P0138 and P0607 codes
+ Reply to Thread
Results 1 to 4 of 4
Thread: P0138 and P0607 codes
  1. #1
    Veteran Member socaliallstar82's Avatar
    Join Date
    Mar 2006
    Location
    Los Angeles
    Posts
    984
    Liked
    18 times
    Images
    8
    Rep Power
    4709
    Default P0138 and P0607 codes
    So my CEL came on saturday morning. No limp mode, everything runs fine. I Figured it was probably nothing big. Came up these codes. I havent gone under the truck yet, but The P0138 code is a O2 sensor code, so Im wondering if the URD O2 sim went bad. The other code is an ECM/PCM failure which doesnt make sense since no limp mode, and the truck runs fine.
    Any one with DT long tubes have this problem?
    5.7 Tundra RCSB- Bolt ons
    14.268 @ 96.15mph "in 3000+ DA"
    358HP/369TQ
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Posts
    1,109
    Liked
    151 times
    Rep Power
    11015
    Default Re: P0138 and P0607 codes
    Something I found
    Quote Originally Posted by ToyotaTechnition View Post
    Most common failure is o2 sensor internal resistance is to high which in return can cause false p0607 ecm failure.
    Steve
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    3. When Noah sends his animals to go forth and multiply, a pair of snakes replies “We can't multiply, we're adders” — so Noah builds them a log table.
    ˇpןɹoʍ ǝɥʇ ɟo sɹǝpuoʍ ǝɥʇ ɟo ǝuo sı ǝpoɔıun ʞuıɥʇ ı
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  4. #3
    Join Date
    Mar 2006
    Location
    Los Angeles
    Posts
    984
    Liked
    18 times
    Images
    8
    Rep Power
    4709
    Thread Starter
    Thanks man! Appreciate it.
    358HP/369TQ
  5. #4
    Join Date
    Mar 2006
    Location
    Los Angeles
    Posts
    984
    Liked
    18 times
    Images
    8
    Rep Power
    4709
    Thread Starter
    So that read the codes for me also cleared the CEL light. Sure enough it came back the next day. 2 days later, it went away by itself. No codes, no CEL. Anyone have this happen? By now Im not too concerned, but just find it odd.
    358HP/369TQ
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
