I've been holding out on yall for a while and now it is time to unveil my lastest and greatest cheap mod. We did this first on my fiancee's tC a while back and it was finally time to do the Tundra. I wanted to wait for the color matched door handles, but its easy to do again.
The total spent on this project was a little less than $10, because I had a lot of the supplies laying around the house. If you have common mechanic tools, wire, etc. you can do this for $10.
If you do this right, your LEDs will fade on when you push unlock, then when you close the door they will stay on until you turn on the ignition or push lock, then they will fade out. They also come on when you open the door and go off when you close it. To get this effect you must tap into the light i show you.
As always, this worked for me. Do this at your own risk it requires cutting/drilling
Materials and Tools
2- LEDs, i use oznium.com, they are the 4chip superflux (brightest LEDS i've found) ($3.29 each)
Philips head
Flat head
13/64 drill bit
drill
wire strippers
4.5" angle grinder w/ cut off wheel
18 guage wire
wire crimps or other suitable wire attacher thingy
10mm nut driver
t30 torx driver
few extra missile clips (help section, advance auto)
electrical tape.
misc handyman tools
I did not take pictures of the full tear down of the truck to spare you guys the superfluous information and pictures (door panel removal is in the DIY section)
Here are what the LEDs look like, my lovely fiancee is showing them for you. I use these because they are 4 chip leds, they are super bright and they are prewired and waterproof and CHEAP @$3.29
First remove the door lock part of the handle by removing the little rubber thing
Then unscrew the torx t30 behind that cover, the bolt wont fall out. Then you can pull the lock cylinder out, it helps to use your key. On my truck, the passenger side is a dummy cover there is no lock cylinder on that side.
Next order of business is to drill the holes in the covers where you plan on mounting the LEDs, I found that a 13/64" hole was perfect for the "domed" part of the LED to peep thru.
Next is the part where you guys may decide this mod is not for you. You have to cut some excess metal off of the lock cylinder in order for the LED to fit inside the cover and go back together properly. You will see that this is not a structural piece, and nothing snaps to it, it is just there. Cut it off. Here is a pic of what I cut off, dotted line in red
Here you will see the LED glued in place where the metal used to be, i cut it so it was a snug fit so the LED wont move.
Next you need to run wires to power the LEDs. You want to use this light under the dash to tap into for power because it is the only light that fades in and out, and it works with the key fob...totally sweet.
Remove the door panel and run your wires. I arrowed the path i took, went through the grommet by the speaker, and then through the door grommet.
Here are the installed shots of the LED under the door handle.
HERE is the money shot.....the fade on/ fade off with the unlock/lock button
GOOD LUCK
-Tim
2008 Tundra RCSB, Slate Metallic, Sport Appearance Package
5.7L, 6 Speed, 4.10s
McGaughy's 4"/6" drop
22" Boss 331s wrapped in Nitto 305/40
Custom true duals with X-pipe, 18" Magnaflow
Black headlights, anytime fogs
Hella Celis LED taillights
20% tint on stock privacy glass
35w 6000k HID lows and fogs
Superflux LEDs custom installed in door handles
Homelink Auto-Dim mirror w/ compass and LED console light
Very nice detailed write up!
I need to do something similar for my sequoia.
__________________ 2001 Toyota Tundra SR5 4x4 - JBA Ceramic Headers, Walboro 255LPH Fuel Pump, 1UZ Rods, IPT valve body, 20" x-sp enkei wheels, 7009 navi w/custom JBL wire harness + OEM XM/Sirus radio, drive by wire, and many other mods.
Thanks to RCsTundra (see his signature for Toyota Tundra service manuals)
2003 Nissan Maxima SE - (Platinum Edition), 3.5L (VQ35DE Engine), 4 speed auto, w/ factory Navigation, Xenon Headlights, Heated Steering Wheel/Seats, + way too many other options. Pretty quick for family car. (Nissan FSM http://www.nicoclub.com/FSM/)
I had fading puddle lights in my IS350 but they were in the bottom of the mirrors. I used red LED's and they looked sick at night. I'll definitely be doing this eventually.
"Skin grows back - paint doesn't" - Chip Foose
09 Tundra. 5.7 DC 4x4. True Duals - Powersticks. Red Out Tow Mirrors.
07 FJ Cruiser. 6 Lifted. 35's. Winch Bumper. One of a kind. Sold.
06 IS350. Slammed. Eibach. Greddy. Fujita. ACE. Sold.
