Help I my brakes are srewed after brake job
+ Reply to Thread
Results 1 to 13 of 13
Thread: Help I my brakes are srewed after brake job
  1. #1
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Default Help I my brakes are srewed after brake job
    Let me start by saying I've done many brake jobs but never on a vehicle with ABS brakes. Following another threads suggestion I bled the brakes before compressing the caliper pistons. I used a vacuum bleeder. Now my brakes are installed but I have excessive pedal travel. I've bled the brakes the old fashioned way with pumping several times and I'm getting no improvement in pedal travel. Am I missing something?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Dec 2007
    Location
    Southern, Ca.
    Posts
    94
    Liked
    6 times
    Rep Power
    45
    Default Re: Help I my brakes are srewed after brake job
    You shouldn't have blead the brakes before compressing the calipers. I've never blead the brake system unless there was air in the lines. If you were just replacing pads, there should be NO reason to bleed the system. If you have everything put together with new pads, bleed the system again.
    2009 Tundra DC SR5 TRD 5.7L - Pyrite Mica
    Tow Package
    Tow Mirrors
    OEM Drop in Bed Liner
    OEM Fog Lights
    15% Tint all around
    EGR Bug Deflector
    Westin Platinum oval step tubes (black)
    USA-Spec ipod PA15
    Toyota Homelink/Compass Mirror
    K&N drop in filter
    Firestone Air Bags
    2012 Wildwood T26RKS travel trailer..
  4. #3
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by VC-17 View Post
    I agree, I've never dont this before either. But a member on here suggested that with ABS brakes you don't want to send dirty fluid from the calipers back to the control system. It made sense to me.
  5. #4
    Junior Member teallin's Avatar
    Join Date
    Aug 2010
    Location
    East Hanover NJ
    Posts
    391
    Liked
    39 times
    Images
    8
    Rep Power
    3218
    You can open the bleeder screws and compress the pistons which will force the old fluid out and not back into the system.
    2010 Black Rock Warrior DC
    mpg buttons added
    WeatherTech Side Window Deflectors
    Custom bed lighting
  6. #5
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Does anyone have an idea as to why, with repeated bleedings I still have spongy brakes? I took the truck around the block and it is slightly improved but at stops the pedal travels a little to close to the floor for my liking.
  7. #6
    Veteran Member Vettelover84's Avatar
    Join Date
    Jul 2010
    Location
    SomewhereBetweenHereandThere
    Age
    30
    Posts
    1,311
    Liked
    77 times
    Rep Power
    28914
    You added more brake fluid right????
    Also if you let fluid out to fast you may have let air in at the master cylinder and then down into the line.
  8. #7
    Join Date
    Feb 2008
    Location
    lincoln ne
    Posts
    228
    Liked
    0 times
    Rep Power
    27
    hmm did u change out fronts? and rear?
    mine had alot of travel when i changed the fronts...i did the rears today..kinda disappointed that the rear were lower than the fronts! and i have alot less pretravel now
  9. #8
    Supercharged Member socal57chevy's Avatar
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Quote Originally Posted by teallin View Post
    Exactly.
    It's not a complete system bleed, it's just allowing the nasty fluid at the caliper to be expelled instead of returned to the reservoir. You will likely need to connect a scantool with ABS capabilities and do a bleed procedure using the scantool. I have also had great results using a pressure bleeder (not a vacuum bleeder) on ABS systems. Keep plenty of fluid in the reservoir at all times.
  10. #9
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Thanks for the responses. Answers to questions are. I never bled the system down, just about 30 mls of fluid at each caliper. The resevior never went below the minimum line. I changed both fronts and rears. As one poster suggested, perhaps I bled to quickly and drew air into the lines. Next time I'll just open the bleeder nuts as suggested, I guess I thought that might let air in so I applied vacuum. I didn't know if I may have caused damage to some internal check valves when I applied vacuum. My understanding is that a vacuum bleeder should be fine for ABS brakes, but then the Tundra is a little more complex then just an ABS system. I'll try a couple more bleedings.
  11. #10
    Supercharged Member RONE's Avatar
    Join Date
    May 2007
    Location
    Merriam, KS
    Posts
    2,533
    Liked
    53 times
    Rep Power
    6465
    Have you actually tried driving it to feel if the brakes 'firm up'? Sitting at a stop, I can push my brake pedal all the way to the floor (as can everyone else with a Tundra).
  12. #11
    Join Date
    Jan 2011
    Location
    Schenectady, NY
    Age
    48
    Posts
    43
    Liked
    0 times
    Rep Power
    55
    I work on Ford E-350 and E-450 busses and after any brake work, the pedal feels like crap. The only way to get the pedal back to normal is to accellerate to 20 MPH and then stand on the brake pedal. This will put it into ABS active mode (pump running and wheel solenoids working) to control the stop. After doing this, the pedal always feels like it should. I don't know if this works on Tundra's, but it is something to try.
    The dealership that I have listed in my garage, will never sell me anything again. My sales person was fantastic! The F&I people are masters of the "straight con" and the "bait and switch". That is my opinion. Update: After ten and a half weeks, the dealership finally made good and cancelled the unwanted insurance and will credit my account with Toyota Financial. Thank you Toni!
  13. #12
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by RONE View Post
    Yes. I can stop without issue, and as you sugested at a stop can push my brake pedal all the way to the floor. I've seen the threads on this, but never noticed this before my brake job. Perhaps it's always been this way but I don't think so. It seems they at least felt firm.
  14. #13
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Quote Originally Posted by gobblerman View Post
    Thanks I'll give this a try.
    By the way sorry about the thread title. I don't know what I was smoking. Unfortunately it cannot be edited.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
