Did you use the illumination wire when installing aftermarket HU?
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Did you use the illumination wire when installing aftermarket HU?
  1. #1
    Junior Member BAMAJAS's Avatar
    Join Date
    Jan 2003
    Location
    BIRMINGHAM
    Age
    39
    Posts
    204
    Liked
    0 times
    Rep Power
    13
    Default Did you use the illumination wire when installing aftermarket HU?
    I am going to install a kenwood dnx 6960 and wanted to know if I should hook up the illumination wire or not. I have a 2007 Tundra with JBL non nav and I can't find the correct wire. If anyone has an illustration showing thw correct wire that would be great. If I don't need to hook up the wire at all that would be even better.
    2007 5.7L Silver Sky Metallic DC/XSP Package
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jul 2007
    Location
    South Eastern, Mass.
    Posts
    183
    Liked
    1 times
    Rep Power
    282
    Default Re: Did you use the illumination wire when installing aftermarket HU?
    Just guessing, but it would be personal preference if you wanted to use the dimmer. If you can't find the correct wire via illustration, just use a DC test light to locate it.
  4. #3
    Junior Member sixfour's Avatar
    Join Date
    Feb 2008
    Location
    IE, CA
    Posts
    175
    Liked
    0 times
    Images
    17
    Rep Power
    12
    These should help...
    Attached Files Attached Files
    In Garage Currently:
    2009 DC SR5 Tundra 6" Procomp II, 18" Eagle Alloys, LineX, airbags, black leather...mine
    2004 Sequoia Limited w/22" TIS wrapped with Nitto 285/45R22 (yeah they rub)...family hauler
    2007 Prius (enough said)...wifey's
    2005? RAV4...mom's
    1995 20' Carrera jet boat powered by BBC 454...uh mine
  5. #4
    Join Date
    Jan 2003
    Location
    BIRMINGHAM
    Age
    39
    Posts
    204
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    So do I just use the pos illumination wire on the k4 plug?
  6. #5
    Join Date
    Feb 2008
    Location
    IE, CA
    Posts
    175
    Liked
    0 times
    Images
    17
    Rep Power
    12
    I would think that you would have to tap into both, but I've never tried it with an aftermarket HU...so, I'm not exactly sure. Do you have the wiring diagram with your HU? Does it only have one ILL wire? You may have to try different combinations.
    2005? RAV4...mom's
  7. #6
    Join Date
    Jan 2003
    Location
    BIRMINGHAM
    Age
    39
    Posts
    204
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Yes it only has one illumination wire. I wouldn't think u would hook the pos and neg up to that one wire would you?
  8. #7
    Join Date
    Feb 2008
    Location
    IE, CA
    Posts
    175
    Liked
    0 times
    Images
    17
    Rep Power
    12
    I couldn't give you an answer on that...here is what one guy said from a google search (maybe someone with stereo knowledge will chime in)
    "My car's factory wiring harness has two illumination wires: ILL+ and
    ILL-. My head unit's harness only has one illumination wire.
    When I connect the illumination wire from my head unit's harness to
    the ILL+ wire on my car's factory harness, the head unit's backlight
    gets _brighter_ when I dim the lights using the car's dimmer control,
    and it gets _dimmer_ when I increase the brightness.
    Should I connect the head unit's dimmer wire to the ILL- wire on my
    car's harness instead of the ILL+ wire? "
    Thanks
    "No. Find a parking light wire +12V and use that instead. You'll just
    damage the dash light circuit if you try and tie it to the radio. "
    2005? RAV4...mom's
  9. #8
    Join Date
    Feb 2008
    Location
    IE, CA
    Posts
    175
    Liked
    0 times
    Images
    17
    Rep Power
    12
    Based on the google searches I read, you'll need to be careful (which you are) and hook up the correct or you may fry something.
    2005? RAV4...mom's
  10. #9
    Join Date
    Feb 2008
    Location
    IE, CA
    Posts
    175
    Liked
    0 times
    Images
    17
    Rep Power
    12
    Here's another one (he's talking about an 03 Toyota here):
    Ok I emailed metra, since I am using the Metra TOYO-01 harness. This is what they said:
    "What you will have to do is take that wire straight to either your dash dimmer inside the car, or to one of your taillight wires as Toyota
    does not use illumination on their vehicles, they use dimmer, positive and negative. You need a wire that will show twelve DC when the lights
    are on, dimmed or not dimmed. You must use a digital multimeter when doing this as you can damage your dash light dimmer. Highly recommended to have a professional do this for you, and make sure they have insurance in case they damage the car."
    2005? RAV4...mom's
  11. #10
    Join Date
    Jan 2003
    Location
    BIRMINGHAM
    Age
    39
    Posts
    204
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Wow! Now I'm really confused.
  12. #11
    Junior Member mic_1011's Avatar
    Join Date
    Jan 2008
    Location
    yonkers, n.y.
    Posts
    175
    Liked
    0 times
    Images
    1
    Rep Power
    21
    i've been installing my own hu 's for years. don't connect it. u won't have any problems
  13. #12
    Lurking Member kickin_asphalt's Avatar
    Join Date
    Mar 2010
    Location
    North Dakota
    Posts
    41
    Liked
    0 times
    Images
    1
    Rep Power
    8
    I installed my Pioneer AVIC-Z110BT just last Thursday and used the radio harness adapters like these: Amazon.com: Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker: Electronics There is an orange illumination wire on the adapter harness that hooked up the orange illumination wire on the Pioneer harness. Everything works like it should (when I turn my headlights on the screen dims). This was also on a non JBL setup.
    2010 DC 5.7 TRD Off Road
    Goodyear DuraTrac 295/65/18
    Pioneer AVIC-Z110BT
  14. #13
    Supporter DavidT.'s Avatar
    Join Date
    Jul 2006
    Location
    NorCal
    Posts
    1,530
    Liked
    0 times
    Rep Power
    1995
    ^Did the same thing as asphalt. Connected my orange wire on HU to orange wire on metra harness. Depending on the headunit you're installing, the illumination wire is important. On mine, when you switch the lights on it turns the Navigation into nightview mode (different set of colors) so the bright colors are not so blinding.
    2007 Tundra CrewMax SR5 4x4 TRD 5.7
    |Corsa Sport Exhaust|TRD Intake|Optitrons|Eclipse DVD/GPS|Factory 20's|Rapid Hitch|Headache Rack|Delta Toolbox|
  15. #14
    Supporter asianflava's Avatar
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,716
    Liked
    14 times
    Rep Power
    4039
    I don't remember this being that difficult. Hook up a meter and find a wire that goes to 12V when you turn on the lights. I did hook mine up because the Nav screen is really bright at night.
  16. #15
    Join Date
    Jan 2003
    Location
    BIRMINGHAM
    Age
    39
    Posts
    204
    Liked
    0 times
    Rep Power
    13
    Thread Starter
    Well the difficult part is that this has the JBL system so the wire harnesses are different. To my knowledge they don't make a harness adapter that has the illumination wire for the jbl. I have searched and the only harness that is even close is the metra 70-8113 but it is missing the illum wire.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
