Pictures DIY - Bed Storage system for my truck
+ Reply to Thread
Page 1 of 4 1234 LastLast
Results 1 to 15 of 47
Thread: DIY - Bed Storage system for my truck
  1. #1
    The M.F.I.C. PoPo's Avatar
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Default DIY - Bed Storage system for my truck
    Been scheming a way to build this for awhile, trying to decide how tall/wide/deep...etc I wanted to build it. Then, trying to decide how exactly I'd attach it to the truck, which rollers to use, materials, etc.
    This is what I came up with The "roller-base" does not attach, per-se... the sides are beveled slightly so that it wedges in between the wheel-wells. You cannot slide it out, it must be lifted, then removed. It's made out of 5/8" plywood, then coated with bedliner. The rollers are "ball-bearing rollers"... I've been trying to find them for awhile, and finally found them at Harbor Freight (gotta love that store!) for around $1/ea.
    The tailgate piece was made (with that lip/raised area) to fit securely against the tray, overlapping the edges, and forming a tight seal. It's attached to the tailgate with industrial strength velcro. It's covered in bedliner spray. It also acts to protect the tailgate/paint...
    The tray is made out of 3/4" plywood... built using heavy-duty screws, and of course covered with bedliner. It's 48" wide X 65" long X 9" deep (interior). I was able to find a cheap piece of carpet to line the bottom. It has divider/inserts that can be used when desired, as well as a middle support divider in case I need to load anything heavy on the top cover pieces.
    The cover is 3-pieces of 3/4" plywood (bedliner spray), and each piece is 60" wide X 21.5" deep. The pieces have "guides" on the bottom so they sit perfectly centered on the tray. The 1st piece has a metal-tab that secures it to the rear of the tray. Then, each piece has metal tabs that secure them to eachother, so that none can be lifted off without first rolling out the tray & removing the 3rd cover piece first, then the 2nd, then the last. Each has 2 cargo-hooks bolted in. When the tray is rolled in, the pieces cannot be opened or removed due to the guide-wheels on top (you'll see them on each side of the bed-opening). These have 2 functions: 1) to lock down the covers, 2) so that when you roll-out the tray, the wheels keep it from tipping down.
    The unit is heavy... I'd say that the total added weight is around 200-250 lbs, maybe more. It's rugged, sturdy, and most of all, functional! What do ya think?
    2004 Sequoia 4.7L 4x4
    275/65/17 Hankook I-Pike RW11, Brush guard, 27w LED Aux lights, Ebay Nav, Husky Liners
    Also have 2008 Prius, 2006 Honda Cr-V
    Previous: 2010 Tundra CM 4x4 & 2007 Tundra DC 4x4
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,111
    Liked
    345 times
    Images
    8
    Rep Power
    42560
    Default Re: DIY - Bed Storage system for my truck
    Neat!! I like it!!
    One question. Do you have a mechanical stop on it to keep it from rolling out too far??
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Senior Contributor Barney_Fife's Avatar
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Images
    216
    Rep Power
    7361
    i like. now, whats your total $$ invested in it?
    2007 Super White DC SR5 , TRD OffRoad; Sand Beige leather, 4.7, tinted windows, OEM running boards, tow mirrors with chrome covers, Armorlid tonneau, billet grille, aftermarket reverse sensors, flowmaster true duals with 3.5 rolled edge stainless tips, Sirius added via OEM module, 5000K HID lowbeams, KMC XD Hoss 20'' wheels in gloss black, Nitto Terra Grappler AT 285/55/20's, chrome door handle covers, smoothed and painted tailgate handle, 3 inch lift/levelling kit,1.5'' Rough Country lift blocks in rear, DVD headrest player/monitors, Rostra backup camera, SS bull bar with 6'' lights, Faux Carbon Fiber dash,console and door trim. Work stuff: red/blue LEDs in grille, headlight wig wag flasher, red/blue LED windshield light, red/blue LED deck lights in back glass, red/blue split 4 LED lights either side of license plate, wig wag backup and brake lamps. 100 watt siren and PA.
