We have spoken with a couple of different companies about producing a non-locking traction aiding differential. After much research, and plenty of personal experience, we are leaning towards a type 1 torsen differential. It is unfortunately the most expensive type to produce, but IMO the high torque ratios available make it the better choice. Price would likely be in the $750 - $950 range. It would be a lifetime unit, though, no clutch packs to wear out. A less expensive type 2 could probably be produced in the $500 range.
So if we are to move forward with this, I need serious commitments. Please post here and PM.
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
The Torsen type 1 seems to me like a better choice than any locker. Would I spend $750 for either one?? Probably not.
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors CBTMA member
Reason: typo
I'm all for it....
although it's probably nonissue, but I am concerned about if it would burn up the ALSD thing-a-ma-jig, when on super slippery terrain..... I could see ALSD over working in slippery scenarios...
Now why couldn't Toyota just offer one from the factory like everybody else!?
-rockstate
"Mr. Policeman" by Brad Paisley
Hey, hey, Mr. Policeman
Bet I can drive faster than you can
Come on Tinker, let's have some fun
Go on shoot me with your radar gun
You look bored and I sure am
Catch me if you can
If the computer kicks in after breaking traction then we will suffer the same sluggish bottom end leaving loose dirt to pavement. we need some sort more like an eaton LSD that will bias torque with out waiting for wheelspin to wake up and do something because the computer will take action long before that happens, a proactive limited slip so to speak Just my $.02
the torsen will react instantaneously to torque transfer so the alsd will not have time to react unless one wheel has no traction whatsoever(in the air ).
only drawback is relative fragility to high impact torque inputs but having an automatic lessens this to a large extent.
looking forward to it for sure.
Thanks porkshop, you covered it pretty well. As you mention, the only downside is no torque transfer with zero traction, one wheel in the air or ice. If one wheel found zero traction, the ALSD would kick in and cause the Torsen to function... it probably wouldn't take much brake to the spinning wheel to cause the torque transfer. This is an excellent article and even compares to the ARB.
Toyota used a Torsen Type 1 in the Supra Turbo, it holds quite a bit of power before blowing.... and it's a 8.7" diff... Which ironically is used in the front of our trucks. IMO a 10.5" Torsen would survive with very little issue behind the 550ft/lbs of a TRD SC. Here is the post discussing the front differential.
Someguy123, the Quaife is a version of the Torsen Type 2. I ran one in my VW Corrado (until it was replaced with AWD).
Brian
Jowett Engineering
Sounds like a fantastic option. I would purchase one of these come next summer for sure.
2007 RCSB 5.7 4x4 Black Sport
Tundra Racing 2/5 Drop, TRD Brakes, Wheels, Swaybar, Exhaust
Morel Elate 3 Way Speakers, Alpine PDX amplifiers, Phoenix Gold Ti 15" Subwoofer in custom enclosure, K40 Laser/Radar Detector, Seat Rail Modification, Back up Camera, Full LED Interior upgrade from VLEDS.com, Homelink Rear View Mirror, http://s116.photobucket.com/albums/o4/sq60ss/
How's that for a no-tire kicking offer? If it pushes $1,000, I would need to wait until after the Xmas bills are cleared otherwise, I'm buying my own Xmas present ....
2007 Toyota Tundra Double Cab SR5 with the 5.7L V-8 and Doug Thorley headers
"Trying to tax yourself into prosperity is like standing in a bucket and trying to pick yourself up by the handle." - Winston Churchill?
