Old 07-07-2009, 05:21 PM
Cooterfoot's Avatar
Dealer : Classic Toyota
Last Online: 10-08-2009 10:56 AM
Cooterfoot is on a distinguished road.
Cooterfoot's Photo Albums
Default 305/50/20 on factory 20"? No lift, will they work?
I search the forums but haven't found anything from someone who doesn't have a lift or leveling kit. I know they rub the skid plate even with some lifts but do they rub the wheel wells? Everything on mine is stock with 20" factory limited wheels. If anyone in the same situation or know anything it will be greatly appreciated.
08 CM 4x4 Limited
Old 07-07-2009, 06:14 PM
dragaeran's Avatar
Dealer : World Toyota Chamblee
2007 Toyota Tundra,
1997 Toyota 4Runner 4x4 Green Upgrades!!,
1997 Lexus LX400 should be LS400
Last Online: 11-22-2009 09:17 PM
Images: 4
dragaeran is on a distinguished road.
dragaeran's Photo Albums My eBay
Default Re: 305/50/20 on factory 20"? No lift, will they work?
They would probably rub b/c of the offset
Old 07-07-2009, 08:26 PM
jeffe1977's Avatar
Dealer : Tom Scott Toyota
Last Online: Yesterday 06:42 PM
Images: 2
jeffe1977 is on a distinguished road.
jeffe1977's Photo Albums
They will not rub the wheels wells. They are only 32"s tall. Should have NO problem.
2" Tuff Country
285/65r18 BFG AT's
Old 07-07-2009, 09:22 PM
Kenpachi Z's Avatar
Last Online: Today 04:19 PM
Images: 9
Kenpachi Z is on a distinguished road.
Kenpachi Z's Photo Albums
I have the 20" BBS wheels with the same tire size and no rubbing here,no lift kit etc.. I think youll be fine.
07 Silver Sky Metallic XSP
90 Mitsubishi Eclipse GSX "LS9 Killer"
Old 07-08-2009, 04:06 AM
jhip's Avatar
Dealer : Servco Auto Center
Last Online: Today 02:06 PM
Images: 5
jhip is on a distinguished road.
Send a message via AIM to jhip jhip's Photo Albums
I've been wondering about this for quite sometime myself. I was also considering getting a new set of 20's but slightly wider (like 20x9 or 20x10) with possibly a Toyo Open Country M/T tire or similar.
Old 07-08-2009, 10:41 AM
Dealer : Pat Lobb Toyota of Mckinney
Last Online: 09-06-2009 09:26 PM
Koldsimer is on a distinguished road.
Koldsimer's Photo Albums
I just put 305/50/20 on my truck with the stock 20" chrome wheels. What a difference! I was concerned that the stock wheels offset would cause them to hit the uca's but no problems here even at full lock with some suspension compression. Hooks up better, handles better and looks so much better with a little tire sticking out.
Old 07-08-2009, 01:42 PM
Cooterfoot's Avatar
Have to agree with you Koldsimer. Went this morning and put on my 305/50/20 Tera Grapplers AT on the stock limited wheels. Close to the uca's bout 1/2". I went down a pipeline to flex it at all angles while turning and no signs of rubbing. Just a note, I went from factory alenzas 275/55/20 and it rides whole lot rougher than I expected, guess the nittos have a much stiffer sidewall. Fixin to check the pressure and makes sure they didn't put 50psi in em. Thanks for all the input.
08 CM 4x4 Limited
Old 07-08-2009, 02:00 PM
Dealer : North Park Toyota of San Antonio
Last Online: 11-06-2009 11:41 PM
RamItOne has a brilliant future. RamItOne has a brilliant future. RamItOne has a brilliant future. RamItOne has a brilliant future. RamItOne has a brilliant future. RamItOne has a brilliant future.
RamItOne's Photo Albums
LOL cooter you can't compare an alenza ride quality to nitto terras, whatever you do will not even get you close to the ride quality you had.
If you can't Dodge it, Ram it, then buy a Tundra
08 5.7 Black D-Cab LTD Red Rock int....
Old 07-08-2009, 03:45 PM
Cooterfoot's Avatar
I was expecting a rougher ride but it is VERY rough. I run dick cepek mud countrys on my Z71 and they are way smoother. I bounce around on semi bumpy roads and my traction control light blinks. Gotta get used to them is all.
08 CM 4x4 Limited
Old 07-08-2009, 03:59 PM
Dealer : Atlantic Toyota
Last Online: 07-21-2009 01:11 PM
07supercharged is on a distinguished road.
07supercharged's Photo Albums
Just my 2 cents........i think you need at least 9 inch wide rims for that size tire. I put 305/50/20 s on 20x9 rims, tire rack will tell you same thing.they will physically fit the rim.....but will wear out outsides faster.
good luck.
Old 07-08-2009, 06:23 PM
jhip's Avatar
Images: 5
Koldseimer / Cooter, please post some pics!
Old 07-08-2009, 10:54 PM
Last Online: Yesterday 10:15 PM
Images: 1
cliff clavin is on a distinguished road.
cliff clavin's Photo Albums
Hmmmm thats odd...I have the same tire in the 275 55 20 size and do not find the ride rough at all.....I double checked and your tire size is not a Load E tire.....What was your tire pressure? I think I run around 40 in mine.....
Old 07-08-2009, 11:34 PM
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 01:29 PM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
We need to see those pics please!
And mileage "improvement".
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
