4.6/5.7 aftermarket exhaust ?
+ Reply to Thread
Results 1 to 10 of 10
Thread: 4.6/5.7 aftermarket exhaust ?
  1. #1
    Rookie buzz wrecker's Avatar
    Join Date
    Nov 2010
    Location
    Newport News, VA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default 4.6/5.7 aftermarket exhaust ?
    Ok, so since the 4.6 is basically a destroked 5.7 to the best of my knowledge, should an aftermarket exhaust for a 2010 5.7 also fit a 2010 4.6? If I search for an exhaust for my 4.6, the pickings are mighty slim but there are a lot more options for the 5.7. The only thing that may be different in my mind may be the pipe diameter, but pipe/hanger placement should be the same. Please correct me if I'm wrong, and thanks in advance for the help!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jan 2011
    Location
    Beaumont
    Posts
    30
    Liked
    0 times
    Rep Power
    32
    Default Re: 4.6/5.7 aftermarket exhaust ?
    bump. as I'm curious of this as well!
  4. #3
    Supercharged Member RONE's Avatar
    Join Date
    May 2007
    Location
    Merriam, KS
    Posts
    2,533
    Liked
    53 times
    Rep Power
    6464
    The motor doesn't matter, it's the routing of the exhaust pipes. Also, an exhaust 'designed' for a 5.7 wouldn't necessarily be good for a 4.6 because of less exhaust gas flow.
  5. #4
    Join Date
    Jan 2011
    Location
    Beaumont
    Posts
    30
    Liked
    0 times
    Rep Power
    32
    ah, good point. I love the sound of the Corsa Sport exhaust system. Any recommendations for that type of sound that would fit a 4.6? I've been looking at MBRP Pro system on youtube, but I'm not sure that it's QUITE loud enough.
  6. #5
    Junior Member Chering88's Avatar
    Join Date
    Jul 2010
    Location
    Fresno, CA
    Posts
    181
    Liked
    0 times
    Rep Power
    304
    5.7 and 4.6 are the same after the first set of cats... so if it fits the 5.7 it WILL fit the 4.6
    know from personal experience, mine was designed for the 5.7 and fits my 4.6
    2010 - TOYOTA TUNDRA - 4.6L DC - BLACK - TINTED - NERF BARS - SHORTIE ANTENNA - KN DROP IN FILTER - TRUE DUAL MBRP EXHAUST - MT TIRES - 5100 BILSTEIN LIFT
    did i mention... bought and paid for
  7. #6
    Veteran Member spoon059's Avatar
    Join Date
    Jul 2009
    Location
    Maryland
    Posts
    878
    Liked
    114 times
    Rep Power
    3829
    If you are having trouble finding an exhaust, you might want to consider some powersticks and getting a local shop to route some custom pipes for you. I paid about $500 for 2 powersticks, custom pipes and 2 stainless tips... all welded. The sound is awesome and cheaper than an off the shelf exhaust.
    2010 white RW DC
    Rostra backup camera, TRD sway bar, BHLM, LineX
    folding seat mod, dual 2.25 Powersticks (too loud while towing... back to stock exhaust)
    JL Audio 8w3v3 sub w/Kenwood KAC-8104D amp, Polk DB651s fronts, dash tweeter bypass
    non-relay anytime fog light mod, Firestone Ride-Rite airbags
  8. #7
    Join Date
    Jan 2011
    Location
    Anaheim, CA.
    Posts
    22
    Liked
    0 times
    Images
    5
    Rep Power
    342
    Gibson Performance Exhaust used my 2011 DC 4.6 for r&d. They bolted up all the systems they offer for the 5.7 on my truck, and ran it on the dyno. All the systems bolted up the same (with great fitment), and all systems tested with a 10 - 15hp increase. I am running the 3" single exit in stock location, and love it.
    2011 Toyota Tundra Double Cab 2wd 4.6l with TRD air filter, Gibson Exhaust, CST 2" spacer lift, KMC Skitch 18" x 8.5" +35, BFG AT KO 275/70/18, debaged, color keyed handles, HIDs, and much more to come.
  9. #8
    Veteran Member codyh12345's Avatar
    Join Date
    Jun 2010
    Location
    Kansas
    Age
    29
    Posts
    1,045
    Liked
    126 times
    Images
    37
    Rep Power
    159425
    I have a flowmaster 50 SUV with custom pipes out behind the rear tires... paid 100 for the muffler and 120 install... oh and 20 for the tips. Sounds great... some drone at 1800 RPM, but nothing I cannot handle.
    2010 Slate Metallic DC Tundra 4.6L
    Mods:
    Auto Dimming Homelink Mirror with Compass, Aftermarket/OEM style fog lights from TRDSparks
    MPG Buttons, Color Matched Grille/Handles, Debadged, OEM Stainless Running Boards, Delta Pro Toolbox
    Alpine SPS-600C components (Front Doors and Dash), Alpine SPS-600 (Rear Doors), FATMAT on all 4 doors
    Pioneer 4300DVD with XOVision Backup Camera
  10. #9
    Junior Member Woodpro91's Avatar
    Join Date
    Dec 2010
    Location
    West of the Capital, Canada
    Age
    38
    Posts
    73
    Liked
    2 times
    Images
    1
    Rep Power
    57
    Cool Re: 4.6/5.7 aftermarket exhaust ?
    Quote Originally Posted by So-Cal SR5 View Post
    Sounds great! Pun intended.
    Thanks for the info.
    2010 Tundra Regular Cab SR5 4.6L 4x4-Towing package, 4.10 rear axle, TRD air filter, Oval step tubes, Leer bed cap w/ tool case, BedRug bedliner, Weather Tech Liners, Towing mirrors, Toyota Bluetooth, MPG us/m Dash Buttons Mod installed. Rostra Rearsight Camera, with view in my mirror, Plug and Play parts from Sparks. "Silver Sky Metallic" color. TRD rear sway bar, 304 stainless steel TRD cat-back dual exhaust. New mod January 2014- Tow mirrors delete, new regular size power & heated with integrated chevron signals.
  11. #10
    Join Date
    Dec 2010
    Location
    Age
    38
    Posts
    73
    Liked
    2 times
    Images
    1
    Rep Power
    57
    Hey guys I was on the TRD website and saw that the have a new dual exhaust cat back system for the 4.6 and the 5.7.
    'Stainless steel, rear left and right outlets, double wall polished tips and an aggressive, powerful v8 sound'
    It says that low and midrange hp and tq are improved. Sounds really good to me!
    What do you guys think? Anyone got this yet? Who would have the best price?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
