Old 03-08-2010, 09:41 PM
Jumbo Jet's Avatar
Dealer : Deland Toyota Scion
Last Online: Yesterday 10:20 PM
Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of. Jumbo Jet has much to be proud of.
Jumbo Jet's Photo Albums
Default Rainbow Germanium / JL Audio re-install work log
I've been meaning to post this for some time, but laziness got the better of me.
The old system consisted of Boston Pro 60's and Alpine V-Series amps. It sounded nice but the Boston's tweeters were just a bit too bright for me.
New system:
Kenwood DNX8120 - source
Rainbow CS 265.25 Germanium - front stage
Rainbow CAL 25 silk - tweeter
Boston Acoustics NX 67 - rear fill
JL Audio 13TW5 - sub
JL Audio 300/4 V2 - front stage amp
JL Audio 500/1 V2 - sub amp
For a recap of the pre-install work, the truck was gutted and Dynamat Extreme applied throughout.
The headliner was removed and Second Skin Damplifier Pro applied, followed by a layer of SS Heat Wave Pro. This combo to the roof made a huge improvement to outside noise. When it rains the only noise is the rain hitting the windshield. Highly recommend doing the roof.
Old system is disconnected and removed.
300/4 V2 gets opened first, surprisingly small compared to the previous Alpine F550.
Laid side by side it doesnt look as if they'll take up much room at all on the back wall.
Next come the stars of the show, the Rainbow CS265.25 Germanuims. I bought these sight unseen (or heard). For those not familiar with Rainbow, they are a German audio company. There are only a handful of Rainbow dealers in the US, so finding a place to audition them was tough. I just went solely on their reputation from SQ forums and took a chance..... I wasnt disappointed.
Like most German things, they are over engineered, the magnets are huge, they weigh a ton and they look like they will out live me. They are almost too pretty to be hiding behind a grill.
New mounts built and ready for power.
Door panel rebadged
The CAL 25 silk tweeters are much larger than the Boston tweeters so I had to re-drill the existing hole in the sail panels.
Boston's on the left, Rainbow's on the right.
I used black silicone to seal it and help hold the tweeter tight to the sail panel.
Both sails finished.
Next up are the crossovers. Most people running Germaniums would laugh at me for running them passive, I do plan on running them active in the future, but for now they sound amazing as they are. The crossovers on the Germaniums are very flexible, they can be run bi-amped and can be configured about a dozen different ways.
2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
Honda Super Cub
Old 03-08-2010, 09:42 PM
Jumbo Jet's Avatar
Default Re: Rainbow Germanium / JL Audio re-install work log
Part 2:
The dual 10" Rockfords I had running are being replaced as well. The new sub will be a single JL 13TW5. I highly recommend this sub, it sounds amazing and only requires .80 ft3 airspace. The sub is only 2.5" thick so it can be fit just about anywhere.
I had to build a new box, so after some quick measurements I had what I needed. The box will be very simple, nothing fancy since it will be hidden under the seat. JL recommends .80 cubic feet and this box came in at .8001.... dead on. The box is sealed and T-nuts installed for mounting.
Clamped, glued and screwed and allowing to set overnight.
I decided to use pocket holes to secure this box, so the remaining holes were filled with wood filler, dried over night and then sanded smooth.
Next I wanted to build a flush mount trim piece for the top of the box, this will give the sub the illusion of being flush mounted in the box.
First I cut the hole 1/8" larger than the outside diameter of the sub.
Next, using the jig saw I cut out the mounting tabs for the sub.
A quick test fit and its perfect.
Lastly, the trim piece is glued and stapled to the top of the box. The outside fit wasnt perfect, so a quick pass with a flush trim bit on the router and its spotless.
Finally the box is ready for carpet.
Wires are run, then its all buttoned up and ready to go.
For a small comparison, the two boxes side by side. Out with the old, in with the new.
I also ran the wire for the 500/1 sub control. For the knob I used an empty spot next to my tow/haul button.
I added some white craft paint so the center point was more visible.
Finally the new amps and crossovers are installed on the amp rack and all connections are finished up. I dont expect this to visually win any awards, but I feel its run cleanly and keeps with the overall simplicity of the install. I spent a few extra minutes to properly set my gains with a DMM. I used a 50hz test tone for the 500/1 and a 1kHz test tone for the 300/4. Then the seats were ready to go back in. Since the amps are installed right side up, tuning and making adjustments is difficult once the seats are in. I keep a small mechanics mirror in the back in case things need tweaked, and the JL's have a great feature where the adjustment dials click at every increment, so making minor changes is pretty simple.
I would like to fabricate a beauty board in the near future to hide the wiring and showcase the amps, but once the seats are back in the wires are hidden and out of sight.
And the sub in its final location.
