Question Accelerator Sensitivity
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Thread: Accelerator Sensitivity
  1. #1
    Rookie boozinbuzz's Avatar
    Join Date
    Sep 2010
    Location
    Marietta, GA
    Posts
    10
    Liked
    2 times
    Rep Power
    0
    Default Accelerator Sensitivity
    Hi y'all, new to the board here and have a quick question. I recently purchased my second truck, an '07 Tundra Limited w/ the 5.7L. My first truck was a Tacoma that gave me a trouble-free 224k miles so I love all things Toyota Truck related. So far the Tundra has been great but I do have one concern.
    The accelerator seems to be super sensitive. Just the slightest touch to it and the engine will take off. Its not just me, when my wife and friend first drove it they had the same problem too. I have been able to get used to it but every once in a while my foot will slip and send the truck lurching again.
    Is there anyway to tune this down a little? There is plenty of travel available in the gas pedal, I don't think I have even come close to flooring it. I would like to make it a little less aggressive.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member filetobeef's Avatar
    Join Date
    May 2010
    Location
    usa
    Posts
    143
    Liked
    3 times
    Rep Power
    918
    Default Re: Accelerator Sensitivity
    true.throttle tip in is very sensitive on these trucks and there are no provisions to change that unfortunately.
  4. #3
    Veteran Member Wacked's Avatar
    Join Date
    Apr 2007
    Location
    Richmond, TX
    Age
    49
    Posts
    1,658
    Liked
    68 times
    Images
    23
    Rep Power
    137874
    You may want to check the history on the truck and see when or if the recall on the gas pedal was done. There was the first fix that involved the installation of a shim which sometimes left the pedal very touchy, then there were two revisions to the pedal itself that addressed that issue. The part number for the latest revision should end with a C, I don't have the exact part number but a search will turn up plenty of threads on the issue and there are a few that have the part numbers.
    2007 Salsa Red Limited Crewmax
    Nav, Sonar, 20" Carved Wheels
    Born in TEXAS Built by TEXANS
    aFe Stage II Pro-S Dry Si
    Corsa Sport Single Cat Back Exhaust
  5. #4
    Junior Member diveriter's Avatar
    Join Date
    Sep 2007
    Location
    Jacksonville, Fl.
    Posts
    181
    Liked
    3 times
    Images
    24
    Rep Power
    26
    My '07 I traded in last month was that was after having the 'pedal' issue resolved. I had been driving it for 2.5 years prior to that and if you even BREATHED on it... you were off to the races. If I would try to say make a u-turn... or pull out into traffic, it would chug like I wasn't giving it any gas. So I'd put it to the floor almost to get it to stop chugging along.
    David
    2010 Super White DCAB 5.7 4x4, Pro Comp 6" Stage 1, Pro Comp 7047 18x9 flat black, Toyo Open Country M/T 35x12.5, Hypertech speedo adjust, Undercover bed cover, AVS vents, Hood shield, Amp Bed Step, Westin step bars, Tint 5% Front, 15% back, 70% WS with 5% strip, Avic-Z2 with BT, XM, iPod, Back up, Infinity Kapa fr and rr doors, Infinity Reference 10" subs, Inifinty 4ch and sub amp, Viper with remote start.
  6. #5
    Benny Hill guntech's Avatar
    Join Date
    Jul 2007
    Location
    Stone Ridge, NY
    Age
    65
    Posts
    17,369
    Liked
    808 times
    Images
    81
    Rep Power
    177988
    Quote Originally Posted by Wacked View Post
    I'm willing to bet you this is the case. After they did the recal work on mine (shim), the gas pedal was VERY, VERY touchy. I actually felt it was dangerous in some instances. They put the new gas pedal assembly in and I was good to go. I would check into this, you will NOT believe the difference !
  7. #6
    Supercharged Member dogstate's Avatar
    Join Date
    Apr 2007
    Location
    Kansas
    Posts
    4,487
    Liked
    31 times
    Images
    3
    Rep Power
    18324
    These pedals are touchy from the factory and I hear the shim only made it worse (i.e. the people above).
    The worst is coming from a 4 way stop sign on a rough road. It'll jerk you all around.
    The best thing I've found to remedy the touchy pedal is this..
    HEAVIER TIRES! worked like a charm but after 40K miles of the heavy tires, it still feels sensitive. I can only imagine what it feels like stock again.
