DIY How to install OEM Tundra Bedliner
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Like Tree1Likes
Thread: How to install OEM Tundra Bedliner
  1. #1
    Junior Member AlaskaTundraMan's Avatar
    Join Date
    Dec 2010
    Location
    Alaska
    Posts
    102
    Liked
    2 times
    Rep Power
    281
    Default How to install OEM Tundra Bedliner
    Greetings!
    This is post is about how to install a drop in OEM style Factory bedliner by Toyota. I purchased the bedliner at my dealership for three hundred bucks. I initally wanted a spray in bedliner, but after reading that a spray in could negate your warranty on new vehicle, I opted for the drop in. I also took in consideration that if I ever wanted to pull the bedliner out, I could easily do that. Also, if the bedliner ever busts, I can just go get a new one!
    There are 3 parts to your bedliner, the tailgate piece, bedliner, and tailgate spacers.
    There are four primary steps to installing this OEM style bedliner:
    1. Clean out your truck bed thoroughly with some water, do really need to use soap as this could cause your vehicle to form rust spots if water pools up underneath it. The chemicals in soap if left on there can cause your bed to rust. After wiping it out, I suggest letting it air dry for about 15 minutes or so, if your vehicle iis in a garage, you can do like I did and immediately install as my garage dries things out really fast!
    2. Once complete drying, you will need a T-30 Torque screw to unloosen the bolts that hold the tailgate piece together. There are a total of 8 of them. Below is a pic of it. Once you have unloosened the screws, put the black tailgate liner on, matching up the holes, then reinstall the screws, washers, and plastic tailgate spacers and screw in, dont overtighten!
    [IMG]file:///C:/Users/lasiter/Desktop/Auto%20loan/Need%20a%20T-30%20torque%20screwdriver%20for%20these.jpg[/IMG]
    3. Once you have completed the tailgate, pick up the bedliner, (preferably with 2 people) I did mine with the old lady, and then drop it in, pick a side and angle it so the lip of the liner goes in one side first. Once in place, then slide the other side in place. You will have to pick up the middle of the bedliner in order to cause the left side to have enough room to pop in. ( This part is a pain in the butt as the plastic is not real flexible. Be sure to get the back lip portion over first before you do this. (Tip: Have one person pull the middle up, which causes the opposite side to cave in towards the middle, makes it easier to pop in place)
    4. Once it is in place, check the functionality of the tailgate to make sure it closes, and you are done!
    [IMG]file:///C:/Users/lasiter/Desktop/Auto%20loan/Completed%20Install.jpg[/IMG]
    For those of you that are thinking about bedliners, this is a great alternative to a spray in bedliner that will look good for years to come. I have one in my sport trac, (factory OEM) that I have had in there for 8 years and it still looks like new!
    Hope this helps whoever is considereing getting one, I love this one so far!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Hootbro's Avatar
    Join Date
    Jul 2010
    Location
    Delaware
    Age
    47
    Posts
    381
    Liked
    47 times
    Images
    1
    Rep Power
    1750
    Default Re: How to install OEM Tundra Bedliner
    You can not locally host your pictures on your hard drive and expect others to see them. Need a third party host site like Photobucket or similar.
    2010 Tundra DC 4.6L 4x4 (SOLD)
  4. #3
    Join Date
    Dec 2010
    Location
    Alaska
    Posts
    102
    Liked
    2 times
    Rep Power
    281
    Thread Starter
    For some reason the pics did not post, see the pics attached.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Completed Install.jpg
ID:	59507   Click image for larger version.
Name:	Need a T-30 torque screwdriver for these.jpg
  5. #4
    Join Date
    Jul 2010
    Location
    Delaware
    Age
    47
    Posts
    381
    Liked
    47 times
    Images
    1
    Rep Power
    1750
    Looks good!
  6. #5
    Join Date
    Dec 2007
    Location
    Southern, Ca.
    Posts
    94
    Liked
    6 times
    Rep Power
    45
    Quote Originally Posted by AlaskaTundraMan View Post
    Greetings!
    This is the FIRST I've ever heard that a spray in bedliner will negate any type of warranty. Where'd you get that info from?