Again, clean, simple and stealthy was my goal for this build. The sound is nothing short of amazing. The Rainbows and JL 13TW5 are an awesome combination, I'm loving the warm and natural sound that the Rainbows produce.... they are an awesome speaker. The CAL 25 silk dome tweeters are buttery smooth and there is virtually no listening fatigue at high volumes for extended periods.
I wasnt quite sure what to expect with the JL 13TW5, but I was pretty surprised to hear just how low this thin sub can get. It can easily handle some of the lowest notes I've thrown at it so far, yet as far as sound quality is concerned, it handles rock music like a champ. Bass notes are clean and tight, kick drums sound fast and accurate and response is very quick. I'm very happy with this sub.
Next phase will be running them active.....
Thanks for looking,
Mark
Honda Super Cub
Old 03-08-2010, 09:59 PM
slackjaw07's Avatar
slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold. slackjaw07 is a splendid one to behold.
slackjaw07's Photo Albums
Absolutely beautiful! How many hours and how much $ do you have into this project? Did you do it all yourself?
2007 Toyota Tundra CrewMax SR5 5.7L w/ TRD Package, Blue Streak Metallic/Graphite, FormulaOne Pinnacle Ceramic Tint (15%), auto-dimming mirror, Line-X Bedliner (under the rail), RS3200 alarm/GBS/hood switch, brushed stainless steel running boards, bed extender, door sill protectors, TRD rear sway bar, TRD CAI, Corsa Touring exhaust, factory accelerator pedal and floormats.
Old 03-08-2010, 10:04 PM
Dealer : Gresham Toyota
Last Online: Yesterday 10:58 PM
JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold. JonnyHotnuts is a splendid one to behold.
JonnyHotnuts's Photo Albums
Kudos big time Mark.
Very few people know what Rainbow is. I am a collector of high end and rare car audio.
I will be installing a trio of Rainbow Vanadium 10" with a Dynaudio front stage (amps are XES M50's).
We could quite possibly have the only 2 Tundras in the world with Rainbow drivers.
~JH
2X World land speed record holder.
H/MS #335/1335
Gas, Fuel, Blown Gas, Blown Fuel
Owner of 4 Tundras, and considering another....
*My motorcycle makes more HP then your Tundra.
Old 03-08-2010, 10:05 PM
Jumbo Jet's Avatar
Thank you. I have no idea on hours..... but its ALOT. Yes, I did everything myself.... except take the back seats out, the wife helped with that.
Honda Super Cub
Old 03-08-2010, 10:07 PM
ThirdHorseman's Avatar
Apocalyptic Wit
Images: 14
ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all. ThirdHorseman is a name known to all.
ThirdHorseman's Photo Albums
You never cease to impress me
How are those Rainbows?!?!?!?! I am partial to Focal but I've heard nothing but amazing feedback on those.
2010 Tundra Limited Crewmax 5.7L 4x4
HID retrofits, 20 inch Platinum wheels, TRD swaybar, Bilsteins, Deaver springpacks, Truxport tonneau cover, debadged.
Old 03-08-2010, 10:12 PM
Jumbo Jet's Avatar
~JH
haha, thats awesome. The Vanadiums look sweet, never listened to them but the reviews are great. The dealer I bought the Germs from was a Dynaudio dealer as well. He almost talked me into them, but I was determined to try the Germs, and I absolutely love them.
Youre so right about the Rainbows, most people that get in my truck have never heard of them, then after a quick demo they are in love.
Honda Super Cub
Old 03-08-2010, 10:23 PM
Jumbo Jet's Avatar
Thanks so much. The Germs are amazing. I bought them solely on reputation, and with their price tag it was a big gamble. But once they were hooked up it took about a minute to realize why there are no bad reviews on them. They are so smooth and natural sounding, the highs are silky smooth and I can listen for hours at high volumes with no fatigue. They have 75w a piece right now from the 300/4 and they are amazingly crisp and clear. Even without a processor, the staging is front and center, live music feels like your sitting in the front row. I've never felt that before with the old Bostons. Vocals sound so alive, and at times you can hear the artist's lips as they get close to the mic.
The next project will be running them active, but for the time being, passive is quite impressive.
Honda Super Cub
Old 03-09-2010, 12:59 AM
popo2239's Avatar
"Conflict Resolution Expert"
Last Online: Today 12:49 AM
Images: 214
popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light. popo2239 is a glorious beacon of light.
popo2239's Photo Albums My eBay
Wow - That's impressive. I've been out of the car-stereo loop for about 11 years (loud bass & babies don't mix I guess!), so that makes me appreciate your install that much more.
And, although it was a really simple add-on, I like the gain-control knob mounted into the empty dash switch-plate. That's a nice touch that looks quite stock.
Nice job - points sent!
