07-12-2009, 10:55 AM
Last Online: Today 10:22 AM
2
Just found a great place for rust to hide
I was washing the beast the other day and found this place. Right in the bottum of the door jam of the driver side there is a black rubber flap. Put my hand in there and pulled out 4 had fulls of leaves and mud. This is great place for rust to start eatting it from the inside out. Just thought I wood put it out there.
07-12-2009, 11:39 AM
Benny Hill
37
Re: Just found a great place for rust to hide
Not sure where you are talking about. Got any pictures ???????
07-12-2009, 11:44 AM
The emblem & panel guy
Last Online: Today 09:23 AM
4
Originally Posted by
thePYRITEship
I wouldn't put your wood out there...... it's might bet damaged
2008 Tundra 5.7L RCSB
Custom Switch panels and Emblems for your tundra. PM for details
READ IT, LEARN IT, STAND FOR IT
http://www.usconstitution.net
Si vis pacem, para bellum
07-12-2009, 12:02 PM
2
Yeah kind of a bad place to be putting wood.
But for pic I'm not sure how to post them. If you open your door and look down towards the engine there is a flap that blends into the look of the finder and if you push it back that is the space I have found.
07-12-2009, 07:45 PM
2006 Toyota Tacoma, 2008 Toyota Tundra
Last Online: Yesterday 07:39 PM
3
thePYRITEship
You are correct! I've been cleaning leaves and dirt out of that area since I bought my truck. If you open your door just look down below the hinges and you will see a small black flap. Just pull it out and start cleaning. This little area is somehow connected to the drain from below the windshield wiper tray.
Definitely a place to be sure you keep clean. OH and I noticed that the never Tacoma's also have the same flap.
07-12-2009, 08:16 PM
Assistant Administrator
2005 Toyota Tundra AC 4.7L 4WD, 2004 Toyota RAV4 Sport 2.4L 2WD
Last Online: Today 09:35 AM
10
It's a spot to check on the Gen1 also. Pulled many dirty, muddy, wet leaves and pine straw outta that tough to reach spot.
My Truck: 2005 Tundra , 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP. Suspension & Tires: 285/75-16 BFG T/A'ko , Fabtech Coils, 1.5" Wheeler's blocks , Toytec Diff Drop , 1.25" Spidertrax [front] , 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links , Wheeler's Anti-Sway Kit , Hellwig 7700 Swaybar , Timbren Rear SES
Electrical: URD MAF Sensor Calibrator , Superlift Truspeed Speed Sensor Re-Calibrator , ScangaugeII , Full LED Conversion
Stereo: Alpine CDA-9886 , Alpine & Phoenix Gold amps, Q-Logic box w/RF subs , eDead
Cosmetic: Line-X Bedliner , Custom N-Fab Steps , Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve , Debadged (partially ), Bell Truck Trunk, Access Vanish Tonneau
B e an organ & tissue donor, register at Donate Life
07-12-2009, 08:43 PM
Diplomacy is dead!!!
Last Online: Today 11:25 AM
18
Good info man...Thanks for sharing. I'll be cheching this out later today..
07-13-2009, 09:33 AM
2
I wonder if there is anyway to block this or let it go on thruogh without getting trapped. Any suggestions? I'm sure I wood put it into a working situatoin. Thanks
10-25-2009, 10:03 PM
Last Online: 11-07-2009 01:50 AM
0
Thanks for that info I have just over 800 miles on my new truck. This would be a great time to put some corrosion prevenitve treatment in there.
Linear Mode