    Quote Originally Posted by steppy View Post
    what barney said sounds reasonable
    Quote Originally Posted by JMSinMD View Post
    Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
  5. #4
    Join Date
    May 2008
    Location
    SD, CA
    Posts
    889
    Liked
    0 times
    Images
    2
    Rep Power
    81
    I like it... good job. This will definitely solve the "bed bounce" problem people are complaining about! LOL.
    2007 Tundra SR5 CrewMax 5.7L
  6. #5
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    Quote Originally Posted by mendonsy View Post
    Neat!! I like it!!
    Well, currently I have a "rope" attached to the rear, but that's just temporary until I make a permanent fix. It works, but isn't the answer... The best part of this system is that it just "sits" in there, and can be removed in just a few minutes with no tools.... whatever I come up with for the stop, it has to follow that rule. And thanks!
    Quote Originally Posted by Barney_Fife View Post
    Hmm... about $100 in wood, $35 for the rollers, hooks & wheels, $20 for the carpet, $100 for the bedliner spray & paint... So, roughly $250 total.
  7. #6
    Veteran Member DawgBonez's Avatar
    Join Date
    Dec 2008
    Location
    Covington
    Posts
    1,255
    Liked
    36 times
    Images
    5
    Rep Power
    1132
    That's pretty crafty... I like it!!!
    08 Limited DC 4x4 Black/Charcoal
    TRD SuperCharger, TRD Cat Back, TRD 22" Forged 5 Spoke
    Odessey Battery, Pioneer Avic Z120BT, PAC SWI-PS, PAC TATO, RockFord Fosgate P1000 w/remote powering a JL SteathBox
    Factory matched tint, Paint matched grill surround, Sequoia mirror caps, Sequoia door handles, Debadged, Appearance rear bumper w/ sonar, Removed step bars
    Full interior LED's including vanity, puddle, reverse, cargo, and license plate LED's, DirectJG 35w 4500k HID's Low Beams, 35w 6000k Fogs, 55w 6000k High Beams, Side marker bulb delete, 2010 TailLights, EBAY bought LED/Smoked 3rd brake Light, Chrome painted amber DRL's and blinker bulbs
    More to come......
  8. #7
    Join Date
    Feb 2011
    Location
    North TX
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    very creative design, i like it!
    2010 Tundra Cremax 4x4 4.6L | 305 65r18 BFG A/T | 3/1.5 Rough Country level kit | 18x9 XD Monsters +18
  9. #8
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    Quote Originally Posted by matrix77 View Post
    LOL - I was thinking the same thing when I was putting it in. There's only 1 stretch of road around here that I've noticed BB on, so I'll have to wait until I drive over it again to see if this changes it or not
    Now I just need to do the "auto-tailgate lock" mod, since this acts as lockable storage when the tailgate is locked. I'm planning on doing that pretty soon - that along with the auto-locks on the Leer top will be really convenient
  10. #9
    Join Date
    Feb 2011
    Location
    North TX
    Posts
    6
    Liked
    0 times
    Rep Power
    0
    i forgot to ask, any extra rattles/squeaking, etc. ?
  11. #10
    Junior Member Toy Collector's Avatar
    Join Date
    Jul 2008
    Location
    Vista
    Posts
    401
    Liked
    3 times
    Rep Power
    531
    I just want to know what it says under the black square... ha!
    Looks good... and functional!
    My truck squeaks. I want a new one. I mean... I know it's made from mass produced parts... I know things move... I know I want a new one... that's all. I won't take the 2 hours to investigate and resolve the solution... I want the dealer to fix it... no... I want a new truck!
  12. #11
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    Quote Originally Posted by Toy Collector View Post
    Department logo & Squad/Team --- didn't want any issues, just in case... never know these dayse
    Quote Originally Posted by tjs011 View Post
    Tonight will be my first time driving it, so I'll let u know I'm hoping there won't be, since I designed it to be VERY snug when you close the tailgate.
