Aluminum Oil Filter Cap - durabilty
+ Reply to Thread
Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 70
Like Tree15Likes
Thread: Aluminum Oil Filter Cap - durabilty
  1. #1
    Preferred Dealer Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes.
    Join Date
    Jan 2008
    Location
    North Adams, Massachusetts
    Posts
    1,167
    Liked
    54 times
    Images
    10
    Rep Power
    4925
    Default Aluminum Oil Filter Cap - durabilty
    As many know, the plastic cap on the oil filter housing leaves something to be desired. While trying to remove the cap, the wrench can slip or frequently becomes stuck , and after enough oil R&R sessions, it can eventually round the cap off. I also expect that after a few more years and many more heat cycles, we'll be seeing plenty of warped or cracked pieces, too. When this happens, one can go to the dealer and buy another at a retail price of over $60. Or for about half that price, one can pick up the aluminum version from a Venza 3.5 V6.
    Only one modification is required to fit the Venza piece up, and that is swapping of the Tundra internal perforated oil filter support tube into the Venza Cap. To peform this swap is easy. To remove the tube, the two small retaining tabs need to be bent up to near vertical. Then push down on the tube, turn it about 45 degrees, and it will push up and out. It has some spring tension on it. A spring and the drain valve disc are located under it. Be careful not to lose them. Remove the Tundra tube in the same manner, install it in the Venza Cap and bend the tabs back flat.
    Here are the caps and internal parts...
    This picture shows how to use a flat blade screwdriver to bend the tabs up. The metal is thin, just a gentle twist on the screwdriver handle will bend the tab to where it is in the picture.
    I have a few of these in stock and can match dealer retail on the price. Or if you want to keep your business local, or find yourself in a jam and need one quickly, the part number is 15620-31060.
    We are working on few ore trick with this part, so stay tuned.
    My little message to Toyota... I've buying and beating on your trucks since the 80's... They are purchased for their extreme durability, smart designs, and easy servicabilty. I don't buy them for built to fail plastic oil filter caps that cost twice as much as the lifetime alloy part that comes on some of your other vehicles. Pull your head out of your nether region and realize how you got to where you are.
    Brian
    Jowett HD Tundra Parts
    Driving the Tundra aftermarket forward.
    ARB 10.5" Locking Differentials now Available!
    "The person who says it cannot be done should not interrupt the person doing it."
    brian@jowettengineering.com
    www.jowettengineering.com
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax is more than famous, they're infamous. 08SalsaMax's Avatar
    Join Date
    Aug 2008
    Location
    Paradise Island
    Posts
    1,443
    Liked
    1 times
    Images
    44
    Rep Power
    2510
    Default Re: Aluminum Oil Filter Cap - durabilty
    Great mod --- but I gotta ask. Will this mod work with the 5.7L V8? THanks....
    2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
    Wheels and tires
    Engine
    Oil filter
    Windows
    Air filter
    Air conditioning
    Seats
    Send POINTS, not thanks or compliments....
  4. #3
    Join Date
    Jan 2008
    Location
    Posts
    1,167
    Liked
    54 times
    Images
    10
    Rep Power
    4925
    Thread Starter
    Yes. This was done to my 5.7L. It should also work on the 4.6L, but that needs to be verified.
    Brian
  5. #4
    Supporter RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation. RichR would rather be driving his reputation.
    Join Date
    Feb 2002
    Location
    Chicago, IL
    Age
    51
    Posts
    819
    Liked
    0 times
    Rep Power
    551
    Brian,
    Gotta to agree on Toyotas bass ackward ness latley!
    Putting a more durable piece on a car instead of a truck.
    Very nice mod.
    I got to hate oil change time.
    You gotta do the stock skid plate trap door next.
    Former Dodge Boy
    Now a Toyota Man
    Proud to be doing
    Life@TS
  6. #5
    Supporter cwit has disabled reputation cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,332
    Liked
    8 times
    Images
    3
    Rep Power
    912
    Isn't Toyota doing this on a lot of parts. Not just this one.
    Charlie & Linda
  7. #6
    Supercharged Member socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy wants you off his porch. socal57chevy's Avatar
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    113 times
    Images
    20
    Rep Power
    180067
    Thanks for posting the info, Brian. You're a real trooper for the cause.
