Question P2442 Code - Ckeck Engin Light, VSC, and 4L light blinking
+ Reply to Thread
Results 1 to 8 of 8
Thread: P2442 Code - Ckeck Engin Light, VSC, and 4L light blinking
  1. #1
    Join Date
    May 2011
    Location
    Troy, oh
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    I own a 2007 and am having issues with a P2442 code. The dealer told me the secondary air injection pump, and valves need replaced. The quoted price is over $2000.00. With a quote price like that I decided to check into this issue and found out a lot of information about that code on this forum and others.
    After researching the problem I decided to fix the problem myself. I took the injection pump out, cleaned and inspected it. Then hooked it up to my battery and verified it worked ok. I also took the valves out and cleaned them and verified the solenoids worked.
    I feel confident I may have fixed the problem but I don't own a scanner. I went to Auto Zone / Genuine Auto Parts store and barrowed there scanners but there scanners will not clear the code.
    I'm interested in possible purchasing a scanner to clean this fault but I'm not sure what scanner to buy. Does anyone know of a reasonable price scanner which will clean the code listed above? Better yet, I would rather save the money if someone could provide me some information on how to clear this code without taking it back to the dealer or purchasing a scanner.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,150
    Liked
    353 times
    Images
    8
    Rep Power
    42968
    Default Re: P2442 Code - Ckeck Engin Light, VSC, and 4L light blinking
    The P2442 code is "Secondary Air Injection System Switching Valve Stuck Open Bank 2". If the valve is now working correctly the code should clear itself after several "drive cycles".
    The chances that it will stay working for very long are slim to none. I suggest you start by reading this thread.
    2008 Tundra w P2442 issues help needed
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Guest
    Join Date
    Dec 2014
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I have an ElmScan 5 compact scan tool. It reset these codes. Check ScanTool.net
  5. #4
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,150
    Liked
    353 times
    Images
    8
    Rep Power
    42968
    Almost anything can reset the codes. That is not going to solve your problem though.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
  6. #5
    Join Date
    Dec 2005
    Location
    Mechanicsburg, PA
    Posts
    413
    Liked
    87 times
    Rep Power
    3747
    How many miles on your truck? You may be eligible for the 10 year / 150,000 mile coverage on that system, although your dealer should have alerted you to this fact.
    2013 Tundra DC 4X2 4.6l Silver Sky Metallic
    2010 Camry
    2000 Echo
  7. #6
    Junior Member Cremator75's Avatar
    Join Date
    Aug 2012
    Location
    PDX
    Posts
    128
    Liked
    16 times
    Rep Power
    766
    Quote Originally Posted by asc08 View Post
    I have found most dealers will just see if you're willing to pay for the repair first and if you bring up the fact its under any type of warranty then they'll act like they didn't know and fix it for you.
  8. #7
    Junior Member chillson's Avatar
    Join Date
    Apr 2010
    Location
    South Florida
    Posts
    50
    Liked
    3 times
    Rep Power
    391
    Quote Originally Posted by Cremator75 View Post
    Cremator, you are going to the wrong dealerships. Dealerships still make incentives performing warranty recalls on customer vehicles. So there is no reason for them to just implement the recall for you the first time.
    You may have experienced service writers who lack the proper product knowledge.
    With that being said, yes, there is a TSB Warranty Extension for 10 years or 150,000 miles which ever comes first. If your vehicle falls under the described VIN range and you meet the other standards, this is a free replacement for you.
    I had this done to my truck this year. Fixed everything and I have brand new $2000 air injection pumps. I would have never undertaken that job on my own. It is a bunch of work and something you don't want to screw up because you are dealing with the trucks stock computer readings.
    I love lamp.
  9. #8
    Join Date
    Aug 2012
    Location
    PDX
    Posts
    128
    Liked
    16 times
    Rep Power
    766
    Quote Originally Posted by chillson View Post
    Very possible. I had a catalytic converter go bad and purchased a new one from a dealership, after they told me my truck was out of warranty, and had it installed at a muffler shop. That shop told me it should have been under a 100k warranty, so I took the old one back to the dealership and they refunded my money but would not pay for the installation because they didn't have it done.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
