Old 11-03-2009, 10:43 AM
Dealer : Ira Toyota of Manchester
2007 Toyota Tundra,
Last Online: Yesterday 02:55 PM
2uprup is on a distinguished road.
2uprup's Photo Albums
Default Best Towing Upgrades
I have read almost all the threads on here about towing with the Tundras. I have a 2007 Tundra SR5 Crewmax 5.7L TRD 4x4. I tow a 4,000 lbs tractor with a trailer that is about 1,500 lbs. I have a brake controller and regular 2 inch ball but that's it for equipment. It feels like I am pulling a tank when I am on the highway, especially long inclines. Also, the rear suspension will bottom out occaisinaly. What are the best upgrades to solve the power issues and rear sag in the truck? I am thinking about adding airbags to the rear suspension and upgrading to a weight distributing hitch. Before I spend all this money I'd like to know what you guys reccomend. Thanks.
2000 Toyota Tundra SR5 AC
2007 Toyota Tundra SR5 CM
Old 11-03-2009, 11:04 AM
RudyDep's Avatar
Moderator
Dealer : Universal Toyota
2007 Toyota Tundra,
- Other -,
2008 Toyota Sequoia Slate Metallic Ltd
Last Online: Today 05:53 PM
Images: 23
RudyDep has blessed us with their presence. RudyDep has blessed us with their presence. RudyDep has blessed us with their presence.
RudyDep's Photo Albums
Default Re: Best Towing Upgrades
I really dont tow anything w/substance, BUT...I would say airbags for the rear to level the vehicle with that trailer attached. I would also recommend a TRD rear swaybar. I cant imagne that your truck would have ANY issue towing that light load and CERTAINLY dont think that 5500 lbs would be an issue. Hang in there, you will get TONS of responses.
Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member"
all that is remaining is:
Black Mod Headlights
1997 Chevy Tahoe Sport 4x4
2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem."
President Ronald Reagan 1985
Old 11-03-2009, 11:26 AM
2007 Toyota Tundra,
I think it has to do more with the awkward shape of the load (tractor) being towed because I also tow a 23 ft boat that is about 5,000 lbs and I barely notice that behind me.
Old 11-03-2009, 11:40 AM
Dealer : Rusty Wallace Toyota
2002 Toyota Tundra,
2005 Toyota Camry
Last Online: Yesterday 03:02 PM
kf4qvi is on a distinguished road.
kf4qvi's Photo Albums
Is your trailer a dual axle? I have a 02 Tundra with 4.7L a pull a trailer with tractor and equipment from time to time. Probably about the same wieght you mentioned. I have to pay very close attention to where exactly the tractor is positioned. Too far forward or backward will make a huge difference, even just a foot or so.
Trucker1967's Avatar
2008 Toyota Tundra DC 5.7 4X4
Last Online: Today 11:21 AM
Trucker1967 is on a distinguished road.
Trucker1967's Photo Albums
Sounds to me like you need a longer trailor, why do you have that kind of tongue weight?
You need to either put that tractor back further on the trailor to reduce tongue weight or if you cannot you are using to short of a trailor or one that doesnt quite accomadate your item correctly, I have had full size cars on a trailor and they dont sag what so ever, why? because I have the car using the trailors suspension, I used no weight distributing hitches, didn't need one for that light of a load, as far as power I had gobs of it.
Sometimes I couldn't get the tongue the way I would like so I would back the car on because of the front engine weight, maybe the tractor could be backed on and that would change the weight distribution better.
Now sometimes you can have to few pounds on the tongue and you will get waggle, I usually had mine around 300 pounds or so just a guess, I would usually try and get it to compress a inch or two using a yard stick ... you must have yours at 1200 to 1500 pounds if you are bottoming out your suspension, thats way too much when its not needed.
Now some things like 5th wheels and other items that are flat out heavy and not adjustable, you cannot do anything about, so you have to use air bags, but a trailor with a movable object on it can be adjusted by moving that item forward or backward to adjust tongue weight.
2008 Tundra DC 4x4 5.7 Black w/Black interior
Old 11-03-2009, 11:46 AM
2007 Toyota Tundra,
Yes it is a dual axle trailer rated for 7k lbs. I have noticed the position of the trailer makes all the difference in the world. I have marked the spot I like best in the trailer floor.
Old 11-03-2009, 11:52 AM
2007 Toyota Tundra,
Great points. I do try to center the tractors center of gravity of the center of the axles. I have an 18 ft trailor so there is plenty of room to place the tractor. I have not tried backing it on the trailor because it looks like the center of gravity would be way too far toward the tongue of the trailor. As far as tongue weight, there is not much because the truck only squats about an inch or 2 when the tractor is loaded.
Old 11-03-2009, 12:03 PM
2002 Toyota Tundra,
2005 Toyota Camry
I usually back my tractor on, unless I have a heavy attachment hooked up. It seems to ride much better. Centering over the axles is the way to go on a dual axle.
Old 11-03-2009, 12:12 PM
2007 Toyota Tundra,
I always end up towing the tractor with the backhoe attachment connected which weighs about 1,800 lbs itself. That's why I haven't tried backing it on yet but might give it a try to see how the truck sits with the tractor in various positions on the trailor.
Old 11-03-2009, 12:39 PM
Dealer : Toyota South
2006 Toyota Sienna Limited,
- Other - 1993 Toyota MR2,
Last Online: Today 07:09 PM
MTeator is on a distinguished road.
MTeator's Photo Albums
If you're bottoming out the rear suspension, get a WD hitch. Airbags won't stop you from lifting the front when the weight goes on the rear. You might not need airbags anymore after you distribute the weight.
Best option is to trade your trailer for a gooseneck trailer
~Michael
2008 Toyota Tundra 5.7 2WD - Toy Hauler / 2006 Toyota Sienna Limited - Kid Hauler / 1993 Toyota MR2 - Autocross Car
Mods: Tekonsha P3; Tow Mirrors; TRD Wheels; TPMS Pipe Bomb
Old 11-03-2009, 02:08 PM
bilztrd's Avatar
Dealer : Carson Toyota Scion
Last Online: Today 02:10 PM
Images: 5
bilztrd is on a distinguished road.
bilztrd's Photo Albums
E range tires! Just got back, first time with the BFG ko's and they are great !
Old 11-03-2009, 04:10 PM
2007 Toyota Tundra,
I'd love to get a gooseneck but the wife drives the truck daily and she would kill me if I installed the hitch in the bed!
Old 11-03-2009, 04:37 PM
It's just a little ball! Get one that has the hidden ball and there's almost no evidence of it in the bed when not in use.
~Michael
Old 11-03-2009, 08:01 PM
Tbirdness's Avatar
Last Online: 11-18-2009 08:19 PM
Tbirdness is on a distinguished road.
Tbirdness's Photo Albums
I agree with all of the above. Get the load on the trailer to be about 60% on hte front half of the trailer and get a equalizer hitch. I just sold one for $200 that is rated for a 750 pound tong weight. Bought another for $200 that has a 1000 pound tongue weight. My trailer is a 20 footer with a total load of about 9200 pounds. Truck sets nearly level. Biggest hazard with too much sag is the lack of braking ability with the front wheels.
T
Old 11-03-2009, 10:45 PM
wassup8687's Avatar
Dealer : Burdick Toyota
2010 Toyota Tundra Double Cab
Last Online: Today 01:50 PM
Images: 2
wassup8687 is on a distinguished road.
wassup8687's Photo Albums
Not sure if they are available for the Tundra but check out Timbren's. They reduce sag by providing a larger bump stop.
