Clunk after coming to a stop - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Thread: Clunk after coming to a stop
  1. #31
    Rookie Pottery_Pal is on a distinguished road.
    Join Date
    Aug 2012
    Location
    Texas
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Re: Clunk after coming to a stop
    I have an 07' 4X2 CrewMax 5.7L. I have had the same problem for more than ~2 years. It happens when I come to a full stop, usually rapid deceleration. I believe it is the transmission downshifting from 2nd to 1st. It doesn't happen all the time but several times a week is typical.
    I am not to concerned about it. The truck has ~50k and I have plans to trade it in next year for a 3/4 ton. I am seriously waiting to see what the big three + Toyota' plans are for 2014 models.
    Peace!
  2. #32
    Lurking Member OkiTundra is on a distinguished road.
    Join Date
    Nov 2010
    Location
    FPO
    Posts
    24
    Liked
    0 times
    Rep Power
    3
    Guys, if I may chime in here. The issue resides in the driveshaft (propeller shaft) slip joint. Basically, its not lubed properly allowing for smooth slipping when coming to a stop (expanding) and then accelerating (compressing) due to axle wrap.
    Get you some of the Motorcraft PTFE Teflon Driveshaft Slip Yoke Lubricant Ford Motorcraft XG-8 (ML1167/31508-42027)
    Toyota PTFE Teflon Driveshaft Slip Yoke Grease Lubricant Lube Ford Motorcraft XG-8 (ML1167/31508-42027)
    You will need to remove the shaft boot and clamps thoroughly clean existing grease/lube then apply this slick stuff.
    I did this to mine a couple of months ago and havent had the problem so far.
  3. #33
    Rookie piperman is on a distinguished road.
    Join Date
    Aug 2012
    Location
    San Antonio
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Are you talking about the slip yoke that goes into the tailshaft housing of the transmission?
    I remember my son had to do the same with his Ford F150 4x4.
    Except his was the yoke at the rear end diff.
    Steve
  4. #34
    Join Date
    Nov 2010
    Location
    FPO
    Posts
    24
    Liked
    0 times
    Rep Power
    3
    Wink Re: Clunk after coming to a stop
    Quote Originally Posted by piperman View Post
    Steve
    Steve, at least on the 4X4 Tundra's, the slip yoke is in the rear half of the two peice drive shaft just aft of the center carrier bearing. There are no lube points on this shaft externally therefore needs to be dismantled.
    The 2WD slip yokes are all in the tail housing of the tranny and are supposed to be lubed via the fluid in the tranny. In this case, I would remove the driver shaft inspect the slip yoke and apply some of the Motorcraft PTFE Teflon XG-8 on the splines and see if that works.
    Works like a champ in my situation.
  5. #35
    Join Date
    Aug 2012
    Location
    San Antonio
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Ok, that seems to be the way the F150 was also. Good, I'll definitely do that, I have some Super Lube on order pretty much the same thing.
    Thank you.
    Steve
  6. #36
    Veteran Member headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj creates their own distinguished roads. headleyj's Avatar
    Join Date
    Jul 2003
    Location
    Ellettsville, IN
    Age
    35
    Posts
    507
    Liked
    8 times
    Images
    37
    Rep Power
    427
    Do you guys get this bump on taking off sometimes too? So how much lube does it need? Do you fill it absolutely full, just enough to provide a smooth surface or somewhere in between?
    08 Tundra DC 5.7 4x4 TRD
    11 Honda Pilot 4x4
    04 Kubota L3830 4x4
    06 Yamaha Kodiak 450 4x4
  7. #37
    Veteran Member Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass is a glorious beacon of light. Geordybass's Avatar
    Join Date
    Oct 2009
    Location
    Sun Valley
    Posts
    534
    Liked
    12 times
    Images
    3
    Rep Power
    235
    My tranny fluid was leaking and when they fixed some busted seals and refilled it went away completely, they also replaced my driveshaft too... but shifting isn't smooth on these trucks, unlike my pops 1st gen to be honest
    -2008 Toyota Tundra V8
    SR5 Tow Package 4x2
    5.7l Dual VVTI
    Bilstein 5100 All Around
    K&N 63 Series CAI
    Dirtydeedsindustries/BAMufflers Exhaust
    -2006 Toyota Tundra V8
    Limited TRD Offroad Package 4x2
    4.7L VVTI
    35w 5000k Fog Light HID's
    K&N Drop-In Filter
    BAMufflers/Dirtydeedsindustries Exhaust
  8. #38
    Lurking Member 2rz-fte is on a distinguished road.
    Join Date
    Sep 2006
    Location
    91/605
    Posts
    33
    Liked
    1 times
    Rep Power
    7
    Quote Originally Posted by OkiTundra View Post
    I have a 2005 2wd 4.7 and it clunks bad. does the prop shaft seal then tranny fluid inside? So if I slide out the shaft will there be fluid everywhere?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
