Amount of Oil for v6
+ Reply to Thread
Results 1 to 9 of 9
Thread: Amount of Oil for v6
  1. #1
    Join Date
    Sep 2005
    Location
    home
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Amount of Oil for v6
    Hi, I have a 2009 Tundra 4.0 v6... how much oil is this suppose to take??? the owners manuel says 4.8qt with filter change... well I dumped the 5qt Mobil 1 in, and it still looks like it's 1/2 qt low, it looks to be bewteen the 2 dot's... This is the (3)rd oil change I did, and these seems to be the norm.... so I don't know weahter to go ahead and dump another 1/2 qt or what.... anyone else have this motor????
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member TucsonCrew's Avatar
    Join Date
    Jun 2007
    Location
    Tucson
    Posts
    598
    Liked
    2 times
    Images
    36
    Rep Power
    467
    Default Re: Amount of Oil for v6
    Let the engine warm up and it should be where it's supposed to.
    2007 Tundra SR5 5.7,2WD White Crewmax
    Toytec 3 Inch lift,18 Monster wheels
    Firestone airbags with compressor
    295/70/18 Tires,Step Rails,Dash Mat
    Bed Extender,Carbon Fiber Dash Kit
    Clazzio seat covers, TRD Sway Bar
  4. #3
    Join Date
    Jun 2007
    Location
    Deep South
    Posts
    1,902
    Liked
    2 times
    Rep Power
    4062
    Quote Originally Posted by the_wraith View Post
    I have the V6 in my Tacoma and it takes about 5.5 quarts to top dot mark on the dip stick.
    SOS
    "Life can only be understood backwards ... but it must be lived forwards" ...... Soren Kierkegaard
    If you or a friend is or has been in the US Military ... make sure ALL important info. (injuries & medical treatments) is documented in the medical records ... and keep those records (forever) in case of a DoD or DVA claim.
  5. #4
    Join Date
    Sep 2005
    Location
    home
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by TucsonCrew View Post
    I did, and it wasn't..
  6. #5
    Join Date
    Sep 2008
    Location
    nashua nh
    Posts
    352
    Liked
    0 times
    Rep Power
    22
    almost 6.. i put in 5.8 qts according to my oil gun..
  7. #6
    Join Date
    Jun 2007
    Location
    Tucson
    Posts
    598
    Liked
    2 times
    Images
    36
    Rep Power
    467
    Does that engine have a normal oil filter or does it have the one like the 5.7? If you have a normal filter maybe Toyota takes in to account they want the oil filter pre filled before you fill the engine with oil. That may be where the extra oil is needed. I don't think the filter holds a 1/2 quart, but maybe a 1/4 quart.
  8. #7
    Join Date
    Sep 2005
    Location
    home
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    I'm not sure how a 5.7 filter is, on my v6 the filter is on top of the motor...front drivers side.
  9. #8
    Veteran Member StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Age
    100
    Posts
    1,104
    Liked
    148 times
    Rep Power
    11015
    As long as you have the correct dipstick, the proper amount of oil is the amount it takes to reach the full line (or mark) with the engine at operating temperature.
    The manual will be close, but cannot account for manufacturing tolerances, or oil that pools in the galleries, heads, etc.
    Some newer engines have a slow draindown, so when you shut off the engine to check the level, wait a minute or so before you check it.
    Steve
  10. #9
    Join Date
    Sep 2005
    Location
    home
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by StevJ View Post
    Steve
    Yeah, I waited a good 15-20min, plus before I changed the oil I checked it and it was the same... so it looks like I need to put in another 1/2qt... to make it a total 5.5qt.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
