Old 10-13-2009, 09:23 PM
Dealer : Toyota of Nashua
2004 Toyota Tundra
Last Online: 10-13-2009 10:08 PM
mauide is on a distinguished road.
mauide's Photo Albums
Default transponder bypas module
any body done one in 08 tundra , do you have to pull; speedo cluster
Old 10-13-2009, 09:25 PM
sledhead907's Avatar
Dealer : Nye Frontier Toyota/Scion
2008 Toyota Tundra DC TRD Limited
Last Online: Yesterday 12:19 AM
sledhead907 is on a distinguished road.
sledhead907's Photo Albums
Default Re: transponder bypas module
Got a "hot" truck?
2008 5.7L DC Limited TRD / Slate Metallic with Grey Leather interior / fully de-badged --- 19.2mpg over 450 miles averaging 57mph!
Old 10-13-2009, 09:39 PM
Last Online: Yesterday 06:03 PM
Images: 15
jessandjamie is on a distinguished road.
jessandjamie's Photo Albums
Subscribe to this forum and download his DIY's, very helpful. But don't follow it word for word if you don't have the 5701.
http://www.toyotatundraforum.com/ele...start-diy.html
Old 10-13-2009, 10:08 PM
2004 Toyota Tundra
using pk-t2 ,they want to tap on to purple wire at security LED, behind speedo, so light wont stay on , has any had to do this ,sounds like a pain
Old 10-17-2009, 05:16 PM
Last Online: 12-04-2009 11:21 PM
hms2010tundra is on a distinguished road.
hms2010tundra's Photo Albums
that's why I prefer the pkall over any bypass when doing toyotas. If you are using a pkall all the wires can be found in the immobilizer harness at the key cylinder and you don't have to worry about the security light. In your case, the security light is easy to get to. You pull the speaker grill in the middle of the dash and you should have access to the wiring harness. I would double check to see if you need to even hook it up first. To determine this, just remote start the vehicle and let it run for a little bit. Then do the key take-over, if the light still blinks then you are sh*t out of luck! I found tapping into the security light is a hit or miss with some toyotas! I hope this helps and good luck!
Old 10-18-2009, 11:55 AM
fire_mike's Avatar
Dealer : Findlay Toyota Flagstaff
2010 Toyota Tundra Slate 4x4 Crewmax
Last Online: 02-03-2010 11:04 AM
fire_mike is on a distinguished road.
fire_mike's Photo Albums
when I did my '08, the bypass connections were all made in the passenger kick panel. I did not have to connect a wire for the security light - I had no issues with it comming on.
