Closed Thread
Old 08-23-2009, 06:46 PM
Last Online: 08-23-2009 07:47 PM
Images: 1
bluecollar_tweeker is on a distinguished road.
bluecollar_tweeker's Photo Albums
Question rear axle seal... the saga continues
My rear axle seal on the 2000 Tundra has blown and flooded my drums. Again. This will be the fourth set of seals in 2 years.
The seal started out weeping a tiny bit, and I let the dealership talk me into replacing it. I suspect one of their 18 yr. old, $110/hr. techs didn't put it back toether with the manic level of attention to detail that this job deserves, and its never been the same since.
On a seemingly (to me) unrelated note, my truck has been reluctant to shift into 4Low ever since I bought it. (I always come to a complete stop and shift to neutral before pressing the button) Lately it hasn't worked at all. Last time I tried it the light blinked repeatedly, then a horrible grinding noise occured that sounded roughly like the mechanical equivalent of someone hitting a baby with a cat. I suspect the actuator rod problem that has stealthily plagued the 2000 Tundras while flying under the radar of most dealership techs.
My question is this:
Is it possible that my faulty transfer case is causing my axle seals to blow? Thinking back on the problem, I have heard the grinding noise before, and I THINK (but am not 100% sure) that it has occured each time before I discovered my my blown axle seal.
I hate to mistake a coincidence for a cause & effect relationship (I'm fairly sure thats how religions get started) but I can't help but wonder. Anybody?
Also, if I elect not to fix the rear brakes and axle seal right away while I try to diagnose the cause of the problem (4 times already suggests a 5th will be not far away), do I run the risk of causing further damage? I'm not too concerned about the loss of rear braking ability (it's a Tundra remember?)
Thanks
Old 08-23-2009, 07:01 PM
Rut's Avatar
Rut Rut is online now
Dealer : Team Toyota
Last Online: Today 11:42 PM
Rut has blessed us with their presence. Rut has blessed us with their presence. Rut has blessed us with their presence.
Rut's Photo Albums
Default Re: rear axle seal... the saga continues
This is the second Gen Tundra section. You will get more help in the first Gen section
My garage:
http://www.vhoist.com/ride/100527
Old 08-23-2009, 07:29 PM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Today 11:46 PM
Images: 45
Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all. Tankerhank is a name known to all.
Tankerhank's Photo Albums
Thanks
Like said you will do better bringing this up in the 1st gen Tundra section, with that said I had rear seals go twice on my 2000 Tundra. Then second time I replaced the seal myself and was astounded to find hammer marks all over the old seal, the Toyota mechanic at Precision Toyota just took a hammer and pounded the seal in... no wonder it leaked... again. After I did it never had a problem, one more reason I don't let them even change the oil.
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
Old 08-24-2009, 11:21 AM
dyogim's Avatar
SAS'ed #5
2000 Toyota Tundra,
1998 Toyota Camry
Images: 88
dyogim's Photo Albums
Thread already started in the 1gen forum.
Closing this thread.
Mike
http://dyogim.blogspot.com
Closed Thread
Tags
4 low , actuator , flooded drums , rear axle seal , transfer case
