Success!!! VSC and Lift issue Fix Confirmed!
+ Reply to Thread
Page 1 of 10 123456 ... LastLast
Results 1 to 15 of 144
Like Tree6Likes
Thread: Success!!! VSC and Lift issue Fix Confirmed!
  1. #1
    Junior Member sknaus's Avatar
    Join Date
    May 2003
    Location
    Rollinsville, Colorado
    Posts
    208
    Liked
    3 times
    Rep Power
    16
    Exclamation Success!!! VSC and Lift issue Fix Confirmed!
    Ok you guys, ever since I put on the Bilstein 5100's I was having issues with the VSC going off around corners unless I went really slow. After having the Zero Point cal done and it didn't fix the problem I was getting upset. After looking into this further, the fix is quite simple. Thanks to Sparks for giving me the diagram for the VSC sensor. The problem lies with the Yaw and deceleration sensor. It seems to be very sensitive to any nose up condition. Here is what I did. I removed the sensor and shimmed up the back side so it would have a slope, nose down, to it, to simulate not having the front lift. I re-calibrated the Zero Point per the pdf file and bam, no more VSC problem. I was taking the corners squealing the tires and no VSC engagement. To get to the sensor you need to remove the center console. I put 3 of the washers shown on the back side. Be sure to tighten the front first, then the back. I have an 07 Crewmax 4x4, but I imagine all others are the same. Hopefully this will work for you guys too!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	44435   Click image for larger version.
ID:	44436   Click image for larger version.
ID:	44437   Click image for larger version.
    Attached Files Attached Files
    keninsb, NCPaulD and c_h1132 like this.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Grizzly05's Avatar
    Join Date
    Feb 2008
    Location
    Seattle, WA
    Posts
    164
    Liked
    0 times
    Images
    4
    Rep Power
    149
    Default Re: Success!!! VSC and Lift issue Fix Confirmed!
    I was going to make an appointment today to have the zero point calibration done again. I get the same thing when pulling a trailer and going around corners. This is awesome news! Thanks!
    2008 Tundra Crewmax Limited TRD Offroad 4X4 5.7, TRD sway bar, Bilstein 5100's, Deaver mini pack, Firestone airbags, N-Fab Stainless step bars, dual stebel horns, 10 ply Michelins, Auburn LSD, Onboard Air System.
    2007 4Runner Limited 4.7 V8 4X4
  4. #3
    Join Date
    Dec 2006
    Location
    _
    Posts
    1,268
    Liked
    5 times
    Rep Power
    1694
    nice work, I bet you are going to make a lot of guys with lifts quite happy this morning....
  5. #4
    Junior Member catalyst105's Avatar
    Join Date
    Jan 2009
    Location
    West Palm Beach ,Fl.
    Posts
    109
    Liked
    0 times
    Rep Power
    21
    Did you re-calibrate using the SST method, if so where is that located?
  6. #5
    Join Date
    May 2003
    Location
    Posts
    208
    Liked
    3 times
    Rep Power
    16
    Thread Starter
    yes, just use a jumper wire and the connector is under the dash next to the TPMS button.
  7. #6
    Veteran Member mudfuel07's Avatar
    Join Date
    Aug 2007
    Location
    Trenton, Fl
    Age
    36
    Posts
    555
    Liked
    0 times
    Images
    18
    Rep Power
    1211
    Thanks very much, that will solve my problem with the VSC.
    Pulling Open Road Puresport 38-3L-5 Toyhauler!
  8. #7
    Back from the dead! Gutz's Avatar
    Join Date
    Apr 2009
    Location
    SoCal
    Posts
    1,778
    Liked
    4 times
    Images
    24
    Rep Power
    1717
    Great bit of information!!!! Thanks for sharing!!
