Pictures The BEST Oil Filter Wrench!!
View Poll Results: Which oil filter wrench did you buy for your Tundra? ('07-Current)
Voters
7. You may not vote on this poll
  • Assenmacher TOY640
    7 100.00%
  • KD Tools 3253
    0 0%
+ Reply to Thread
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By Armystrong
Thread: The BEST Oil Filter Wrench!!
  1. #1
    Junior Member Armystrong's Avatar
    Join Date
    Nov 2009
    Location
    Fort Carson, Colorado Springs
    Posts
    317
    Liked
    6 times
    Images
    34
    Rep Power
    735
    Default The BEST Oil Filter Wrench!!
    This is by far the BEST oil filter wrench I have bought! I went through several and this one is a keeper. The TOY640 is what my dealer uses and the one I highly recommend. (The only one I recommend)!
    Here is the link I bought mine from. The cheapest you will find for a heavy duty constructed oil filter wrench. Save on Assenmacher TOY 640 at ToolTopia.com
    Specifications:
    64mm with 14 flats
    Use in conjunction with a 24mm or 15/16" socket
    Made in the U.S.A.
    The second talked about (BUT NOT RECOMMENDED) Oil filter is the K-D Tools 3252 (Last Photo, Shiny Chrome Finish). SOME SAY IT WORKS SOME SAY THEY HAVEN'T HAD ANY LUCK WITH IT cus it slips. Works on 14 - flute, 65mm factory oil filters. This one is a tad bit cheaper! Save on KD Tools 3253 at ToolTopia.com
    Here is an excellent post for DIY OIL Change. DIY: Oil Change w/ pics. & Reset Maintenance Required Light
    Hope this helps.
    Jim
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Another Bottom Veiw.jpg
ID:	58726   Click image for larger version.
Name:	Bottom View of Oil Filter.jpg
ID:	58727   Click image for larger version.
Name:	Side View Oil Filter Wrench.jpg
ID:	58728   Click image for larger version.
Name:	Top View TOY640.jpg
ID:	58729   Click image for larger version.
Name:	K-D Tools 3253 Oil Filter Wrench.jpg
    Hippo likes this.
    2009 Toyota Tundra CrewMax 5.7L 4x4 SUPERWHITE!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    May 2009
    Location
    Portland, TX
    Age
    32
    Posts
    404
    Liked
    14 times
    Rep Power
    2315
    Default Re: The BEST Oil Filter Wrench!!
    FYI, the KD3253 would not fit my '09 Tundra's filter housing but the TOY640 fits perfectly. Here are some links to some posts in which I took some measurements that show why that is:
    -Wes
    2006 Toyota Tundra, Double Cab, 4.7L, 4WD, Silver Sky Metallic
  4. #3
    Join Date
    Nov 2009
    Location
    Posts
    317
    Liked
    6 times
    Images
    34
    Rep Power
    735
    Thread Starter
    Thank You KP Texan. I have edited my original post. I will not use anything other than the TOY640 on my 09 5.7L 4x4.
  5. #4
    Junior Member David Jones's Avatar
    Join Date
    Mar 2006
    Location
    Hoover
    Posts
    474
    Liked
    8 times
    Images
    35
    Rep Power
    1775
    Toyota "improved" the oil filter?
  6. #5
    Join Date
    Nov 2009
    Location
    Posts
    317
    Liked
    6 times
    Images
    34
    Rep Power
    735
    Thread Starter
    Quote Originally Posted by David Jones View Post
    Yes they did. Its no longer the canister oil filter you can remove by hand. You now have a filter housing unit with a drain plug for the housing unit and the filter element fits inside the housing unit. Its alittle more of a pain than the normal oil filter. After 30 years of oil changes, this is the first filter housing unit with a filter element inside I have had to change. After doing this once, its like any other filter change.
    Here is what the housing unit looks like. The prime reason you need a special tool for 2007 and up Tundras.
ID:	58740   Click image for larger version.
ID:	58741   Click image for larger version.
    Hippo likes this.
  7. #6
    Veteran Member Vettelover84's Avatar
    Join Date
    Jul 2010
    Location
    SomewhereBetweenHereandThere
    Age
    30
    Posts
    1,311
    Liked
    77 times
    Rep Power
    28914
    I have to agree that the TOY640 is awesome. It was well worth the price I paid!
  8. #7
    Supporter kerryman71's Avatar
    Join Date
    Mar 2009
    Location
    Worcester, MA
    Age
    44
    Posts
    2,697
    Liked
    807 times
    Images
    27
    Rep Power
    231947
    Good info. I have an '02, so my filter wrench is my hand .
    John
    The fools, the fools the fools! They have left us
    our Fenian dead, and while Ireland holds these
    graves, Ireland unfree shall never be at peace!
    Padraig Mac Piarais (Patrick Pearse)
  9. #8
    Rookie berky2500's Avatar
    Join Date
    Jan 2004
    Location
    Anywhere
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    I performed the first oil change on my 2011 Tundra tonight. Used an OEM brand, 64mm Filter Wrench from AutoZone. It is an aluminum wrench, so no problems with splitting or slipping like others have noted with the plastic ones on other threads. It worked well. Only minor issue is that it sticks when full tight or full loose, there is a spot in between where it will slides right off. But after loosening, or tightening, it stays stuck very tightly. Wasn't an problem, just noting it. $9.99, OEM # 25412.
  10. #9
    Supporter Hootbro's Avatar
    Join Date
    Jul 2010
    Location
    Delaware
    Age
    48
    Posts
    381
    Liked
    47 times
    Images
    1
    Rep Power
    1750
    Quote Originally Posted by berky2500 View Post
    TOY640 wrench I have also sticks when full tight or removal. Just reverse ever so slightly and it releases.
    2010 Tundra DC 4.6L 4x4 (SOLD)
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
