DIY 5.7 Serpentine Belt Replacement
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
Like Tree4Likes
Thread: 5.7 Serpentine Belt Replacement
  1. #1
    Rookie BatmanTDK's Avatar
    Join Date
    Jan 2010
    Location
    Georgia
    Posts
    13
    Liked
    5 times
    Thanks
    0
    Rep Power
    0
    Do-It-Yourself 5.7 Serpentine Belt Replacement
    I know there have been several threads on changing the serpentine belt but I did mine recently and put together a DIY guide based on all the stuff I found.
    My advice when attempting to install the new belt, start with getting it around the crankshaft first and work all the pulleys in order and end with the fan pulley. I went with the Gatorback which is a snug fit so i had to be specific in the order. The Tundra or Land Cruiser belt is probably long enough that you can skip my advice .
    The tensioner is pretty strong and a longer handle on your wrench or socket makes it easier. I cheated and used a long handle breaker bar and socket to move the tensioner. There is a hole on the tensioner to lock it in the released position. This hole is about 2-3 inches deep and about the size of a pencil. What I didn't know was that the hole is horizontal.
    Good luck.
    Attached Files Attached Files
    • Rancho QuickLift front shocks and Rancho RS9000XL rear shocks.
    • Ekstrom (Coachbuilder) +2 Shackles and Bushings.
    • Icon Leaf Springs.
    • Volant CAI, prefilter, and Vortice Throttle Body Spacer.
    • BFG AT KOs (275/70/R18).
    • Fumoto oil drain valve.
    • Borla cat backs (2 in:2 2 out).
    • V-LEDS overheads.
    • Bedrug bedliner.
    • Undercover Tonneau.
    • Homelink mirror.
    • TRD Sway bar.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Armystrong's Avatar
    Join Date
    Nov 2009
    Location
    Fort Carson, Colorado Springs
    Posts
    317
    Liked
    6 times
    Thanks
    0
    Images
    34
    Rep Power
    735
    Default Re: 5.7 Serpentine Belt Replacement
    Excellent job! Thank you for taking the time to post this and the tid bits of information making this a very useful DIY job.
    2009 Toyota Tundra CrewMax 5.7L 4x4 SUPERWHITE!
  4. #3
    Junior Member Ra21V12eN's Avatar
    Join Date
    May 2009
    Location
    Oro Valley, AZ
    Posts
    165
    Liked
    6 times
    Thanks
    0
    Rep Power
    3110
    When you did this, why'd you have to take the skid plate off?
    I assume this is to get to the bottom wheels? Also, how much did the replacement serpentine belt cost? I need to do this on my truck and the stealership wants to also replace the water pump at the same time... (NOT NEEDED!!!)
    Great post!
    Chris
    '08 Timberland Mica SR5 5.7 SBDC 4x2 Prodigy P-2
  5. #4
    Supporter eatyourroadkill's Avatar
    Join Date
    Aug 2006
    Location
    Lafayette CO
    Posts
    414
    Liked
    3 times
    Thanks
    0
    Images
    13
    Rep Power
    1874
    nice write up .. pts!
    2007 Tundra 4x4, Nautical Blue, 5.7, SR5, RCSB, NUVI 660, Ipod Nano Gen 3, Truxedo Lo Pro QT, Bedrug, LT295/70/18 Nitto Terra Grapplers, SS Exhaust tip, Stebel Compact truck horn, Auto-Dim w/compass rear view mirror, Silverstar (H11ST, 9005SU, 9145ST). Boston Acoustic S60, Kicker 50x2 Amp, Dynamat, Debadged, 2.5" Lift w/ F&R Bilstein 5100, 1" LRO tapered aluminum block, LRO diff drop, Hypertech inline speedo calibrator
  6. #5
    Hall of Fame Member Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Thanks
    0
    Rep Power
    268069
    Quote Originally Posted by Ra21V12eN View Post
    I found the tensioner was easier to get to from the bottom, hence I removed the skid plate as well. Nothing wrong with leaving it on if you can get it done that way.
    Attention environmentalists, reduce emissions from this:
  7. #6
    Join Date
    Apr 2006
    Location
    Posts
    32,593
    Liked
    1526 times
    Thanks
    0
    Rep Power
    268069
    Have a look around on the front area of the engine block for any pink fluid / residue.
