installing front Bilstein 5100 on Tundra 5.7L
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: installing front Bilstein 5100 on Tundra 5.7L
  1. #1
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Default installing front Bilstein 5100 on Tundra 5.7L
    Anyone installed the front shock for the Tundra 5.7L by themselves? Can you give me a quick DIY how to do it? I'm planning to do it myself to save some money. Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member BillyTheKid's Avatar
    Join Date
    May 2010
    Location
    south texas
    Posts
    374
    Liked
    11 times
    Rep Power
    4644
    Default Re: installing front Bilstein 5100 on Tundra 5.7L
    I highly suggest another set of hands if this is your first time doin somethin like this.
    Jack up the truck and put it on some stands. Loosen (do not remove) the lca cam bolts. Remove the swaybar end link bolt then remove the lower strut nut and bolt. Remove the two bolts that connect the spindle to the lower ball joint. Be careful cause the lca arm might swing down if you loosened the cam bolts enough. Now just remove the top four strut nuts and take the coilover out. Only other thing I can think of is.....if you have problems connecting the lower ball join to the spindle you can use a pry bar to pry the uca down or you can stick a jack under the lca to push it up.
    2014 TUNDRA 5.7 4X4 SR5 CM
    7" PRO COMP LIFT - 20X10 BLACK MILLED FUEL KRANKS - 35X12.50X20 COOPER DISCOVERER S/T MAXX - CUSTOM LEATHER - N-FAB SIDE STEPS -HUSKY LINERS - BUSHWACKER POCKET STYLE FENDER FLARES - FLOWMASTER DUAL DUMP EXHAUST - K&N CAI - BLACKED OUT GRILLE AND EMBLEMS
    4wd for Dummies>>>>4WD Simplified Version 4.0
  4. #3
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    Thanks..what kind of spring compressor will I need to get the spring out? Does the one they loan out at Autozone surfice?
  5. #4
    Join Date
    May 2010
    Location
    south texas
    Posts
    374
    Liked
    11 times
    Rep Power
    4644
    I'm not to sure about the spring compressors from autozone. I've heard some stories about the compressors being kinda flimsy. If I were you I would tear both sides down and take them to a shop that has a wall mounted compressor.
  6. #5
    Junior Member Scottie4817's Avatar
    Join Date
    May 2011
    Location
    Plainfield, IL
    Posts
    76
    Liked
    0 times
    Images
    2
    Rep Power
    1488
    Im going to post a DIY tomorrow on this. Stay tuned
    2010 Toyota Tundra 4X4 5.7 V8.
    Car Wash/Wax/Interior all done with Turtle Wax ICE
    Modifications
    • Anytime Fog Lights
    Installed on the truck
    • Craftsman Diamond Plate Toolbox
    • Kenwood VHF Tk-880 Radio (Fire Department)
    http://www.fuelly.com/driver/scottie4817/tundra
  7. #6
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    Quote Originally Posted by Scottie4817 View Post
    Looking forward to it Scottie.
  8. #7
    Junior Member BLamb's Avatar
    Join Date
    Dec 2010
    Location
    Texas
    Posts
    450
    Liked
    11 times
    Images
    24
    Rep Power
    3474
    Also looking forward to this, points your way when it's up! How hard was the install would you say? I did the rears myself but thats not hard at all, also did the bed bounce tsb cab mount replacement myself as well.
  9. #8
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    Quote Originally Posted by BLamb View Post
    Where did you get the parts to do the bed bounce? Truck is no longer under warranty?
  10. #9
    Junior Member TheJackal0398's Avatar
    Join Date
    Apr 2010
    Location
    Concord
    Posts
    106
    Liked
    0 times
    Images
    1
    Rep Power
    119
    If you google how to install lift on 07 tundra it will give you a how to put a spacer lift in. Everything is about the same except strut part. You need to take the strut apart and yeah an autozone strut compressor will work but i wouldn't recommend it. When i did mine the compressor bowed out since the tundra springs are super stiff and dont forget if you are lifting the truck you will need to compress the spring further than normal to allow for the extra lift. I thought i had the wrong shocks at first but i realized the spring purch was adjusted and i had to compress those suckers even more. I would recommend having a buddy around since its kinda difficult putting everything back together.
    2010 Tundra Crewmax 5.7 4x4 SR5 package. Pioneer AVIC-X940BT, 2 10" compvr kicker subwoofers, 300.1zx amp. tinted windows, Flowmaster American Thunder cat back exhaust system with super 40 muffler dual in/out, Bilstein 5100s front and rear, Nitto Terra Grapplers 295/70/18, Bushwacker pocket fender flares, Westin Bull Bar with PIAA 520 ATP lights. Infinity Kappa component speakers.
  11. #10
    Join Date
    Dec 2010
    Location
    Texas
    Posts
    450
    Liked
    11 times
    Images
    24
    Rep Power
    3474
    Quote Originally Posted by randomwalk101 View Post
    Got them from TRD Sparks parts dept delivered to my door. Truck was out of warranty period by the time the TSB came around, dealers don't care that it is a known problem for any of the issues even major ones, they claim since it isn't a recall it is only "suggested and not mandatory".
  12. #11
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    Yup..I have the 07 5.7L too and warranty was out when that TSB came out. How much was the parts and how was the installation. I read teh TSB and it looks like it's a b*tch to intall. I have a torneau on so some weight may subside the bed bounce or do you still recommend me to replace the parts?
  13. #12
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    Couple pics of the Bilstein installed (from another user). Are all these stuffs must be removed to install the shock?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	62853   Click image for larger version.
  14. #13
    Join Date
    Dec 2010
    Location
    Texas
    Posts
    450
    Liked
    11 times
    Images
    24
    Rep Power
    3474
    It was about $220 or so in parts give or take, install wasn't that hard, you have to jack the back of the cab up pretty high to get them out, made me a little nervous, kept rechecking the front bolts to make sure there was enough slack up there, it probably took me about 2 1/2 hours to do because I did it by myself and was going slow to make sure I did everything right. As for the difference, it reduces the "diving board" effect going over some bumps, i'd say it reduces the vibration by about 40-50%, it's still there but is better, so it just depends on how much the bed bounce bothers you as to if its worth the time and money to pursue.
  15. #14
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,095
    Liked
    33 times
    Rep Power
    6877
    Thread Starter
    I'm tempting to do this. When you said jacking the bed up pretty high..How high is pretty high? And also, how do you raise it up that high? I think I can do it, but raising the bed is the part that get me nervous too. Thanks.
  16. #15
    Join Date
    Dec 2010
    Location
    Texas
    Posts
    450
    Liked
    11 times
    Images
    24
    Rep Power
    3474
    it's actually the cab, not the bed, and i'd say you need at least 3.5-4 inches off the frame to pull the old mount off, jack it up from the joint like in the pictures, the instructions in the TSB are pretty good and I just followed those. I used a floor jack with a 4x4 on the circular head part of the jack to give it a little extra height when jacking it up. When they say to loosen the front mounts, take the nut off and then hand tighten it back on, you need all the space on the front.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
