Question why not? 120v plug in bed
+ Reply to Thread
Results 1 to 12 of 12
Thread: why not? 120v plug in bed
  1. #1
    Junior Member citizen's Avatar
    Join Date
    Feb 2010
    Location
    new york
    Posts
    68
    Liked
    0 times
    Images
    5
    Rep Power
    8
    Default why not? 120v plug in bed
    the tacoma comes with a 120v plug in the bed of the truck, along with storage.
    Why is the tundra not given the same option???
    It's a work truck right?
    Workers plug in power tools?
    We also make cuts using the tailgate as our bench........
    So why do we not get our own 120v plug in the bed or cab
    I know I could buy my own converter and make this work, I only feel this should be a factory option. Maybe I'll buy the tacoma setup and fit it to my tundra
    2010 SALSA RED PLATINUM TUNDRA CREWMAX V8 5.7L
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Wickett's Avatar
    Join Date
    Mar 2010
    Location
    Sacramento, CA
    Age
    34
    Posts
    54
    Liked
    0 times
    Rep Power
    9
    Default Re: why not? 120v plug in bed
    I too was disappointed that there was not an option for the outlet. I came in real handy on the Taco.
    2010 Crew Max Rock Warrior
  4. #3
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,035
    Liked
    334 times
    Images
    8
    Rep Power
    41225
    It should be simple enough to do. There is a 40 amp power circuit going to the trailer plug. That is enough to power a 500 watt inverter. It does require the key to be on though.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  5. #4
    Join Date
    Feb 2007
    Location
    portland
    Posts
    315
    Liked
    14 times
    Rep Power
    98
    I run a 1500w (2250w peak) inverter and have outlets split inside and out.
    I recommend running dedicated wire to the battery and leave the OEM wiring for GPS, DVD and other low draw devices.
    Any inverter capable of running power tools will need to have enough current to supply the inverter. OEM wires are not sufficient.
    ~I also caution people on getting too small of a unit.
    ~JH
    2X World land speed record holder.
    H/MS #335/1335
    Gas, Fuel, Blown Gas, Blown Fuel
    Owner of 4 Tundras, and considering another....
    *My motorcycle makes more HP then your Tundra.
  6. #5
    Join Date
    Oct 2009
    Location
    Nunya Bizness
    Posts
    151
    Liked
    0 times
    Images
    18
    Rep Power
    17
    Do you have a how - to on this setup? This sounds interesting and may address some lighting issues I have requiring a generator.
    2007 5.7 DC 4 x 2
    Slate Metallic
    Mods: Prodigy Brake Controller see gallery for location,
    Fold down rear seat mod
    Suction Cup Holder In Place of coin holder
    Bling Lights BL 500K fog lights installed (What can I say, I was one of the lucky winners!)
  7. #6
    Join Date
    Feb 2010
    Location
    new york
    Posts
    68
    Liked
    0 times
    Images
    5
    Rep Power
    8
    Thread Starter
    a short and simple answer would be to purchase a power inverter at your local store and wire it into the truck for 120v use.
    A longer answer would be to retro fit a tacoma 120v bed plug into the tundra's bed.* this would involve wiring, cutting, and planning*
    I am be running a wire from the battery to the rear seats where I'll place an inverter nicely hidden behind a seat, from there I'll just run a short extension cord through my back window as needed for power
  8. #7
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,035
    Liked
    334 times
    Images
    8
    Rep Power
    41225
    I noticed today that one of they guys at work has the outlet in his Taco. It is a really nice looking setup.
    He says that his switches between 400 watts and 150 watts output. He thought it was 400watts if the Taco was in park and the engine was running and 150 watts at other times. Does any one know how that works??
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
  9. #8
    Junior Member dukes5.7's Avatar
    Join Date
    Oct 2008
    Location
    mobile, al
    Posts
    63
    Liked
    0 times
    Images
    15
    Rep Power
    11
    This definitely would've been nice for me. I used to be a carpenter and I carried tools and used my bed as a work bench all the time. There were plenty of times where I was on a job site with no power and had to drag out the generator for just a few cuts.
  10. #9
    Veteran Member smack's Avatar
    Join Date
    Oct 2007
    Location
    San Diego, CA
    Posts
    834
    Liked
    11 times
    Rep Power
    1302
    Someone said the entire Taco bed was plastic, no metal underneath and that the plug set up was integral, so I don't think you could adapt it.
  11. #10
    Veteran Member bilztrd's Avatar
    Join Date
    Sep 2007
    Location
    whittier ca
    Posts
    588
    Liked
    7 times
    Images
    5
    Rep Power
    1311
    The inverter(xantrex) I installed in my toy hauler recomended keeping the battery leads as short as possible(Voltage Drop). they recomended running a longer AC line if needed>
  12. #11
    Veteran Member Stripped Honda's Avatar
    Join Date
    Jul 2005
    Location
    So Cal
    Posts
    848
    Liked
    2 times
    Rep Power
    13
    Quote Originally Posted by mendonsy View Post
    that is exactly how it works .. and yeah its a shame they didnt do it for the tundras but maybe they didnt do it because we have a metal bed and the tacoma has a plastic bed
  13. #12
    Veteran Member Geordybass's Avatar
    Join Date
    Oct 2009
    Location
    Sun Valley
    Posts
    544
    Liked
    18 times
    Images
    3
    Rep Power
    237
    i think every truck needs that lol. It would be awesome that you can carry a compressor and have it hooked up to your truck in case you get a nail in a tire or got ticked and went on a finish nail rampage? jk hahaha
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
