2010 Tundra Transmission Shift Patterns
NEWS
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Like Tree2Likes
Thread: 2010 Tundra Transmission Shift Patterns
  1. #1
    Rookie parker12 is on a distinguished road.
    Join Date
    Nov 2011
    Location
    NC
    Posts
    3
    Liked
    1 times
    Rep Power
    0
    Default 2010 Tundra Transmission Shift Patterns
    TSB 0285-10 is out there for this issue. Does anyone know if I can have this tsb done for free on a 2010 w/ 54K miles. I bought the truck used and have been having issues with the way the truck down shifts, especially when towing my boat or when using cruise control.
    I did buy as a certified pre-owned with a 100K miles powertrain warranty and I wasn't sure if this tsb was only done on in warranty trucks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some. netranger6 has done just about everything...and then some.
    Join Date
    Dec 2011
    Location
    Texas
    Posts
    146
    Liked
    11 times
    Rep Power
    1021
    Default Re: 2010 Tundra Transmission Shift Patterns
    TSB is good to go in your case. Call the dealer.
  4. #3
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    3,932
    Liked
    128 times
    Images
    8
    Rep Power
    30184
    You should be covered as long as your drive train warranty is in effect.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  5. #4
    Join Date
    Nov 2011
    Location
    NC
    Posts
    3
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Took the truck to the dealer this morning and according to them the computer program update is not covered under the extended powertrain warranty?
    Does anyone know if this for a fact is covered?
  6. #5
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    3,932
    Liked
    128 times
    Images
    8
    Rep Power
    30184
    You should still be covered under the original 5yr/60k power train warranty.
    Might be worth making a call to Toyota.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Scangauge II
    CBTMA member
    Block Off Plate
  7. #6
    Supporter Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla wants you off his porch. Breathing Borla's Avatar
    Join Date
    Apr 2000
    Location
    IL
    Posts
    833
    Liked
    46 times
    Images
    43
    Rep Power
    96085
    why is this on the front of the home page?
    this was out a while back for the 4.6 guys
    2010 Tundra 4x4 5.7 Limited, Slate, TRD RW Wheels with 285's
    http://www.tundrasolutions.com/forums/image.php?type=sigpic&userid=348&dateline=12472564  47
  8. #7
    Join Date
    Nov 2011
    Location
    NC
    Posts
    3
    Liked
    1 times
    Rep Power
    0
    Thread Starter
    Update - was able to get the reprogram taken care of by a different dealer as a warranty item. The truck's shift pattern seems much more in line with what you'd expect as it now holds the gears longer when using cruise control.
    It's always interesting that dealers have differing opinions about what is or isn't covered under warranty.
    Breathing Borla - not sure what you mean?
    macmcalexander likes this.
  9. #8
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    3,932
    Liked
    128 times
    Images
    8
    Rep Power
    30184
    Quote Originally Posted by parker12 View Post
    That seems to have a lot more to do with how honest the dealer is. I suspect the first dealer wanted make you pay for it then bill Toyota for warranty too.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Scangauge II
    CBTMA member
    Block Off Plate
  10. #9
    Rookie ttoyota is on the right track. ttoyota is on the right track. ttoyota is on the right track. ttoyota is on the right track. ttoyota is on the right track. ttoyota's Avatar
    Join Date
    Mar 2006
    Location
    N. Tonawanda
    Posts
    14
    Liked
    0 times
    Rep Power
    0
    I asked my Dealer ( service adviser ) last week if there was some adjustment that could be made
    to keep me in 6th longer and was told no. Maybe something aftermarket. I take it he doesn't know what he's talking about ?
    I have A 2011 4.6 and just drove it from NY to Fla. and back. The truck downshifted for every little hill. I use a scanguage and the mpg loss was very high. I ended up driving most of the trip in 5th. Even on flat land in Fla.
    it would downshift at overpasses going 75. Seems a little ridiculous. I averaged 19 mpg. going and 18.8
    coming back with 4 people and a truck full of stuff. in 5th.
    2011 Tundra DC 4.6
    2006 Lexus ES330
    2002 Four Winns 190 Horizon
  11. #10
    Rookie toyotec56 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Gainesville,fl
    Posts
    2
    Liked
    1 times
    Rep Power
    0
    hi i work for toyota theres a few ways to do it, your truck is under powertrain warranty which it 6yr/60k some times it will throw shift soleniod codes, first step in fixing it is flushing the tranny, i have an 06 double cab and it was downshifting very hard from 2nd to first i flushed the tranny and its good. if your truck has a world standard sealed tranny it can get pretty expensive i used over 12 quarts of fluid. flushing world standard trannys have fixed almost every shift concern ive had a tundras and tacomas.
    and most extended warrantys will not cover things like reflashes cause they want to see an actual defective or broken part i have a 2006 seinna van 2gr engine completly torn down in my bay and fidelity warranty will not cover any of it cause theres no physical damage. the pistons were below spec and slapping around the cylinder wall making noise
    TUNDRAMIAMI likes this.
  12. #11
    OTR
    OTR is offline
    Veteran Member OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR is a splendid one to behold. OTR's Avatar
    Join Date
    May 2007
    Location
    Everywhere
    Posts
    752
    Liked
    14 times
    Images
    6
    Rep Power
    20
    Quote Originally Posted by toyotec56 View Post
    Note to self: Never by an extended warranty through Fidelity.
    Also, why doesn't the owner of the van go on a little trip down the highway in 3rd gear with the engine at 5k RPM until there is "physical" damage to the engine. It shouldn't take long for that to happen per your description. It sucks that a person would have to do something like that in order to a claim covered that should be covered to begin with. That is why I only purchase an extended warranty through the manufacturer only.
  13. #12
    Rookie jaddiz is on a distinguished road. jaddiz's Avatar
    Join Date
    Dec 2011
    Location
    lakeview ar
    Posts
    5
    Liked
    0 times
    Rep Power
    0
    I'm Sr Claim Adjuster with Auto Services Company & Route 66. Depending on the policy we will cover reflash/reprograming.... as far as the worn valve body bores not sure what there problem is. Even the most basic powertain plan covers valve body failure!
    This is my first tundra, I have a 10, mine is great, BEST truck I ever bought.
    Black 2010 2WD DBL CB 4.6L Auto (base)
    *current add-ons:
    Tonno pro Tri fold tonneau cover; Tinted- side windows 25% rear 18% &5% brow 7" down; receiver hitch; Toyota Bed Liner
    *future add-ons:
    nurf bars, pinstripes,grill, vent visors, bug shield (maybe)
  14. #13
    Rookie garage4 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    italy
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Sorry, I'm new....
    I have a quastion for you..
    Where I can found the vin number on the frame on my 2010 tundra, because I can not find it.
    Maybe if you can send me a photo of part of the frame where it is stamped in vin number.
    Thank and best regards,
    francesco
  15. #14
    Rookie offroadman1973 is on a distinguished road.
    Join Date
    Jan 2012
    Location
    mc allen, tx
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    what exactly is this TSB?
  16. #15
    Junior Member AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light. AnchoRager is a glorious beacon of light.
    Join Date
    Apr 2011
    Location
    Alaska
    Posts
    51
    Liked
    0 times
    Rep Power
    168
    Technical Service Bulletin - tell the techs how to fix and tweak certain things.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
