Switched to Synthetic Oil. How many miles between changes?
+ Reply to Thread
Results 1 to 9 of 9
Thread: Switched to Synthetic Oil. How many miles between changes?
  1. #1
    Veteran Member Dysan911's Avatar
    Join Date
    Dec 2007
    Location
    Florida
    Posts
    819
    Liked
    2 times
    Rep Power
    670
    Default Switched to Synthetic Oil. How many miles between changes?
    I recently switched to Synth. MObil1 to be exact. If traditional oil is recommended to be changed every 5k miles by indication of the idiot light. How far should we be able to go on Synth? I was thinking every 7,500 between changes. If I have to change Mobil 1 every 5k like regular oil then I might as well stay with regular oil right?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member Hippo's Avatar
    Join Date
    May 2010
    Location
    Washington
    Posts
    1,077
    Liked
    284 times
    Images
    8
    Rep Power
    268427
    Default Re: Switched to Synthetic Oil. How many miles between changes?
    I'd go 10K and depending on usage i.e. towing and "city stop n go" traffic vs majority freeway driving.
    My truck specifies 10K intervals but the idiot reminder light still kicks in at 5K. I just manually reset it.
    Pacific NW Hippo
    BMW MOA; '03 K1200RS
    PCA since 1995; '78 911SC, '88 928S4
  4. #3
    Join Date
    Dec 2007
    Location
    Florida
    Posts
    819
    Liked
    2 times
    Rep Power
    670
    Thread Starter
    Quote Originally Posted by Hippo View Post
    Thanks!. The thought of 10k did occur to me, especially with so many newer cars coming out now with much higher than 5k change intervals. I just wasn't sure if that would be pushing it or not.
    THanks!
  5. #4
    Marine Veteran wballen.79's Avatar
    Join Date
    Aug 2007
    Location
    Wilmington, NC
    Age
    36
    Posts
    826
    Liked
    20 times
    Images
    21
    Rep Power
    2961
    Full Synthetic 0w-20 will be a 10k service. The 5k reminder light will still go on to remind you of the tire rotation. That light can not be set to a higher interval so it will come on every 5k.
    As a reminder light, hell, it won't hurt to check your fluids and rotate your tires every 5k. Doesn't cost anything at all to do that if you do it yourself properly. If you go to a dealership if anything it will be $19.95 for the rotation (at least that is what mine is).
    Hope that helped some.
    2012 Radiant Red Toyota Tundra TRD Sport
    Mods: TRD CAI, TRD dual exhaust, TRD anti-sway bar, BHLM, Hitch, Toyota Black Tube Stepbars, Weather Tech In-Channel Vent Shades, MPG Add-on Buttons, Limited Power-Fold Exterior mirrors with Turn Signals, Toyota Tundra tailgate handle rear view mirror/camera,
    Toyota Fender Flairs, Toyota DRL L.E.D. mod, Kenwood DNX-9980
    To Do: ProComp Nitro Leveling kit, "Alwayslooking" front and rear bumpers, TRD Big Brake Kit, TRD Supercharger, and more....
  6. #5
    Supporter Remmy700P's Avatar
    Join Date
    Jan 2008
    Location
    Inland Empire, CA
    Age
    49
    Posts
    8,393
    Liked
    3191 times
    Images
    47
    Rep Power
    162921
    I'd send an oil sample off to Blackstone Labs at 7,500 miles and see where you're at. It's only $25 for the analysis and is the only definitive way to know what your true OCI should be given your own driving habits, environment, etc.
    2002 Tundra V8 SR5 2WD AC
    1C7-Thunder Gray Metallic | Bilstein 5100s | Wheeler's Progressive 3-leaf AAL w/ OL Leaf
    LT265/75R16D1 Nitto Terra Grapplers | Wheeler's Poly Sway Bar Bushing/Bump Stop Set
    eBay T304 SS Headers | Percy's #66080 Header Gaskets | Remflex #8015 Collector Gaskets
    13WL Caliper Upgrade | Hawk Quiet Slot Rotors | Hawk LTS Brake Pads
    Mobil 1 Syn 5W-30 | Mobil 1 Syn ATF | Mobil 1 Syn 75W-90 Gear Oil | Magnefine ATF Filter 3/8"
    Denso #K20R-U Plugs | Russell Speed Bleeders #639570 (7mm)
    Ham Radio: KJ6OPA | CB Radio/Handle: Midland 75-822/"Marksman"
    * * * O2 Sensor Replacement DIY * * *
    "I came into this world covered in someone else's blood and screaming...I'm not afraid to leave it in the same way."
  7. #6
    Veteran Member Vettelover84's Avatar
    Join Date
    Jul 2010
    Location
    SomewhereBetweenHereandThere
    Age
    30
    Posts
    1,311
    Liked
    77 times
    Rep Power
    28915
    I have been debating this too. I will more than likely go 10K miles just because my truck sees pretty light duty...
  8. #7
    Forum Admin Tundradrenalin's Avatar
    Join Date
    Apr 2007
    Location
    Virginia Beach, VA, USA
    Age
    37
    Posts
    8,143
    Liked
    430 times
    Images
    240
    Rep Power
    5011741
    Quote Originally Posted by Remmy700P View Post
    That is by far the best thing to do.
    There are too many variables (driving styles, traffic routines, engine health, etc) to simply say "10,000 miles is your new OTI.". Spend the $25 and get your truck's engine oil an annual physical.
    New to the forum? CLICK HERE!
    Questions about advertising? CLICK HERE!
    Know the facts about Warranties and the Magnuson-Moss Act.
    Link to Amsoil -->
  9. #8
    Lurking Member Mike - '09 DoubleCab's Avatar
    Join Date
    Jul 2009
    Location
    PA
    Posts
    23
    Liked
    0 times
    Images
    8
    Rep Power
    7
    This is very interesting to hear all your opinions. I have also thought about doing the same thing and going with synthetic. My truck sees light duty and barely any dirt or dust other than what is normally found by everyday driving. My dealership (Krause Toyota in Allentown PA) claims you can not extend the interval of oil changes by just simply changing to synthetic. Now I know they want to keep you coming back in so I get their stance on this. I would be intersted in hearing from Toyota that the warranty that still remains on any of our trucks whether it's the original or extended or powertrain will not be voided by going to 10k on the oil changes if using synthetic. I have an '09 so i do not require synthetic according to the manual, I hear the 10's and up require synthetic oil.
    Also, someone mentioned doing tire changes every 5k, I agree with this philosophy and have gotten 100K twice out of BFG Long Trails on my previous vehicle a chevy blazer. I traded it in with 230k on it for the tundra. I recently bought Michelin LTX M/S2 's for the tundra from Sears Auto center and I found out that they have lifetime tire rotation if you buy a set of tires from them. It is covered at ANY Sears Auto center also. Saves me the time and trouble of doing it at home in the garage!!
  10. #9
    Supercharged Member RONE's Avatar
    Join Date
    May 2007
    Location
    Merriam, KS
    Posts
    2,533
    Liked
    53 times
    Rep Power
    6465
    I'm going to have to send a sample of my Mobil 1 full synthetic off to Blackstone to see if my supercharger plays nicely with my oil.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
