Gibson Exhaust
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Gibson Exhaust
  1. #1
    Veteran Member Frederick D. Berg's Avatar
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Default Gibson Exhaust
    Just put on a Gibson cat back dual sport. I have attached all of the clamps and tightened them after the break in. I am thinking of spot welding the pipes after the muffler to prevent any possible movement/play. I need some thoughts from you pros out there. Pros/Cons? Thanks.
    Fred
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member dogstate's Avatar
    Join Date
    Apr 2007
    Location
    Kansas
    Posts
    4,487
    Liked
    31 times
    Images
    3
    Rep Power
    18324
    Default Re: Gibson Exhaust
    I've had my Borla exhaust on my truck for like 45k miles now and I've never had to mess with a pipe coming detached. The only problem I have is mine sliding off the hangers. It probably happens once every few months, dependent on the kind of roads I drive on.
    -rockstate
  4. #3
    The M.F.I.C. PoPo's Avatar
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    63 times
    Images
    262
    Rep Power
    23502
    Without a sound-clip, it didn't happen...
    2004 Sequoia 4.7L 4x4
    275/65/17 Hankook I-Pike RW11, Brush guard, 27w LED Aux lights, Ebay Nav, Husky Liners
    Also have 2008 Prius, 2006 Honda Cr-V
    Previous: 2010 Tundra CM 4x4 & 2007 Tundra DC 4x4
  5. #4
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    Quote Originally Posted by popo2239 View Post
    Tough crowd...okay, here it is. Enjoy!
    Attached Files Attached Files
  6. #5
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    Here are the pictures of the Gibson eshaust system. If you can see the joints where the u bolts are attached, those are the ones I am wondering if I should tack weld. I have got the bolts as tight as I can get them. Cheers!
    Fred
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	58617   Click image for larger version.
ID:	58618   Click image for larger version.
ID:	58619   Click image for larger version.
ID:	58620   Click image for larger version.
  7. #6
    Supporter eatyourroadkill's Avatar
    Join Date
    Aug 2006
    Location
    Lafayette CO
    Posts
    414
    Liked
    3 times
    Images
    13
    Rep Power
    1874
    sounds really good
    2007 Tundra 4x4, Nautical Blue, 5.7, SR5, RCSB, NUVI 660, Ipod Nano Gen 3, Truxedo Lo Pro QT, Bedrug, LT295/70/18 Nitto Terra Grapplers, SS Exhaust tip, Stebel Compact truck horn, Auto-Dim w/compass rear view mirror, Silverstar (H11ST, 9005SU, 9145ST). Boston Acoustic S60, Kicker 50x2 Amp, Dynamat, Debadged, 2.5" Lift w/ F&R Bilstein 5100, 1" LRO tapered aluminum block, LRO diff drop, Hypertech inline speedo calibrator
  8. #7
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    63 times
    Images
    262
    Rep Power
    23502
    Looks & sounds good. Are you having any issues with them rattling? Just wondering why you're thinking you need to weld them in the first place... ?
    How much $$$ did that run ya?
  9. #8
    Junior Member 642MX's Avatar
    Join Date
    May 2007
    Location
    Evansville, IN
    Posts
    456
    Liked
    0 times
    Rep Power
    112
    Your truck sounds like mine!
    When I put my cat-back on, I used a 3/8" impact on the clamps. So far, so good... none have backed off or caused any problems.
    2008 Tundra DC 5.7L 4x4 TRD
    • Gibson Dual Sport Cat-Back
    • TRD Sway Bar
    • Tint 17%
  10. #9
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    Quote Originally Posted by 642MX View Post
    I had not thought of that...an impact wrench would do the trick! I am assuming you cut the ends of the bolts on both sides of all u-bolts? Love the sound of this exhaust...never knew a Toyota could sound this good.
  11. #10
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    No rattles as I have "wrenched" down the bolts as tight as I can get them but just wondered if it was wise to tack weld them to ensure no movement. I will cut the ends of the bolts and put an impact wrench on each one to ensure that I have them as tight as needs be. This SS Dual Sport system went for $657.00...no tax...free shipping. I was wondering, would you turn those u-bolts the other way so the ends are pointed up? Thanks and cheers!
    Fred
  12. #11
    Rookie 09streetbobber's Avatar
    Join Date
    Jan 2011
    Location
    New Mexico
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    sounds good man! maybe just double nut the nut so that they dont back off once to hit them with an impact.
  13. #12
    Join Date
    May 2007
    Location
    Evansville, IN
    Posts
    456
    Liked
    0 times
    Rep Power
    112
    Quote Originally Posted by Frederick D. Berg View Post
    You can cut them if you want to. I didn't cut mine since you really can't see them. Wait until you get about 1000 miles on that exhaust... it gets a little louder outside the cab, but stays nice and quiet inside.
    • TRD Sway Bar
    • Tint 17%
  14. #13
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    Thanks to all for the support and the "sharing" of hard work. I am going to take an impact wrench this weekend and tighten up all bolts without cutting them. This will ensure they are as tight as we need them. I sure am enjoying this Tundra as it is the best truck I have ever owned...bar none, and I have owned quite a few. Cannot wait until 1,000 miles when the sound only gets sweeter to the ears! Cheers!
    Fred
  15. #14
    Supercharged Member socal57chevy's Avatar
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180316
    We tack welded them at both exhaust shops I worked at. A small tack weld is easy to get rid of if you need the pipe back apart and keeps the pipe from shifting. The band clamps don't cinch the pipe like "U" bolt clamps do and it's common for the pipe to work loose or shift angles. We've adjusted, tightened and tack welded hundreds over the years.
    Nevermind. I just looked at your pics and saw that you used regular "U" bolt clamps. No need to tack those.
  16. #15
    Join Date
    Dec 2010
    Location
    Del Rio, Texas
    Posts
    866
    Liked
    148 times
    Rep Power
    226911
    Thread Starter
    Quote Originally Posted by 09streetbobber View Post
    Good advice...I think I will do this with lock nuts. What do you think? Cheers!
    Fred
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