  8. #7
    Join Date
    Jan 2010
    Location
    Georgia
    Posts
    13
    Liked
    5 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    Great post!
    I did take my skid plate off. I took the time to do the belt while letting oil drain out for an oil change. I checked all my pulleys and surfaces for anything unusual. Everything was good.
    I bought my Gatorback on Amazon for about $35.
    Last edited by BatmanTDK; 05-18-2011 at 12:14 AM. Reason: Forgot the second question
    • V-LEDS overheads.
    • Bedrug bedliner.
    • Homelink mirror.
    • TRD Sway bar.
  9. #8
    Join Date
    Jul 2008
    Location
    Apache Junction, AZ
    Posts
    46
    Liked
    1 times
    Thanks
    0
    Rep Power
    7
    great write-up. Wish I had seen it before changing my belt.
  10. #9
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,069
    Liked
    339 times
    Thanks
    0
    Images
    8
    Rep Power
    42560
    Great job on the writeup.
    Points sent.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  11. #10
    Junior Member dawgdays's Avatar
    Join Date
    Jan 2008
    Location
    Atlanta, GA
    Age
    47
    Posts
    430
    Liked
    14 times
    Thanks
    0
    Images
    4
    Rep Power
    12
    Looks ridiculously easy, about how long did it take you to complete this?
    2007 5.7 SR5 4x4 Crewmax, Black with Tan Interior, Bench Seat, Bed Rails, Line-X, Black Oval Raptor Nerfs, Truxedo Lo Pro QT
  12. #11
    Join Date
    Jan 2010
    Location
    Georgia
    Posts
    13
    Liked
    5 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    It didn't take more than maybe about 30 minutes. Most of that was fighting to find the right way to get the Gatorback belt on. It's considerably easier if you get the longer Land Rover belt but I wanted the shorter Gatorback and paid the price in time.
    • V-LEDS overheads.
    • Bedrug bedliner.
    • Homelink mirror.
    • TRD Sway bar.
  13. #12
    Join Date
    Jan 2010
    Location
    Georgia
    Posts
    13
    Liked
    5 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    I did mean to update the thread a while back. So about 5 months after this DIY was posted, I was changing the oil, and noticed this pink crud under the bottom of my engine. Turns out that about 4 months after I did the belt the water pump did start leaking. Just happened to catch it while doing my regular maintenance checks. I probably could have done the replacement but ended up taking it to my dealer. I got a great price on parts and the side bonus for me was I got the coolant flush done as part of the procedure just before the maintenance interval that required it. Took them about 2 hours I think and was about $250 for the whole deal.
    • V-LEDS overheads.
    • Bedrug bedliner.
    • Homelink mirror.
    • TRD Sway bar.
  14. #13
    Junior Member sld92e_23's Avatar
    Join Date
    May 2008
    Location
    Jamaica plain
    Age
    37
    Posts
    103
    Liked
    0 times
    Thanks
    0
    Images
    7
    Rep Power
    13
    " Batman TDK " I have a 2007 with 35K miles and they just did my waterpump for free...you had to pay?
    5.7 IFORCE , 3" toytec , TRD cai, trd dual exhaust, JBA Headers,18x9 moto metal 951 chrome wheels, 295/70-18 nitto trail grapplers, debaged, 35% front tinted windows, low pro truck box, chrome sidesteps, undercover Whelen 6 head strobe kit, eclipse avn726e navigation/dvd,jl audio 500/1 amp, jl audio stealthbox ,color matched door handles,linex spray liner,chrome grille,rear trd swaybar carraige works grills ( center, top and bottom vents)
  15. #14
    Join Date
    Mar 2012
    Location
    Texas
    Posts
    1
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    What did you use for the 5mm bar to stick in the hole to lock the tensioner?
  16. #15
    Join Date
    Feb 2011
    Location
    ohio
    Posts
    5
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    I replaced my belt 3 months ago. Last weak when changing oil noticed antifreeze under waterpump. Bought new wp from NAPA for $65. Took me about 3 hrs to change. My 07 has 90k was surprised it needed a wp.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 10-01-2014, 11:09 AM
  2. 09-03-2013, 01:32 PM
  3. 07-20-2013, 06:02 AM
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