  13. #12
    NASH Dim Sum's Avatar
    Join Date
    Apr 2007
    Location
    Henderson, NV
    Age
    30
    Posts
    3,634
    Liked
    403 times
    Rep Power
    227418
    That's slick! I wish I could do something like that, but I always have to keep my bed ready for the ATV :/.
    -Steve
    2011 Ford F-350 SuperCrew Lariat 4x4 6.7 Powerstroke: Truxedo Truxport
    "The America Republic will endure until the day Congress discovers that it can bribe the public with the public's money." -- Alexis de Tocqueville
  14. #13
    Join Date
    Sep 2009
    Location
    Detroit
    Posts
    3,761
    Liked
    64 times
    Images
    262
    Rep Power
    23502
    Thread Starter
    Well, drove it finally. Man, I love the way having weight in the bed softens up the ride with these trucks. However, cornering showed that I need to get the TRD sway bar if I have this much weight in the bed for regular driving.
    No rattles... Didn't hear it at all. And actually, I think it made the truck more quiet since it softened up the ride and didn't cause so much jarring over bumps.
  15. #14
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Images
    216
    Rep Power
    7361
    did it level your truck out? i'd imagine having the cap and that huge gun case, er, bed storage system, would probally bring the back down a tad so it sits level now....?
  16. #15
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,111
    Liked
    345 times
    Images
    8
    Rep Power
    42560
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. 02-22-2015, 10:57 AM
  2. 12-19-2014, 04:33 PM
  3. 11-15-2014, 06:58 PM
  4. 11-14-2014, 08:38 PM
  5. 11-13-2014, 10:13 PM
  6. 11-12-2014, 08:10 PM
  7. 11-12-2014, 05:56 PM
  8. 11-12-2014, 12:07 PM
  9. 11-10-2014, 08:35 PM
  10. 11-05-2014, 11:29 PM
  11. 11-05-2014, 05:00 PM
  12. 11-04-2014, 07:42 AM
  13. 10-21-2014, 09:02 PM
  14. 10-19-2014, 08:39 PM
  15. 10-16-2014, 07:42 AM
  16. 10-14-2014, 10:23 AM
  17. 10-11-2014, 03:40 AM
  18. 10-06-2014, 04:37 AM
  19. 10-05-2014, 11:12 AM
  20. 10-04-2014, 08:58 PM
  21. 10-01-2014, 07:10 PM
  22. 09-30-2014, 12:07 AM
  23. 09-24-2014, 10:12 PM
  24. 09-19-2014, 08:38 PM
  25. 09-15-2014, 10:06 PM
  26. 09-15-2014, 06:22 AM
  27. 09-13-2014, 03:13 AM
  28. 09-05-2014, 07:47 PM
  29. 09-04-2014, 06:35 AM
  30. 09-01-2014, 06:15 PM
  31. 08-26-2014, 01:57 PM
  32. 08-24-2014, 04:55 PM
  33. 08-16-2014, 08:08 PM
  34. 08-04-2014, 05:28 AM
  35. 07-28-2014, 10:10 PM
  36. 07-26-2014, 04:11 AM
  37. 07-20-2014, 10:03 AM
  38. 07-18-2014, 10:25 AM
  39. 07-08-2014, 07:12 PM
  40. 07-05-2014, 11:28 AM
  41. 07-01-2014, 08:35 PM
  42. 06-28-2014, 07:30 PM
  43. 06-28-2014, 07:19 PM
  44. 06-17-2014, 07:33 PM
  45. 06-15-2014, 06:29 PM
  46. 06-15-2014, 06:34 AM
  47. 05-25-2014, 03:59 PM
  48. 05-25-2014, 03:57 PM
  49. 05-25-2014, 09:53 AM
  50. 05-14-2014, 05:57 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