    2009 Tundra DC SR5 TRD 5.7L - Pyrite Mica
    Tow Package
    Tow Mirrors
    OEM Drop in Bed Liner
    OEM Fog Lights
    15% Tint all around
    EGR Bug Deflector
    Westin Platinum oval step tubes (black)
    USA-Spec ipod PA15
    Toyota Homelink/Compass Mirror
    K&N drop in filter
    Firestone Air Bags
    2012 Wildwood T26RKS travel trailer..
  7. #6
    Lurking Member Durangoman's Avatar
    Join Date
    Oct 2010
    Location
    Durango
    Posts
    28
    Liked
    0 times
    Rep Power
    58
    Quote Originally Posted by VC-17 View Post
    I've never heard of that.
    Plastic bed liners are garbage-- Things slide around, they warp, water and dirt gets underneath causing rust issues. Spray-on liners are the only way to go.
  8. #7
    Veteran Member Garth's Avatar
    Join Date
    Jan 2000
    Location
    VT
    Posts
    618
    Liked
    3 times
    Images
    4
    Rep Power
    267
    re: spray in bedliner not under warranty
    The only place that would say that would be someone looking to sell the Bedliner. I've never heard of such a thing either.
    I will never use a drop in bedliner again, it caused rust buildup on my '00 tundra where water(with salt in it I'm sure) sat under it, and ate the metal where the bedliner had rubbed the paint off the metal.
    -Garth
  9. #8
    Join Date
    Dec 2010
    Location
    Alaska
    Posts
    102
    Liked
    2 times
    Rep Power
    281
    Thread Starter
    Quote Originally Posted by Garth View Post
    -Garth
    Well, I did not create this post to argue if a drop in bedliner or spray in bedliner is better. I created it so that those of us that do not have 596.00 to 800.00 plus dollars lying around can have an alternative solution to lining our beds of the truck. A bedliner is there for many purposes and many uses, it all depends on who wants it, needs it and ultimately preference. Its like comparing apples to oranges, both are sweet and fruits, its a matter of preference....
    For those of you that live on the cheap like I do, this bedliner will serve you well! Also, for those of you that take care of your vehicles, this bedliner will be fine, considering you can take it out in less than 10 minutes and due some maintenance on the truck bed when you wish...Hope this helps, thanks guys!
  10. #9
    Senior Contributor Barney_Fife's Avatar
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Images
    216
    Rep Power
    7361
    If one lives in salt country i could see it being an issue. for most of us a drop in works just fine. if its a quality drop in, it wont warp or crack. ive seen cheap ones do both of those but not a decent OEM maker or similar. the guy took the time to do a DIY on a modification...(yes a very basic modification most of the world could do easily, but the effort is commendable)... the spray ins are kinda funny. they scuff the heck out of the paint and spray crap on there that over time fades and looks worse than a worn OE finish anyway. the plastic bed liners dont fade or dull over time. if they do its easy to drop another one in. ( i know they say they have UV stable ones etc but here in texas nothing is UV stable and anything fades.
    B-boo likes this.
    2007 Super White DC SR5 , TRD OffRoad; Sand Beige leather, 4.7, tinted windows, OEM running boards, tow mirrors with chrome covers, Armorlid tonneau, billet grille, aftermarket reverse sensors, flowmaster true duals with 3.5 rolled edge stainless tips, Sirius added via OEM module, 5000K HID lowbeams, KMC XD Hoss 20'' wheels in gloss black, Nitto Terra Grappler AT 285/55/20's, chrome door handle covers, smoothed and painted tailgate handle, 3 inch lift/levelling kit,1.5'' Rough Country lift blocks in rear, DVD headrest player/monitors, Rostra backup camera, SS bull bar with 6'' lights, Faux Carbon Fiber dash,console and door trim. Work stuff: red/blue LEDs in grille, headlight wig wag flasher, red/blue LED windshield light, red/blue LED deck lights in back glass, red/blue split 4 LED lights either side of license plate, wig wag backup and brake lamps. 100 watt siren and PA.
