Found: 10 pin connector, EC Mirror
+ Reply to Thread
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By bud-con
Thread: Found: 10 pin connector, EC Mirror
  1. #1
    Join Date
    May 2011
    Location
    Melbourne, FL
    Posts
    17
    Liked
    5 times
    Rep Power
    0
    Default Found: 10 pin connector, EC Mirror
    I bought a 2011 SR5 Tundra a few months ago and wanted to upgrade the mirror. I wanted an EC Mirror with a compass, but didn't need the backup camera. So, I went on-line and found a plug 'n play mirror for the 2007-2009 Tundra, and figured it would work fine in my 2011 Tundra. It's the PT 374-34070 (or 00016-34011) mirror. which is the Gentex 536, and has EC, Compass, Homelink, and the silly shift light. Well, on install I found that I only have the 14 pin connector, and do not have a 10 pin to mate with the new mirror. It was then searched the forums and found that the 10 pin connector was dropped for the 2010 Tundra model year.
    The forums also mentioned that only three pin are needed out of the 14 pin connector. So I searched around and found a suitable 10-pin connector for the mirror side. What I found was a 10-pin USB 1.0 connector for AT/ATX motherboards ... see the link:
    Amazon.com: DUAL USB CONNECTOR, 10 PIN CONN.: Electronics
    This is a USB 1.0 connector for AT/ATX. Note: USB 2.0 connectors are 9-pin. If you go the USB 2.0 route, you will need to drill out a new pin hole in the connector. So I cut-out the unnecessary wires, soldered pins on the three needed wires, and shrink-wrapped. I attached two pictures of the connector, a before and after shot. I used pins off the back of an old hard drive, they fit nicely into the 14-pin socket holes.
    The install was now easy: mounted the mirror, inserted the three pins into the 14-pin connector, slipped the 10-pin connector through the headliner, plugged the 10-pin connector into the mirror, and re-hung the overhead console. All mirror functions tested fine. I still need to program the homelink functions.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	63548   Click image for larger version.
    brew5.7 likes this.
    Bud
    2011 Tundra Double Cab, SR5, 4.6L V8
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supercharged Member RONE's Avatar
    Join Date
    May 2007
    Location
    Merriam, KS
    Posts
    2,533
    Liked
    53 times
    Rep Power
    6465
    Default Re: Found: 10 pin connector, EC Mirror
    Nicely done.
  4. #3
    Mark it eight, Dude... MaylonTRD's Avatar
    Join Date
    Oct 2007
    Location
    Shreveport,LA
    Posts
    4,373
    Liked
    125 times
    Images
    35
    Rep Power
    86844
    Nice write up man! When they discontinued that mirror, sparks toyota and other venders had them really cheap. But like you found out, a lot of guys ended up with mirrors that didn't work with their harness. There was an adapter that they sold for a while and some mirrors even came with it, but now it's hard to find that mirror or that adapter. This is great that you figured out how to do it without it and this should come in handy for some members. Great job and rep points sent to you!
    2014 4Runner Limited Blizzard Pearl- Wife's
    2014 Tundra CM SR5 5.7l TSS Edition Magnetic Gray ProComp 6", XD809 18x9 -12 offset, trail grappler 35x12.50
    2007 Tundra CM SR5 5.7 2WD TRD Slate SOLD
    Skyjacker 6" lift, BFG KO 305/65R18 (33.7"x12.2") XD Hoss Chrome 18x9 +30 offset, Go Rhino Dominator II Nerf Bars, Debadged, AFE Pro Dry Drop-in Craven Speed Stubby Antenna, HomeLink Rear View Mirror, Ranch Hand Grille Guard, Custom Spintech Muffler, Pioneer head unit, RF shallow mount sub, Hypertech Speedo Calibrator
  5. #4
    Join Date
    May 2011
    Location
    Melbourne, FL
    Posts
    17
    Liked
    5 times
    Rep Power
    0
    Thread Starter
    I decided I wanted a longer cable to reduce the possibility of the pins pulling out of the 14 pin socket, so I made another cable. This time I used a USB 2.0 9-pin connector, as it's cable was about 12" long. One of the pins is blocked with a plastic plug, which was easy to pop out from behind, making the connector into a 10-pin socket. When first tried to seat this new connector with the mirror, the pins wouldn't line up. So I removed the seven unneeded socket pins inside the 10-pin connector I just made (I only need three pins: 1,2,6). Now the new connector fits perfectly, and the longer cable gives me piece-of-mind the pins will not pull out 14-pin connector. These cables are pretty easy to make. All the mirror functions (EC, compass, shift light, homelink) tested out fine.
    Bud
  6. #5
    Veteran Member Henry T's Avatar
    Join Date
    Jun 2007
    Location
    chicago IL
    Posts
    1,495
    Liked
    4 times
    Images
    25
    Rep Power
    3036
    I still wanna do this mirror upgrade on my 07. It should be plug and play with that mirror for me right?
    2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, All 4 doors and rear wall Dynamat, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear camera, Interstate Battery Mega Tron Plus MTP27F.
  7. #6
    Join Date
    May 2011
    Location
    Melbourne, FL
    Posts
    17
    Liked
    5 times
    Rep Power
    0
    Thread Starter
    I would assume so. To be sure, you should check behind your overhead console and see if you have a lengthy 10-pin connector.
    FYI - below is a picture of a 4-port PCI USB 2.0 Header. I used one of these to make the longer patch cable for my 2011 Tundra.
Name:	4 Port PCI USB.jpg
    Bud
  8. #7
    Join Date
    May 2003
    Location
    North Central Oklahoma
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default diagram of 10 pin Gentex 536
    I just bought a Gentex 536 and created this diagram of the mirrors connector:
Name:	Gentex 536 Connector Wiring Pin and Color.jpg
  9. #8
    Join Date
    Jan 2007
    Location
    RI
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Just a note there's a Toyota 536 mirror (it has a visible display) and there's Hyundai/Kia 536 hidden display mirror, they are both wired differently. There's also a 536 with a 5 pin connector.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
