Interior lights Flicker?
+ Reply to Thread
Results 1 to 6 of 6
Thread: Interior lights Flicker?
  1. #1
    Join Date
    Jan 2008
    Location
    standish
    Posts
    53
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Default Interior lights Flicker?
    As of lately, My interior lights have been pulsating/flickering when I turn them on. I can also sometimes see SLIGHT flickering in my headlights and tail lights. Any ideas from anyone? The only thing I can think of is maybe the battery is starting to loose some juice? and or bad connection? I don't have anything aftermarket electrical wise. What are your guys thoughts? any ideas would be appreciated!!! Thanks
    I tried searching and found nothing....
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member WyomingMedic's Avatar
    Join Date
    Feb 2011
    Location
    The 307
    Posts
    33
    Liked
    0 times
    Thanks
    0
    Rep Power
    89
    Default Re: Interior lights Flicker?
    Hmmm, I am not an experienced Tundra feller (YET), but I am an automotive wiring nut.
    My best guess would be battery based, but I doubt it is a "bad" battery. If you have a pulsing or flickering, it would indicate to me that there is a variable load on the power system OR something loose.
    If the flickering rhythmic at all?
    My first bet would be to check the connections at the battery. Especially the negative clamp. Clean them and give em a good tug, they should be stable and not move.
    Next move over to the alternator. Make sure all the cables (again, especially the ground) are firmly attached.
    I have seen batteries have a poor ground connection and rapidly go from poor to better contact and draw some weird currents while the charging system plays catchup then shutdown. Same with the alternators. Poor ground connections can change loads.
    If that does not work, I would look at the output of the alternator itself. While he truck is running, get a good FAST volt meter and put it on the battery posts then the alternator outputs. See if there is proper voltage and if it is fluctuating. Then check the voltages at the various electrical panels. I don't know what the Tundras use for voltage regulation, but it could be malfunctioning and you would not see that until some point AFTER the battery and charging system.
    As a final and worst case scenario, I have seen multiplexed electrical systems get wet and have some very bizarre symptoms (like antilock brakes randomly engaging). Watch to see if there is any correlation once once the system dries out (if it is wet, if not, no worries).
    Those are my best guesses. Sadly, electrical "ghost" problems can be some of the hardest to diagnose. It may be something VERY simple, or not.
    Good luck,
    WM
  4. #3
    cmb
    cmb is offline
    Veteran Member cmb's Avatar
    Join Date
    Jan 2005
    Location
    Cecil County MD
    Age
    61
    Posts
    715
    Liked
    23 times
    Thanks
    0
    Images
    2
    Rep Power
    359
    Hopefully it's not rodent damage. Take a "flashlight tour" under your hood to make sure. Could be just getting started.
  5. #4
    Join Date
    Jan 2011
    Location
    wi
    Age
    47
    Posts
    28
    Liked
    0 times
    Thanks
    0
    Rep Power
    60
    Would seem to be a charging based concern. Does flickering go away when rpm's of engine are higher? And like WyomingMedic stated take good look at battery terminals for corrosion this can cause voltage drop/excess resistance.
  6. #5
    Join Date
    Jan 2008
    Location
    standish
    Posts
    53
    Liked
    0 times
    Thanks
    0
    Rep Power
    8
    Thread Starter
    Quote Originally Posted by ToyotaTechnition View Post
    Thanks for the replies...and a quick look under the hood seems like there is some corrosion around my battery terminals as Wyomingmedic and toyotatechnition said may be a cause. Hopefully it is as simple as giving them a cleaning...
    I'll keep you guys updated....
  7. #6
    Senior Contributor Barney_Fife's Avatar
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Thanks
    0
    Images
    216
    Rep Power
    7361
    corrosion causing bad ground IMO. if not at the battery, check the main ground wires to make sure htey arent corroded too. my guess would be a poor ground someplace.
    2007 Super White DC SR5 , TRD OffRoad; Sand Beige leather, 4.7, tinted windows, OEM running boards, tow mirrors with chrome covers, Armorlid tonneau, billet grille, aftermarket reverse sensors, flowmaster true duals with 3.5 rolled edge stainless tips, Sirius added via OEM module, 5000K HID lowbeams, KMC XD Hoss 20'' wheels in gloss black, Nitto Terra Grappler AT 285/55/20's, chrome door handle covers, smoothed and painted tailgate handle, 3 inch lift/levelling kit,1.5'' Rough Country lift blocks in rear, DVD headrest player/monitors, Rostra backup camera, SS bull bar with 6'' lights, Faux Carbon Fiber dash,console and door trim. Work stuff: red/blue LEDs in grille, headlight wig wag flasher, red/blue LED windshield light, red/blue LED deck lights in back glass, red/blue split 4 LED lights either side of license plate, wig wag backup and brake lamps. 100 watt siren and PA.
    Quote Originally Posted by steppy View Post
    what barney said sounds reasonable
    Quote Originally Posted by JMSinMD View Post
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
