Two questions for supercharged owners
first of all, just a couple of weeks ago i am staring to have a lot of dtc's. mainly cylinder one miss fire code. for example, when i get on it hard before the truck is really hot (the guages are up all the way but they just got there) it throws the dtc consistently. the truck always throws the code, from day one of the blower, if i floor it and its not all the way warm. lately another code has been with the cylinder miss fire. it is one or multiple oxygen sensors. also when i am wide open under steady acceleration up in the 80 mph's the truck kind of stumbles or stutters. its almost like the fuel pump cant keep up with demand. it doesn't do this when i pull 11000lb. so do you have the cylinder miss fire codes? does your supercharged truck stumble at wot in the 80 mph's? obtw i am not hitting the rev limiter which immediately throws the dtc. it is so annoying because the truck goes into limp and the dtc clearer works only sometimes while driving. and yes i have version two of the re-flash, which i worked directly with Jason Lambert (trd programmer) to get done. OK i guess its three questions...what mpg's are you getting with the blower? i get 8 mpg towing the 11k camper 65 mph and around twelve otherwise. when i drove to Florida i got 15.8 mpg with the bimmer bike in the bed.
