Pictures Oil Filter Housing Upgrade...Thanks Brian! (Jowett Engineering)
+ Reply to Thread
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By StevJ
Thread: Oil Filter Housing Upgrade...Thanks Brian! (Jowett Engineering)
  1. #1
    Supercharged Member socal57chevy's Avatar
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Default Oil Filter Housing Upgrade...Thanks Brian! (Jowett Engineering)
    I had interest in this a long time ago and finally got around to doing it. Brian (Jowett Engineering) verified the fit and I believe he has the aluminum housings available for purchase.
    The perforated tube from your composite housing needs to be transferred to the new housing. To do this, just bend the locking tabs so they point at you as you look into the housing. (90 degree angle) Note the position of the locking tab before bending it so you can bend it back to the original position.
    After bending the locking tabs, push in on the tube and rotate it 90 degrees. It should now come off in your hand when you release pressure.
    Remove the tube from the new housing and transfer the old tube to the new housing. Be sure to bend the locking tabs back into their original position.
    Install new filter and "O" rings, then carry on with your oil change as usual.
    If you think this is as cool as I did...find Jowett Engineering and send him some rep points for doing the research and verifying fit. Thanks Brian.
    Sorry for the fuzzy pic. This is the locking tab that needs to be bent toward you to the 90 degree position. After that, just push in and twist.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Vettelover84's Avatar
    Join Date
    Jul 2010
    Location
    SomewhereBetweenHereandThere
    Age
    30
    Posts
    1,311
    Liked
    77 times
    Rep Power
    28914
    Default Re: Oil Filter Housing Upgrade...Thanks Brian! (Jowett Engineering)
    Awesome!! I saw this awhile back.. Its the Toyota Venza's right?
    I might do this with my next oil change... which will be a bit...
  4. #3
    Veteran Member StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Posts
    1,119
    Liked
    152 times
    Rep Power
    11015
    Quote Originally Posted by Vettelover84 View Post
    Yep. He also gave the part number in his post here.
    Here's the thread, for those interested in some additional details.
    Steve
    Larry Lawton likes this.
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    3. When Noah sends his animals to go forth and multiply, a pair of snakes replies “We can't multiply, we're adders” — so Noah builds them a log table.
    ˇpןɹoʍ ǝɥʇ ɟo sɹǝpuoʍ ǝɥʇ ɟo ǝuo sı ǝpoɔıun ʞuıɥʇ ı
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  5. #4
    Join Date
    Feb 2011
    Location
    Bay Area, California
    Posts
    29
    Liked
    1 times
    Rep Power
    331
    Where to buy the tool to take it off? part number for the tool is appreciated too. I want to do this.
    * 2010 CM 5.7L V8 * TRD Super Rock Warrior Edition * Pro Comp Stage I 6" * 35" Cooper Discoverer STT * 20" Ballistic Off-Road Enigma * 2007 OEM Tow Mirrors * Pro Comp Red Skid Plate *
  6. #5
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Thread Starter
    Quote Originally Posted by Rengsey View Post
    Assenmacher tool probably makes the best one. I believe the P/N is ASTTOY640. Just google it for a supplier.
  7. #6
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1527 times
    Rep Power
    269355
    .... enmacher.
    Sorry, I couldn't help myself.
    Attention environmentalists, reduce emissions from this:
  8. #7
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Thread Starter
    Quote Originally Posted by Mr. Creosote View Post
    .... enmacher.
    ...and to name it ASTOY is the icing on the cake. It's like they were begging people to point and mock.
  9. #8
    Preferred Dealer
    Join Date
    Jan 2008
    Location
    North Adams, Massachusetts
    Posts
    1,170
    Liked
    55 times
    Images
    10
    Rep Power
    4927
    You are welcome.
    Brian
    Jowett Performance
    www.jowettperformance.com
  10. #9
    Supporter Hootbro's Avatar
    Join Date
    Jul 2010
    Location
    Delaware
    Age
    48
    Posts
    381
    Liked
    47 times
    Images
    1
    Rep Power
    1750
    Has anyone broken the plastic one in normal use?
    2010 Tundra DC 4.6L 4x4 (SOLD)
  11. #10
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Thread Starter
    Quote Originally Posted by Hootbro View Post
    Not that I'm aware of, but my oil filter wrench began rounding off the flats on the plastic unit during the last oil change. I didn't want to have to eventually chisel it off, so I opted for some preventive maintenance. This is the part Toyota should have installed in the first place.
  12. #11
    Join Date
    Oct 2009
    Location
    corona
    Posts
    90
    Liked
    2 times
    Rep Power
    289
    Can i ask how much you paid for it? The aluminum filter housing? thx
  13. #12
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Thread Starter
    Quote Originally Posted by ichrisi88 View Post
    I think it was around $35. I bought it and the delay wiper switch at the same time.
  14. #13
    Join Date
    Oct 2009
    Location
    corona
    Posts
    90
    Liked
    2 times
    Rep Power
    289
    Quote Originally Posted by socal57chevy View Post
    That's pretty cheap. I'm going to check the dealer tomorrow since I can get 20% off.
  15. #14
    Join Date
    Jun 2009
    Location
    Oceanside, Ca
    Posts
    2,791
    Liked
    119 times
    Images
    20
    Rep Power
    180317
    Thread Starter
    It's worth every penny, too.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