    Quote Originally Posted by steppy View Post
    what barney said sounds reasonable
    Quote Originally Posted by JMSinMD View Post
  11. #10
    Join Date
    Dec 2010
    Location
    Alaska
    Posts
    102
    Liked
    2 times
    Rep Power
    281
    Thread Starter
    Quote Originally Posted by Barney_Fife View Post
    Thanks Barney, I appreciate the kudos! Yeah I just wanted to share something with the Tundra community you have here, I get on here just about everynight when I am winding down with the kiddo's and they are preparing to go to bed. They watch cartoons, I get on here and daydream about superchargers and what other mods people are doing on their tundras, some really cool stuff here!
    Yeah, the reasons you stated are the primary reasons I chose a drop in liner over over spray in, I just did not feel like dealing with the spray stuff.
  12. #11
    Veteran Member toolowtrh's Avatar
    Join Date
    Jun 2008
    Location
    El Cajon
    Posts
    681
    Liked
    12 times
    Rep Power
    1667
    If you have to buy another one at $300 then you've spent the same amount anyway. Props to you for getting what you want for your truck, but you logic just doesn't make sense. And I am another one who has never heard of a spray-in voiding any warranty.
  13. #12
    Join Date
    Jan 2000
    Location
    VT
    Posts
    618
    Liked
    3 times
    Images
    4
    Rep Power
    267
    Unfortunately all of the trucks I've looked at (I'm almost ready to purchase one) have the OEM bedliner in them. One of the first things I'll be doing, is pulling that out, and getting a spray in. I'll probably put it up on CL.
    I wasn't trying to sway anyone one way or another, just telling you my experience with it(I forgot to tell how it always made noises driving down the road, as it banged against the side from the wind and bumps in the road) and how I'd never heard of the spray in causing warranty issues.
    -Garth
  14. #13
    Join Date
    Dec 2007
    Location
    Southern, Ca.
    Posts
    94
    Liked
    6 times
    Rep Power
    45
    I'm sure there are many who will use your DIY drop in bed liner write up, my truck came with a Toyota drop in bedliner, if it didn't, I would've opted to get a spray in liner like I had on my 3 previous trucks. I just didn't get the part where you read that spray in bedliners VOID the vehicles warranty.
    Tow Package
    Tow Mirrors
    OEM Fog Lights
    15% Tint all around
    EGR Bug Deflector
    USA-Spec ipod PA15
    K&N drop in filter
    Firestone Air Bags
  15. #14
    Join Date
    Dec 2010
    Location
    Alaska
    Posts
    102
    Liked
    2 times
    Rep Power
    281
    Thread Starter
    When I said it may void the warranty, I was getting it from Toyotas website. Please check out the following link: http://www.usatoyotaparts.com/stores...lsBedliner.pdf
    Refer to page 3, the question is addressed on question 1. I also copied and pasted the info:
    QUESTION #1:
    Is it true that drop-in bedliners
    can rust your truck bed?
    ANSWER:
    Toyota Skid Resistor™ Bedliners
    require no drilling, and the I-Beam floor
    construction promotes natural moisture
    evaporation. Due to the installation process
    that may require “scuffing” the truck bed,
    spray-on coatings may void the paint and
    corrosion warranty."
    Now whether this is true or not, I dont know or really care, just sharing the information with other Tundra enthusiasts, like myself
  16. #15
    Join Date
    Jan 2008
    Location
    mansfield, texas
    Posts
    7,461
    Liked
    16 times
    Images
    216
    Rep Power
    7361
    Quote Originally Posted by toolowtrh View Post
    yup. and 5 years down the road if he buys another for 300 he has a nice clean brand new one for the same money. if he spent all that up front, then in 5 years its gonna look all dirty and faded and grungy. and he cant renew it w/o spening more money. besides, 300 for some is alot easier to cough up than 600. even if they do it twice. kinda like financing a car. a few hundred a month is easier to spend than 30k at once. you spend the same money (assuming 0 percent of course) but you spend it when you want and can spend it.
    as far as the warranty goes, i do see the point in the corrosion warranty aspect but i would believe that rhino or linex or whoever would step in and guarantee their product to not allow rust through from the top side...so the warrany issue probally is a mute point.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
