DIY How to: Turn your "Bench-Seats" into "Buckets"
+ Reply to Thread
Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
Thread: How to: Turn your "Bench-Seats" into "Buckets"
  1. #1
    The M.F.I.C. PoPo's Avatar
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Default How to: Turn your "Bench-Seats" into "Buckets"
    This thread will show you how I removed the front center "bench" seat from my CrewMax, and added the floor-console instead to now have "bucket" seats. This is how I did it - I'm not responsible if you try this and damage anything
    Okay, long-story-short, I had the Buckets in my '07. When I was looking to upgrade to the 2010, I thought I'd give the Bench-seats a try. Well, after 7 months, I missed my floor-console so much that I finally decided to take on this MOD. Personally, I like the Gear-shifter up on the Column MUCH better than the floor, so this worked out perfectly for me, and allowed an additional spot for storage. (It may be possible for you to move the shifter from the column and down to the console, but I didn't want to, didn't look into it, and don't know anything about it so don't ask me how!!!).
    First thing you'll need is the floor-console itself. I found mine on ebay, through seller "LKQonline" - I was unable to find a Tundra console (used) so I had to settle for an '08 Sequoia console. Typically you can find these for approx $210 with shipping, although he had one with a "Make Offer" listing, and I ended up getting it for around $150 total. These include the silver "bezel" that goes curves up to the gauge-cluster, and also includes "Compartment Type-B" which has the tow-haul switch. I'm probably going to swap in "Compartment Type-A" later, which is just a big, empty compartment found on trucks without the tow-package, since my "tow-haul" button is up on the column-shifter.
    Anyhow, the fit is perfect, although if you're installing this into a Crewmax (like I did) you'll have to make a compromise and do either 1 of 2 things:
    1) Lose the rear-vents for the back-seat passengers (I'll get into why later)... OR
    2) Spend approx $300 extra on the following parts: Tundra Rear-Panel, Tundra Air-Duct, Tundra Air-Vents (2).
    (The parts can be found through Partznet.com; in fact, the entire console can be found there new, but the price tag is astronomical so it's best to do it this way.)
    Here's the issue: Our trucks have a plastic "tube" that sits under the carpeting, providing air to the rear-seat vents. I'm assuming that the Sequoia has roof-vents for the rear or something, because their console doesn't have vents; it has "controls" for their climate zone. The INTERIOR of the Console is built the same for all trucks, and has passages built-in for the vents, but the "tube" is shaped differently for Bench/Bucket setups, and the rear-panel and vents would have to be swapped into the Sequoia console.
    I chose option 1, since those rear-vents weren't very powerful anyhow, and I can always add them later if I want. Yes, I left the "controls" and the rest of the Sequoia rear-panel on the console, which also includes a bottom "pull-out" cup holder similar to the Double Cab console. The only people that usually sit back there are my kids, and they won't care if there's buttons there that don't work... they'll probably like it instead!
    You'll also have to purchase the "Finish Panel" which sits below the the Climate Controls on the dash - it contains a small middle pocket, a lighter, and a 12v outlet. This "panel" replaces the pull-out Cup-Holders that were in the dash if you have bench-seats. This piece doesn't come with the Console, and can be found at Partznet for around $57 plus shipping. It's under "Instrument Panel / Instrument Panel Components / Finish Panel (black or brown).
    Removal: (always unplug the 12- terminal of your battery b4 working )
    Step 1: Remove the front seats (4 bolts [14mm] each, and unplug the wiring harnesses).
    Step 2: Remove the center seat/console. There are 2 more 14mm bolts on the sides, as well as some Torx bit bolts/screws in the inside/bottom that have to be removed. Don't forget to unplug the harness for the 12v outlet. Pull it out & set it aside.
    Step 3: Remove the bottom valance/trim piece under the center console - just 2 plastic phillips screws.
    Step 4: Remove the Cup-Holders - I think it's 2-screws & a bolt.
    Step 5: Remove the Silver trim-piece that contains the ash-tray, 12v & cig outlet - I think it's 2 more screws... You'll have to unplug the cig & 12v harnesses. (By the way, most of these interior bolts are 10mm.)
    Step 6: Remove the Driv & Pass side Kick-Panels AND the bottom plastic "door-sils" on each side.
    Step 7: Remove the front-half carpet insert - It "pops" into the plastic clips on the sides (door sils) and also has some velcro at the very front on each side.
