Old 06-30-2009, 07:36 PM
Last Online: Yesterday 10:50 PM
Big Vic is on a distinguished road.
Big Vic's Photo Albums
Default Another mirror swap question
I have searched and read the threads on this topic and have not found my answers to some questions. I have an 08 power mirror which is not heated. I have the 11 wire connector harness at the mirror (not the 3 wire) and the standard power mirror switch with a 9 wire connector. There is no mirror heat on switch on my console.
So...if I upgrade to the OEM toyota or aftermarket mirrors with power, heated, and turn signal, I am pretty sure that I will get the signals and power. But how is the mirror heat controlled since I do not have a dedicated mirror heat switch?
Also, does anyone have the wiring diagram to the mirror which shows which two wires go to the signaling leds?
Old 06-30-2009, 07:47 PM
joepersad's Avatar
Dealer : Serra Toyota Scion
2008 Toyota Tundra XSP,
- Other - 1969 Conv. Mustang
Last Online: Yesterday 09:39 PM
joepersad is on a distinguished road.
joepersad's Photo Albums
Default Re: Another mirror swap question
if your truck has a defrost button under the radio it will more than likely work fine. I just put limited mirrors on my truck and they indicate great and I did not do any additional wiring, just installed them. I say try it?
Old 06-30-2009, 08:55 PM
ninja ed's Avatar
Dealer : Findlay Toyota Scion
2008 Toyota Tundra 08 White CMaxSR5 TRD
Last Online: Yesterday 12:48 PM
ninja ed is on a distinguished road.
ninja ed's Photo Albums
There is no specific button just for the heated mirrors, they just come on when you press the defrost button but if you say u have 11 wires your good to go. I was told 8 or more wires any mirror swap will work with of course the addition of a mirror fold button if you wanted that option with the limited mirrors.
2008 White CrewMax SR5 4x4 TRD
No Fear .50Cal Grille - NoFearGrilles.com
Tow Mirror Swap! =]
Coga PA System
5% Tint
Color Matched Grille Surround
DRL Disabled
Old 07-02-2009, 12:14 PM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Today 12:01 AM
Images: 44
Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light.
Tankerhank's Photo Albums
You say you don't have the switch under the radio with the little defrost sqwiggle, but you have all the wires at the mirror connector I am betting the plug is dangling behind there, so buy the switch and then find where the fuse goes and add it... all should work.
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2005 Rockwood 26' 5'er
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