  8. #7
    Veteran Member Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84 wants you off his porch. Vettelover84's Avatar
    Join Date
    Jul 2010
    Location
    SomewhereBetweenHereandThere
    Age
    28
    Posts
    1,290
    Liked
    72 times
    Rep Power
    27889
    very nice!!! and now I know about this trap door modd too...
    2010 Tundra CrewMax 5.7L V8 4x2--- Mostly Stock
    4.5/5 Drop-- TexasRanger96 Electric Fan Kit
  9. #8
    Benny Hill guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech wants you off his porch. guntech's Avatar
    Join Date
    Jul 2007
    Location
    Stone Ridge, NY
    Age
    62
    Posts
    17,413
    Liked
    802 times
    Images
    81
    Rep Power
    174523
    Quote Originally Posted by Jowett Engineering View Post
    I agree. I buy Toyotas because of their reliability and durability. I sure hope they don't continue in the direction they are going.
  10. #9
    Veteran Member keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb is a pinnacle in their own mind. keninsb's Avatar
    Join Date
    Oct 2002
    Location
    Santa Barbara, CA
    Age
    48
    Posts
    1,015
    Liked
    10 times
    Images
    39
    Rep Power
    1358
    Brian, EXCELLENT post and great pics. I did not realize that the oil filter cap was plastic. Amazing. If you have any more of those aluminum caps let me know, I am definitely interested.
    You and GunTech are right, Toyota has been cutting some serious corners. I have owned Toyotas since the "80s and cannot believe some of the short cuts they are taking. I am noticing huge differences in parts quality from my '02 Tundra. Things like the plastic intake manifold (and manifold cover), and they no longer use screws to secure the scuff plates, they use plastic clips that tend to break. The interior assist handles used to be held on with sturdy 10mm bolts, now they use these cheasy clips that are not nearly as strong. I could go on and on. I hope Toyota pulls their head out and goes back to making vehicle (and parts) to last. I'll climb off my soapbox now.
    But seriously, GREAT write up.
    Ken
    To many mods to list...
  11. #10
    Junior Member filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef has done just about everything...and then some. filetobeef's Avatar
    Join Date
    May 2010
    Location
    usa
    Posts
    122
    Liked
    1 times
    Rep Power
    915
    great info.
    thanks.
  12. #11
    Junior Member wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen is a name known to all. wintergreen's Avatar
    Join Date
    Sep 2007
    Location
    Manassas, VA
    Posts
    160
    Liked
    1 times
    Images
    9
    Rep Power
    366
    Brian,
    Excellent suggestion, points sent!
    Part number 15620-31060 is also used in a 2010 Lexus RX350 and is available for around $26 from URL:
    15620-31060 - Lexus CAP ASSY, OIL FILTER
    2007 Tundra DC 5.7L 4x4 Limited, Timberland Mica, 20" Wheels, NAV, Bed Liner, Run Boards, aFe CAI, Borla Dual-Side Exhaust Craftec Tonneau Cover, Dawn Enterprises Lower Body Side Molding
  13. #12
    Junior Member PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all. PPosey is a name known to all.
    Join Date
    May 2008
    Location
    Bryson City NC
    Posts
    339
    Liked
    2 times
    Rep Power
    357
    very nice, I hate the plastic housing, after my last dealor oil change I can't get the drain plug out anyway they really jamed it in there,,,,
    2008 Tundra CrewMax SR5, Silver Sky 5.7 and 4x4
  14. #13
    Veteran Member StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ is almost part of the TundraSolutions family. StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Posts
    892
    Liked
    84 times
    Rep Power
    6935
    Might you be whittling on one, and replacing the perforated center tube with a solid one, to adapt a remote spin-on oil filter? he asked, hopefully.
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  15. #14
    Junior Member imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox is a splendid one to behold. imtfox's Avatar
    Join Date
    Oct 2009
    Location
    Omaha
    Posts
    372
    Liked
    0 times
    Rep Power
    17
    Quote Originally Posted by StevJ View Post
    Might you be whittling on one, and replacing the perforated center tube with a solid one, to adapt a remote spin-on filter? he asked, hopefully.
    That's what I'm looking for... I have a machinist friend who is all of the sudden too busy to look at my project... damn economy picking up!!!
  16. #15
    Join Date
    May 2008
    Location
    Bryson City NC
    Posts
    339
    Liked
    2 times
    Rep Power
    357
    That would be nice!!!!!!!!!!!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