    Okay, now you've exposed the floor area and all the vent tubes & wiring. You'll notice that the vent-tube is a long, flat tube that comes out from under the center of the dash. This will pull out easily from the front duct --- I think there were some plastic tabs holding it in but they pop out easily.
    Once you pull this out, you either have to re-install the new Tundra-specific console tube, or just close it off like I did. I used a Door & Window sealant tape that has a tar-like adhesive, and is about 4" wide. This stuff is very pliable, and seals like glue. I'm sure duct-tape would work fine, but this stuff is better... just make sure you seal off that duct so you don't lose any airflow.
    Okay, I took this opportunity to re-wire my aftermarket seat-heaters. From the pics, you can see I gave-up on using the OEM Seat-heater switches for my aftermarket heaters. I tried several different wiring methods, but it just won't work. Instead, drilled into 2 of my blank switches and installed the aftermarket switches there; truth is, they look pretty good. My wife thinks they look stock... they're close enough. As with anything, make sure you center them properly; the finish is key! They wire-up easily, just hook up a 12v source, a ground, and the harnesses are idiot-proof.
    To deal with the empty space where the floor-shifter was, I made a 4x6 (4"deep) pocket to fit the spot. In retrospect, the fit ended up being way too tight (measured the top piece, but not the console itself. I used 3/8" plywood... if I was doing it again, I'd try 1/4, and only make it 2" deep... even still it may be tight. I had to cut some of the plastic supports & framing of the console base to make it fit, but now that it's all put-together it looks fine. I carpeted it too and it looks stock.
    Remove the silver piece from the rest of the console - just plastic pins locking it in. Turn it upside down and you'll see a bunch of plastic tabs that hold the center-trim piece (lines the hole around where the shifter would be) onto the main section. You'll have to break them off to remove the trim piece. Then cut/sand them down so they're flush with the holes they insert into --- basically, to attach my storage-pocket to the silver piece, I did the following: Using a brad-nailer and 3/4" nails, I glued & nailed the center-trim insert to the pocket. I then re-inserted the center piece (attached to the pocket now) and glued that to the bottom of the main piece. I forgot to take more pics during this process, as I was brainstorming different ways to do it, so I'm sorry if my description is confusing at all.
    WIRING CONCERNS:
    Since the front 12v plug & cig lighter are being moved to the right (the "Finish Panel") you'll have to extend the wires and move the plugs themselves into the new finish panel. Removing the plugs is a PAIN IN THE A$$... Basically, trial-and-error and some cussing will get them out of the old trim piece. You'll figure it out. I extended the left one about 4-5" and the right plut about 8"so it would reach the new panel.
    You'll also have to cut the wiring harness that went under the carpet to the center seat... in my truck, it only had 2 wires; presumably a 12v+ & a Ground for the power-outlet on the back of the center seat. Cut it right at the harness and it'll be long enough to reach the wires in the new console. Basically, you'll just have to isolate the 2 wires for the 12v plugs in the console... there's one inside the console, and one at the rear. (The console has a bunch of wires for the rear climate-control, and also the little light by the cup-holders --- I just ignored those wires and concentrated only on the 12v plugs). Connect the wires and you'll have those plugs working.
    Re-Install:
    Put the carpet back in, followed by the kick-panels and the door-sils. If you removed the silver-trim piece to make a pocket, install that back into the console before you put the console in the truck. There are 4 bolts that hold the interior/bottom of the console to the truck frame (oh yeah, you may have to cut little holes into the carpet to expose the 4 bolt holes --- you'll see where they go). Connect the wiring to the 12v wires for the plugs in the console. After you attach the console, install the "finish-panel" and connect the wires you extended to the 12v plug & cig plug. Put the top pieces back on the console & put the seats back in.... That's it!
    I'm sure there are many different ways to make use of the existing hole where the shifter would be... Personally, I like pocket & storage space, so the 4x6 pocket worked best for me. Later on I may add the ventilation pieces for the rear, but in truth I may not even need it. Those rear-vents weren't that strong to begin with, and there are still the rear floor-vents under the driv & pass seats to bring air/heat back there.
    I'm also planning on addressing the color-difference between the '08 silver panel & the '10 darker silver panel... I've been wanting to add the woodgrain applique around the gauges (like Barney's Carbon Fiber pieces) -- so this will finally give me a good excuse to buy it.
