08 Tundra codes C1241 / C1332 / C1340...
+ Reply to Thread
Results 1 to 4 of 4
Thread: 08 Tundra codes C1241 / C1332 / C1340...
  1. #1
    Join Date
    Nov 2010
    Location
    Iowa
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Default 08 Tundra codes C1241 / C1332 / C1340...
    I have the following codes on my 2008 Crew Max 4x4.
    4hi / 4 lo VSC - ALL - Flashing
    ABS / Skid Control - ALL -Solid lit
    Happened the other day, lights did this...shut off truck and lights went off. Then they came back...now they won't go away. I put it on the local guys scanner and got 3 codes...
    C1241 low OR high power supply voltage
    C1332 Open circuit Rear Right Speed Sensor Circuit
    C1340 Center Differential Lock Circuit
    Anyone had these issues before? I'm thinking it might be wires since all 3 of them are going off?
    I just got done with the stupid Air Intake blower issue...had the whole system replaced (which Toyota paid all but $350 of)....and now this. I know this is a product of all the crap every car mfg has to put on for emissions / safety, but I'm getting sick of it.
    Also, the truck is not shifting out or into 4wd...but I have gotten it to go one time out and one time back. It's in 4wd now and I'm just leaving it since it's winter here in Iowa. I'm thinking that is the speed sensor issue...since the computer doesn't know how fast the wheels are spinning it says 'nope, this could cause damage so no change in drive system'.
    Oh, one final thing...I don't trust (and have been proven correct in that judgment) our local Toyota dealer and it's a pain to drive all the way down to Ames (1.5 hours). So I'll probably go with the local independent since I'm out of warranty.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Jan 2011
    Location
    wi
    Age
    47
    Posts
    28
    Liked
    0 times
    Rep Power
    60
    Default Re: 08 Tundra codes C1241 / C1332 / C1340...
    Take a look at the RB1 connector just above the rear diff this is where both rear speed sensor harnesses come together. Unplug and inspect sensor wires for possible corrosion from moisture intrusion. If you find corrosion will need to replace affected speed sensor harness. Harness part #89516-0c050. There is also a bulletin for this concern t-sb-0346-08 so this would be good place to start. Hope this helps!!
  4. #3
    Join Date
    Nov 2010
    Location
    Iowa
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks...I'll try that.
  5. #4
    Join Date
    Feb 2010
    Location
    canada
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    Any luck with that Wilber?
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
