Hi, my stock tires are almost wore out. I want to get new rims, probably KMC's and Cooper STT's in 325-60-18. Will that setup work with just a top gunz level kit, or do I need to go to a 3/1 kit? Also, what offset would be best to go with?
Thanks
Yea they will work if you get the right backspace on the rims. Those 325's run pretty wide and you might run into rubbing issues on the upper control arm if you go with stock backspace.
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, AFE PRO DRY INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