    Oh - One thing I noticed about the Sequoia console compared to the Tundra... It has a stitched "leather" arm rest, compared to the 1-pc vinyl arm rest from the Tundra console... It matches the look of my Clazzio's nicely
    ~PoPo
    2004 Sequoia 4.7L 4x4
    275/65/17 Hankook I-Pike RW11, Brush guard, 27w LED Aux lights, Ebay Nav, Husky Liners
    Also have 2008 Prius, 2006 Honda Cr-V
    Previous: 2010 Tundra CM 4x4 & 2007 Tundra DC 4x4
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member peteyp5.7's Avatar
    Join Date
    Mar 2010
    Location
    JERSEY
    Posts
    823
    Liked
    1 times
    Images
    1
    Rep Power
    715
    Default Re: How to: Turn your "Bench-Seats" into "Buckets"
    Amazing write up , great mod pop.
    More Power!!!!!
    5.7 Limited Tundra Silver Sky Metallic, 35% tint front windows facotry on the rest, Yellow 42w foglights, Black headlight mod, Volant cold air, Magnaflow Exhaust, Oem skid plate, Debaged, 4in stub antenna, 6/8 Lowered Peaced Together Kit, Belltech Shock and Strust, TRD Front Lowering Springs, TRD Leaf Pack, Flip Kit, Shaved tailgate handle, Auto TailGate off of the Key Fob, CW Roll pan, Upgraded sub to MTX, Added Poinner Amp 200x1RMS
  4. #3
    Supercharged Member dogstate's Avatar
    Join Date
    Apr 2007
    Location
    Kansas
    Posts
    4,487
    Liked
    31 times
    Images
    3
    Rep Power
    18324
    Nicely done and great writeup!
    When you pulled out the seats, would you say it would be worth it to clean 'em and such while they're out? I don't really see much benefit to doing this, unless you were cleaning underneath the seat... I guess i have an urge to pull my seats. Other than the squeaking that is constantly coming from them, I have no other reason.
    -rockstate
  5. #4
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    ^^ Well, mine are only 7 months old, plus I had them out a few months ago to install the Clazzio's, so I didn't need to clean them. Maybe yours could use a good cleaning tho?
  6. #5
    Mark it eight, Dude... MaylonTRD's Avatar
    Join Date
    Oct 2007
    Location
    Shreveport,LA
    Posts
    4,373
    Liked
    125 times
    Images
    35
    Rep Power
    86844
    Another good write up. Points sent
    2014 4Runner Limited Blizzard Pearl- Wife's
    2014 Tundra CM SR5 5.7l TSS Edition Magnetic Gray ProComp 6", XD809 18x9 -12 offset, trail grappler 35x12.50
    2007 Tundra CM SR5 5.7 2WD TRD Slate SOLD
    Skyjacker 6" lift, BFG KO 305/65R18 (33.7"x12.2") XD Hoss Chrome 18x9 +30 offset, Go Rhino Dominator II Nerf Bars, Debadged, AFE Pro Dry Drop-in Craven Speed Stubby Antenna, HomeLink Rear View Mirror, Ranch Hand Grille Guard, Custom Spintech Muffler, Pioneer head unit, RF shallow mount sub, Hypertech Speedo Calibrator
  7. #6
    Veteran Member JMSinMD's Avatar
    Join Date
    Aug 2006
    Location
    Maryland
    Posts
    1,780
    Liked
    41 times
    Rep Power
    3025
    Very nice, I was actually thinking about doing the opposite and adding a bench to the front and middle row of my Sequoia (Platinum only has seating for 2 in middle row). With all 3 rows I'd have seating for 9 but the logistics of moving the shifter to the steering column seems like it would get expensive.
    2008 Sequoia Platinum (8 passenger) 4x4 5.7 V8; Debadged/5% tint over factory rear with 15% front/LED rear foglights/White Knight RLS/V-LEDs LPF/Silverstar Ultra/Lexus LS460 bi-xenon HID projectors with 5000k Osram CBI/Philips DRL8/Lockpic navigation override/Locking gas cap/TRD intake flow accelerator/K&N panel filter/K&N filter minder/5000k LED license plate bulbs/Big Daddy horns/SET exhaust tip/Factory color matched (B&I SEQUOIA emblem insert, brake calipers, side-view mirrors, b-pillars, c-pillars)/summer 22 Giovanna Caracas w/Yokohama Parada 305/45/22/winter 18" OEM steel wheels powder-coated black w/Bridgestone Dueler A/T "Revo 2" 255/70/18
  8. #7
    Junior Member VooDooDan's Avatar
    Join Date
    Jun 2005
    Location
    Bay Area
    Age
    29
    Posts
    397
    Liked
    0 times
    Images
    64
    Rep Power
    746
    Very Nice DIY. Great job!