2010 Tundra CM 4x4 5.7L Pyrite Mica (Traded in my '07 DC 4.7L 4x4 SR5 - 12/29/09)
Added:
*TRDIntake *TruXedo LoPro QT Tonneau *Clazzio Seat-Covers w/aftermarket seat-heaters *Toyota NAV & AMP *Chrome door handles & Mirror Covers *3" Polished Step-Bars *305/50/20 Toyo Proxes S/T on MST 20x8.5 rims *TRD Valve-stem covers *8yr/75k Platinum Warranty
MODS/DIY's:
*Added Toyota NAV & JBL Amp (to non-JBL truck): http://www.tundrasolutions.com/forum...gation-my-non/
*Color-matched Grill-Surround: http://www.tundrasolutions.com/forum...undra-w-color/
*Added Clazzio Seat-Covers & Aftermarket Seat-Heaters: http://www.tundrasolutions.com/forum...s-aftermarket/
*Changed "Bench" seats to "Buckets": http://www.tundrasolutions.com/forum...ch-seats-into/
*Added MPG buttons: http://www.tundrasolutions.com/forum...uttons-thread/
Old 03-09-2010, 07:59 AM
Jumbo Jet's Avatar
Thank you. I love the bass knob and I'm so glad I got it. It really lets me fine tune the music, especially when listening to Sirius. As I bounce from station to station I can get the bass right where I want it in a matter of seconds without having to dig into the settings on the head unit every time.
It fits perfect right there too. I didnt take any pics of that, but I drilled out the hole in that little empty piece on the drill press so it came out clean and perfectly centered. Then the little white craft paint on the center notch really matches the white paint on the seat heaters, so it looks like it belongs there.
Honda Super Cub
Old 03-09-2010, 08:17 AM
Last Online: Yesterday 03:15 PM
BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough. BobbyD1120 will become famous soon enough.
BobbyD1120's Photo Albums
Very nice!!!!
Old 03-09-2010, 09:12 AM
jeepnuts311's Avatar
Dealer : Toyota and Scion Mall of Georgia
2008 Toyota Tundra 5.7L RCSB,
2005 Scion tC Far from stock
Last Online: Yesterday 08:43 AM
Images: 14
jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold. jeepnuts311 is a splendid one to behold.
Send a message via AIM to jeepnuts311 jeepnuts311's Photo Albums
Always have been happy with my JL.
-Tim
2008 Tundra RCSB, Slate Metallic, Sport Appearance Package
5.7L, 6 Speed, 4.10s
McGaughy's 4"/6" drop
22" Boss 331s wrapped in Nitto 305/40
Custom true duals with X-pipe, 18" Magnaflow
Black headlights, Black taillights, anytime fogs
20% tint on stock privacy glass
35w 6000k HID lows and fogs
Superflux LEDs custom installed in door handles
Homelink Auto-Dim mirror w/ compass and LED console light
Old 03-09-2010, 03:33 PM
Barney_Fife's Avatar
Senior Contributor
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Today 12:25 AM
Images: 156
Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads. Barney_Fife creates their own distinguished roads.
Barney_Fife's Photo Albums
ok. so if i ship my truck over there to you, can u make it match? how much is it gonna cost me hahahaa
awesome install....i would love to have something like that in my truck..
2007 Super White DC SR5 , TRD OffRoad, (two stage base/clear unlike OEM single stage white); Sand Beige leather seats, 4.7, tinted windows, OEM running boards, tow mirrors with chrome covers, Armorlid tonneau, billet grille, aftermarket reverse sensors, flowmaster true duals with 3.5 rolled edge stainless tips, Sirius added via OEM module, 5000K HID lowbeams, Toyo Open Country AT 275/70/18, chrome door handle covers, smoothed and painted tailgate handle, 3 inch lift/levelling kit,1.5'' Rough Country lift blocks in rear, DVD headrest player/monitors, Rostra backup camera, SS bull bar with 6'' lights, removed little "TOYOTA" from tailgate, Faux Carbon Fiber dash,console and door trim.
Old 03-09-2010, 03:44 PM
willi717's Avatar
Last Online: 03-31-2010 10:39 PM
willi717 will become famous soon enough. willi717 will become famous soon enough. willi717 will become famous soon enough. willi717 will become famous soon enough. willi717 will become famous soon enough. willi717 will become famous soon enough. willi717 will become famous soon enough.
willi717's Photo Albums
^^^no doubt, let me know when you start doing installs in oklahoma!!
Old 03-09-2010, 03:45 PM
Montanaguy's Avatar
1997 Toyota 4Runner,
Last Online: Yesterday 02:45 PM
Images: 12
Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold. Montanaguy is a splendid one to behold.
Montanaguy's Photo Albums
HA! I was actually going to ask if I could fly him out to Montana! Wow! GREAT write up/pics.
Sponsored Links
