Will towing mirrors that fit a 2009 Tundra fit a 2012 Tundra?
+ Reply to Thread
Results 1 to 9 of 9
Thread: Will towing mirrors that fit a 2009 Tundra fit a 2012 Tundra?
  1. #1
    Join Date
    Jan 2012
    Location
    Rineyville, KY
    Posts
    47
    Liked
    3 times
    Rep Power
    17
    Default Will towing mirrors that fit a 2009 Tundra fit a 2012 Tundra?
    I want to replace the OEM mirrors on our 2012 Tundra with tow package and wonder if mirrors specified for a 2009 Tundra will fit?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Apr 2010
    Location
    Westchester, NY
    Posts
    79
    Liked
    3 times
    Rep Power
    5
    Default Re: Will towing mirrors that fit a 2009 Tundra fit a 2012 Tundra?
    Yes they will bolt up and fit the same but for 2009 there is No power folding mirror unless you did the Mod with the switch..
    hope this helps
    good luck!
  4. #3
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    bolt pattern is the same through out years. wiring will not plug and play however.
  5. #4
    Supporter PowerHogger's Avatar
    Join Date
    Oct 2008
    Location
    Houston, TX
    Posts
    733
    Liked
    12 times
    Images
    16
    Rep Power
    1166
    Why won't wiring be plug in and play?
    The IForce is strong with this one
    5.7 RCSB Tundra
    TRD Sway Bar
    Tint 35% front, 15% back
    K&N drop in filter-Now back to stock!
    DIY Dash black out
    5000k lows and 4300k fogs from DDMtuning
    Access Lorado tonneau
    Ebay Led Everything
    MPG BUTTONS
    White LED Dash lights & Radio
    Limited 20"s
    TRD duals with Corsa 14635
    Broadway Mirror 360mm
    2010 Grille & Tails
  6. #5
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    i would like to answer you question with a question. where is the folding mirror park switch? the wire schematic shows wires that are not im my jack plug with an optional switch, relay, and fuse. should i have said my truck wouldn't be a plug and play?
  7. #6
    Join Date
    Oct 2008
    Location
    Houston, TX
    Posts
    733
    Liked
    12 times
    Images
    16
    Rep Power
    1166
    Maybe some clarification is needed here so it won't confuse others as it did me. The harnesses do plug in together but some features MAY be missing ex: power fold which only comes on the newer model tow mirrors. Well if the OP's truck is a limited, I don't see why every single option wouldn't work, even power fold since the stock limited mirrors should have them.
    5.7 RCSB Tundra
    TRD Sway Bar
    DIY Dash black out
    Ebay Led Everything
    MPG BUTTONS
    Limited 20"s
    2010 Grille & Tails
  8. #7
    Join Date
    Jan 2012
    Location
    Rineyville, KY
    Posts
    47
    Liked
    3 times
    Rep Power
    17
    Thread Starter
    Thanks for the info on the compatibility of the mirrors. I have a work truck with no electric fold option. In fact I didn't know there was such an option. I wish I had negotiated OEM tow mirrors when we bought the truck. I hope the after market mirrors are good quality. (Tic_Tuning)
  9. #8
    Join Date
    Oct 2007
    Location
    PALM DESERT
    Posts
    84
    Liked
    10 times
    Rep Power
    1302
    Which ones did you order? Off Ebay?
    I see the mirrors on Ebay and they all "look" the same. I wonder if they are all made by the sameChinese factory.
    Can anyone chime in and link to which Ebay units they bought to verify quality and fit.
    Thanks.
  10. #9
    Join Date
    Jan 2012
    Location
    Rineyville, KY
    Posts
    47
    Liked
    3 times
    Rep Power
    17
    Thread Starter
    Quote Originally Posted by RUSTYDAWG View Post
    Thanks.
    I haven't ordered mirrors yet. I contacted the Toyota Dealer where we bought the truck a couple months ago and they said there were no towing mirrors available. I called another Toyota dealer and was told that towing mirrors are $278.09 each!!!!
    The ones that I am looking at are on eBay. I sure would like to know about the quality of these mirrors.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