    2008 Tundra 5.7 4x4 LTD Silver w/Navi, XM, & Memory
    TRD Rear sway bar, VLED Cab lights, Longo LED Tail lights, Recon LED CCL's
    GTek DSP, Custom LEDs for rear seats, LED Puddle lamps, Duplicolor Bed Armor
    Toyota Painted Fender flares, Painted Door Handles w/LED's
    Magnaflow Dual CAT Back, AFE Cold Air, Bilstein 5100 front/back
    Procomp 8128 18in w/285 65 18 BFG AT/KO, Front & Rear Weathertechs
    More Photos
    DIY: LED's in out Side Door handles("BMW Style" with a twist)
    DIY: LED Puddle Lamps for LTD Tundra
  9. #8
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,111
    Liked
    345 times
    Images
    8
    Rep Power
    42560
    I like it and that's a great writeup!!
    Sure a lot of work though!
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  10. #9
    Meep Meep! ThirdHorseman's Avatar
    Join Date
    Jun 2007
    Location
    LaLaLand
    Age
    34
    Posts
    5,232
    Liked
    40 times
    Images
    14
    Rep Power
    27182
    Looks great!
    Much easier than the Ford I did (required custom fab to match up to the dash) and much more OEM I still recommend perhaps painting the lower cubbyhole silver. I think the uncovered areas of the 4x4 switch and HVAC knob are going to be obviously different compared to that cubby (gray vs. silver) because they are so close in proximity. But I am very particular and want everything to look relatively stock, so if you don't mind, cest la vie!
    The stitched armrest cover comes in the Limited and Platinum Sequoias. I've been looking for one for my Tundra, but do not want to buy the entire console to get it.
    Some euro stuff...
  11. #10
    Junior Member rich_4's Avatar
    Join Date
    Feb 2009
    Location
    Davidson, NC
    Posts
    167
    Liked
    0 times
    Rep Power
    9
    great job. I wanted the bucket seats but had to settle for the bench, I might try this when I have some extra time.
    "Skin grows back - paint doesn't" - Chip Foose
    09 Tundra. 5.7 DC 4x4. True Duals - Powersticks. Red Out Tow Mirrors.
    07 FJ Cruiser. 6 Lifted. 35's. Winch Bumper. One of a kind. Sold.
    06 IS350. Slammed. Eibach. Greddy. Fujita. ACE. Sold.
  12. #11
    Junior Member knepp1bj's Avatar
    Join Date
    Dec 2009
    Location
    Michigan
    Posts
    133
    Liked
    0 times
    Rep Power
    25
    Popo. just a curious question, when you were buying ur crew max didnt you want the bench in the front for more storage reasons? I thought i rememberd reading that b4 and you were having a hard time finding a crew max with a bench seat in the front...
    if yes just curious why you switched?
    I have the buckets and love them
    2010 Crew Max, Radiant Red, Grey Leather, 5.7L
  13. #12
    Join Date
    Dec 2009
    Location
    Michigan
    Posts
    133
    Liked
    0 times
    Rep Power
    25
    oh nvm i didnt read the first part, just skimmed it...sorry
  14. #13
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    Quote Originally Posted by ThirdHorseman View Post
    ... I still recommend perhaps painting the lower cubbyhole silver. I think the uncovered areas of the 4x4 switch and HVAC knob are going to be obviously different compared to that cubby (gray vs. silver) because they are so close in proximity.....
    Yeah, that's why I'm planning on swapping the compartments, from Compartment Type-B (with the switches) to Compartment Type-A, which is all black & to my knowledge doesn't have any silver on it... besides, if it does I can just order a 2010 M.Y. Compartment and it should be the right color.
  15. #14
    Join Date
    Jun 2007
    Location
    LaLaLand
    Age
    34
    Posts
    5,232
    Liked
    40 times
    Images
    14
    Rep Power
    27182
    Sounds great! I like those appliques, can't wait to see the final product
    Some euro stuff...
  16. #15
    Join Date
    May 2009
    Location
    USA
    Posts
    63
    Liked
    0 times
    Images
    1
    Rep Power
    7
    Was this uneventful? Did anything break?
    2009 DC 4x4 5.7L
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