    2007 RCSB |5.7 | TRD SC | JBA Headers | Auburn LSD
  9. #8
    Supporter Art64's Avatar
    Join Date
    Jul 2006
    Location
    Perris, CA
    Posts
    1,426
    Liked
    15 times
    Rep Power
    284
    That's it. No wonder my truck feels quicker with the factory rake compared to when I lower the rear. I have Alcan soft springs with Firestone airbags. With the airbags at 5 psi, the rear is lower than stock. The truck feels sluggish on acceleration. I thought it was just aerodynamics but I'm also thinking the truck has accelerometer and yaw sensor which maybe interpreting the truck is loaded.
  10. #9
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Rep Power
    268069
    Quote Originally Posted by Art64 View Post
    Do you disable nannies while you feel this sluggishness?
    Attention environmentalists, reduce emissions from this:
  11. #10
    Join Date
    May 2003
    Location
    Posts
    208
    Liked
    3 times
    Rep Power
    16
    Thread Starter
    Just a quick update, went for a long drive today and noticed that sharp right hand curves there was still a little bit of sensitivity of the VSC. There was none on the left hand curves. When I got home I check the sensor again and noticed it was not level from left to right. So I ben the bracket to make it level side to side and went back out and the right hand sensitivity was gone. It did not change the left hand sensitivity. So what I am suggesting is to make sure the side to side is not skewed when you do this mod.
    Steve
  12. #11
    Join Date
    Jul 2006
    Location
    Perris, CA
    Posts
    1,426
    Liked
    15 times
    Rep Power
    284
    Quote Originally Posted by Mr. Creosote View Post
    The nannies are always off when I drive except for really short ones like reparking the truck. I got used to the routine of turning the nannies off as soon as I start the truck. I also use "S" mode 99% of the time and have been using 91 octane gas for years now. The sluggishness is not too much though. It's like putting 500 lbs in the bed. I guess the computer can relearn after sometime, but I just put the factory rake back on. It's quieter on the highway(less wind noise) and also on the track at 118 MPH.
  13. #12
    Junior Member Dmonies's Avatar
    Join Date
    Mar 2009
    Location
    ct
    Posts
    68
    Liked
    1 times
    Images
    1
    Rep Power
    7
    hmm. i have this when i brake and turn left.. how much does the dealer charge to zero the vsc?
    07 white dbl cab ltd tundra loaded.
    7"BDS LIFT 20" rockstars with 37" nitto mud grapplers
    http://www.tundrasolutions.com/forum...summer-meet-4/
  14. #13
    Supporter Shotgun Scott's Avatar
    Join Date
    Oct 2007
    Location
    Binghamton, NY
    Posts
    39
    Liked
    0 times
    Images
    9
    Rep Power
    8
    Quote Originally Posted by sknaus View Post
    Steve
    Just a thought about why it may have been occuring with rights more than lefts. Since we drive on the right side of the road, the turn radius is usually shorter for a right hand turn, if it is a two lane road/ramp. That makes for higher G's given the same speed for that turn radius. Or, as you said, the sensor wasn't balanced. Could be a sway bar issue as well I assume.
    I am thinking about trying this mod on my 2006 Tundra before they mount the new (larger) tires, and then have them zero balance the VSC system. Is the unit under the center console like it is in the '07 and ups, and what size washers did sknaus use? I wish the truck had a VSC defeat button, so I could just kill the thing all together.
  15. #14
    Rookie mjgoug's Avatar
    Join Date
    Jun 2009
    Location
    Salt Lake City
    Posts
    6
    Liked
    0 times
    Images
    4
    Rep Power
    0
    They charged me $110 which includes tax. It took them 5 minutes. Those bastards!
    2007 Tundra Limited, 2.5" leveling Kit, 20" MKW with 33's.
  16. #15
    Lurking Member witness91's Avatar
    Join Date
    Jul 2006
    Location
    Maryville TN
    Posts
    27
    Liked
    0 times
    Images
    15
    Rep Power
    9
    Does that washer mod really work? Should I do that right after installing my lift/tires to prevent VSC engagement?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
