Read your owners manual. Spark plug replacement 120k, I believe they say to check them at 30k or some such thing.
I have been running Iridiums for years in my motorcycle and in my '00 Tundra even. Iridium plugs just don't wear out, they are an excellent conductor of electricity even.
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
Spark plug replacement is only required on the small V6. Here are the 30k maintanance specs:
2007 Tundra 30,000 Miles - 36 Months
q Replace engine oil and oil filter1
q Rotate tires
q Lubricate propeller shaft (4WD only)
q Replace cabin air filter
q Replace engine air filter
q Replace spark plugs (1GR-FE engine)4
q Re-torque propeller shaft bolt
q Inspect the following:
__ Ball joints and dust covers
__ Brake lines and hoses
__ Brake linings/drums and brake pads/discs5
__ Engine coolant6
__ Exhaust pipes and mountings
__ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
__ Fuel tank cap gasket
__ Radiator, condenser and/or intercooler
__ Rear differential oil
__ Steering gear box
__ Steering linkage and boots
__ Transmission fluid or oil
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
q Replace front differential oil (4WD only)
q Replace manual transmission oil
q Replace rear differential oil
q Replace transfer case oil (4WD only)
q Tighten nuts and bolts on chassis
Driving Off-Road, on Dirt Roads or on Dusty Roads
In Addition to Above, Daily Maintenance When Driving Off-Road Through Deep
Sand, Mud or Water
q Check ball joints and dust covers
q Check brake lines and hoses
q Check brake pads/discs
q Check differential oil
q Check drive shaft boots
q Check engine air filter
q Check nuts and bolts on chassis
2007 Crewmax 4x4 Limited - Silver
2.5" OME Front Lift w/Toytec 1" Diff Drop
1" Toytec Block rear w/Bilstein 5100 shocks
20" Ultra Mammoth Wheels
305/55/R20 Toyo Open Country A/T
Line-X Bed Liner
Undercover Tonneau
Console Vault
Two car seats and a box full of princess toys!
CBTMA Member
regardless of the service interval. it can never hurt to replace plugs early. so does anyone have any info on a good NGK plug to replace with?? or does anybody reccomend anything in particular??
If the man wants to replace his plugs let him!! Give the man advice and be done with it.
If you are referring to the OP, It looks to me like he thought it was required service. I seriously doubt he "wants" to do it.....
Line-X Bed Liner
Undercover Tonneau
Console Vault
CBTMA Member
I am not looking forward to the time mine need replacing. Aluminum heads....hopefully they used anti-sieze at the factory and/or there are helicoils installed.
Attention environmentalists, reduce emissions from this:
JBA Headers
With 30+ years as a professional master tech, DO NOT leave those plugs in for 120k they'll be part of the cyl. head reguardless of what vehicle/spark plug configuration you have. Spending a few dollars on spark plugs is a helluva lot cheaper than having to pull the heads!
5.7 CrewMax SR5 Salsa red pearl JBL XM
Weatherguard mats Undercover tonneau