    -rockstate
  8. #7
    Mark it eight, Dude... MaylonTRD's Avatar
    Join Date
    Oct 2007
    Location
    Shreveport,LA
    Posts
    4,373
    Liked
    125 times
    Images
    35
    Rep Power
    86844
    Another vote for this ^^
    2014 4Runner Limited Blizzard Pearl- Wife's
    2014 Tundra CM SR5 5.7l TSS Edition Magnetic Gray ProComp 6", XD809 18x9 -12 offset, trail grappler 35x12.50
    2007 Tundra CM SR5 5.7 2WD TRD Slate SOLD
    Skyjacker 6" lift, BFG KO 305/65R18 (33.7"x12.2") XD Hoss Chrome 18x9 +30 offset, Go Rhino Dominator II Nerf Bars, Debadged, AFE Pro Dry Drop-in Craven Speed Stubby Antenna, HomeLink Rear View Mirror, Ranch Hand Grille Guard, Custom Spintech Muffler, Pioneer head unit, RF shallow mount sub, Hypertech Speedo Calibrator
  9. #8
    Join Date
    Mar 2007
    Location
    Richmond, VA
    Posts
    144
    Liked
    0 times
    Rep Power
    42
    Snap a picture of the accelerator and post it. That way someone here can tell you whether it got the trim and shim fix of the old pedal assembly, or if it already has a new pedal assembly. Basically the pedal will seem a bit touchy if it's an original '07 or the new pedal assembly, but it's bearable. If it's been shimmed, there's a good chance it will feel slightly ridiculous.
    07 Bluestreak Tundra DC SR5 TRD+LineX+Retrax
    ITA Integra racecar
    02 Subaru WRX daily driver
  10. #9
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    Ironically I find the Gen 1 throttle response to be more aggressive than the 5.7.
    Attention environmentalists, reduce emissions from this:
  11. #10
    Join Date
    Sep 2007
    Location
    E. Hampstead, NH
    Posts
    652
    Liked
    3 times
    Rep Power
    1059
    Try these links:
    NEW pedal tomorrow
    New pedal owners and sport pedals
    Pedal Replaced WOW! What a difference!
    The new, revised pedal assembly is model or p/n: 440C
  12. #11
    Join Date
    Sep 2010
    Location
    Marietta, GA
    Posts
    10
    Liked
    2 times
    Rep Power
    0
    Thread Starter
    I went digging through the paperwork and found this invoice from the original owners dealership. I cant figure out which part numbers mean which. Do I still need to go in to have the latest version installed?Click image for larger version.
  13. #12
    Join Date
    Sep 2007
    Location
    E. Hampstead, NH
    Posts
    652
    Liked
    3 times
    Rep Power
    1059
    Quote Originally Posted by boozinbuzz View Post
    I would just go into the dealership, tell them about the pedal sensitivity, tell them you feel unsafe with it the way it is and see what they advise...
    If it doesn't have the 440C pedal assy upgrade, ask them to install it...
    Brad
  14. #13
    Join Date
    Sep 2007
    Location
    E. Hampstead, NH
    Posts
    652
    Liked
    3 times
    Rep Power
    1059
    I didn't see anything regarding the pedal upgrade on your invoice...
  15. #14
    Supercharged Member Jumbo Jet's Avatar
    Join Date
    Mar 2007
    Location
    Florida
    Posts
    2,966
    Liked
    29 times
    Rep Power
    6708
    I had/have the same problem even after the 440C upgrade pedal. Mine lurches forward too, its so hard to find it's sweet spot. I had the shim done first, then still no luck so they switched out to the newer pedal and it still lurches. I drove around with my service tech and showed him, but he said it's normal for the Tunrda's, they all do it.... I still dont buy that excuse. He drove it as well and it didnt hop around on him, but he drove it a little old lady. Still bugs me, but thats my only complaint in 3 years, so I get by.
    2007 Tundra Limited DoubleCab 5.7, Silver Sky, TRD
    Honda Super Cub
  16. #15
    Junior Member imtfox's Avatar
    Join Date
    Oct 2009
    Location
    Omaha
    Posts
    374
    Liked
    0 times
    Rep Power
    19
    that is the shim "fix"... you need to go to the dealer and complain and get a new pedal
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
