Old 09-20-2009, 01:31 PM
fire_mike's Avatar
Dealer : Findlay Toyota Flagstaff
2010 Toyota Tundra Slate 4x4 Crewmax
Last Online: Today 01:10 PM
fire_mike is on a distinguished road.
fire_mike's Photo Albums
Default Another 5100 thread. . .
I have been looking at threads about the 5100's, and I think I might go that route. I really like the 3"/1" lift I had on my '08, and I'd a bit worried that I won't be happy with the 5100's at the 2.5" mark. I have not had much luck finding pics that compare a 2.5" with the 3" lift - does anyone have any? I am thinking that I might try to get a bit more lift by using a 1/4"-3/8" custom spacer (stell or maybe aluminum) at the top of the shock - any thoughs on this? Also, do these shocks act like the toytec lifts by preloading the spring?
I think these are a good way to go because I found them for $266 with free shipping for a set of 4. That is what I was planning on spending on a 3/1 spacer kit. I figure that I can find some blocks and a diff drop kit for about $100, so I can have way better shocks for only 100 more bones - seems like a good idea to me.
One more thing - how well do these work withthe non TuRD springs? I have read plenty about them withthe TuRD's, but nothing about the regular springs.
Old 09-20-2009, 01:52 PM
wildbill129's Avatar
Last Online: Today 01:20 AM
Images: 6
wildbill129 will become famous soon enough.
wildbill129's Photo Albums
Default Re: Another 5100 thread. . .
Mike,
I have a 2.5" lift. It's not a Bilstein but an OME. Should give you an idea though. I put 1" blocks in the back to leave some rake. Had I not, it would have been exactly level. I am very happy with the lift. Pics in my album...
2007 Crewmax 4x4 Limited - Silver
2.5" OME Front Lift w/Toytec 1" Diff Drop
1" Toytec Block rear w/Bilstein 5100 shocks
20" Ultra Mammoth Wheels
305/55/R20 Toyo Open Country A/T
Line-X Bed Liner
Undercover Tonneau
Console Vault
Two car seats and a box full of princess toys!
CBTMA Member
Old 09-20-2009, 01:57 PM
VooDooDan's Avatar
Dealer : Toyota Walnut Creek
2008 Toyota Tundra 5.7 4x4 DBL CAB
Last Online: Today 12:49 AM
Images: 46
VooDooDan will become famous soon enough.
VooDooDan's Photo Albums
They are a tad bit stiffer than the stock shocks(non trd for me). I only have mine set to the 2nd setting(about 1.5in of lift) so I didnt do the diff drop or blocks in the rear. These do compress the springs but not with a spacer. They are kinda like a real coil over but cant be adjusted after you put the spring back on. You have to take them off to adjust them. Check out my photo album for photos.
2008 Tundra 5.7 4x4 LTD Silver w/Navi, XM, & Memory
Magnaflow Dual CAT Back, TRD Sway Bar,
AFE Cold Air, Toyota Fender Flares, VLED's Cab Lights
Bilstein 5100 front/back, Painted Door Handles W/LEDs
Procomp 8128 18in w/285 65 18 BFG AT/KO
More Photos
DIY: LED's in out Side Door handles
DIY: LED Puddle Lamps for LTD Tundra
Old 09-20-2009, 01:58 PM
fire_mike's Avatar
That looks like it might work for me. I was just looking at my front shock mounts, and there is a ton of threads poking out the top of the mount, so I might try a spacer as well - I figure it shouldn't hurt anything by doing that.
Old 09-20-2009, 02:47 PM
tbaxl's Avatar
Last Online: 11-23-2009 10:18 PM
tbaxl is on a distinguished road.
tbaxl's Photo Albums
voodoodan, i am putting my 5100 on this week mid setting also. have you had any negative effects not having a diff drop, did it realign ok anything i should look out for while doing the install.
tim
2009 DC black
4X4 flex fuel
Old 09-20-2009, 03:13 PM
VooDooDan's Avatar
Images: 46
tim
All installed/aligned fine. Been installed for a year now with out any issues.
More Photos
Old 09-20-2009, 04:21 PM
Last Online: Today 10:31 AM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Fire_Mike, post where you get your diff drop kit and the 1" rear block. I'm looking for the same and do not know where to start. I put in an order for the 5100's on friday. I was looking at the Low-Range Off Road 3/1 kit, but decided on the Bilsteins at the last minute..... I am wanting to crank them all the way up.
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
Old 09-20-2009, 04:29 PM
fire_mike's Avatar
If I go the 5100 route, I am going to make some small spacers (for the top of the shocks) out of plate steel (or maybe aluminum). That way I'll get back to the 3" of lift that I like in the front.
I know toytec sells the blocks and diff drop - it would be $100 for both before shipping. There are other diff drop kits out there that ore $10 cheaper, but they don't have the skid plate spacers.
Old 09-20-2009, 04:31 PM
Images: 43
Thanks...... if you go the 5100 route..... use "TEN" and see if you can get 10% off vice the 5% using the tundra code.... Remember that the sale is done at the end of the month.
Old 09-20-2009, 04:57 PM
fire_mike's Avatar
Do you mean use TEN when buying from Toytec? If so, it doesn't work.
Old 09-20-2009, 05:56 PM
Images: 43
Use TEN at Shockwarehouse.....
Old 09-20-2009, 06:10 PM
fire_mike's Avatar
That works! Why is it that the whole kit costs $348, and when you buy it separately it is only $261? Makes no sene to me uless the kit comes with other stuff.
Old 09-20-2009, 06:11 PM
fire_mike's Avatar
nevermind - the price is the same in the cart. The total would be $235 shipped!
Old 09-20-2009, 06:17 PM
Images: 43
Yep !!! It's 25% off the whole kit which makes it $261, then you get the additional 10% which brings it down to $235. That's $26 you can apply towards the Diff drop kit..... yeah !!!
Old 09-20-2009, 06:27 PM
fire_mike's Avatar
Do you know if the 'TEN' works til the end of september too?
