What does the TOW/HAUL button really do?
+ Reply to Thread
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By KingLou
Thread: What does the TOW/HAUL button really do?
  1. #1
    Join Date
    Feb 2012
    Location
    Yakima, WA
    Posts
    10
    Liked
    2 times
    Rep Power
    0
    Default What does the TOW/HAUL button really do?
    Just finished reading the owner's manual for my new '12 CrewMax TRD Offroad... no mention of what the TOW/HAUL button does, just to push it when towing. Anyone know technically what it does (other than make the light in the dash come on)?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Lurking Member KingLou's Avatar
    Join Date
    Apr 2009
    Location
    Vegas
    Age
    32
    Posts
    21
    Liked
    1 times
    Rep Power
    7
    Default Re: What does the TOW/HAUL button really do?
    My understanding of it is that it just changes the shifting characteristics of the transmission to more effective for towing. I think it holds gears till higher RPMs, and downshifts a bit more aggressively for some "engine braking" effect. I could be wrong, and welcome any more knowledgeable comments.
    mendonsy likes this.
  4. #3
    GWD
    GWD is offline
    Junior Member GWD's Avatar
    Join Date
    Feb 2009
    Location
    Vacaville, CA
    Posts
    442
    Liked
    45 times
    Images
    3
    Rep Power
    2081
    Try searching this forum. Lots of information and opinions.
    Plus, drive it around with the "tow" on and experience the difference in upshifting, downshifting, shift points, an transmission braking. Probably more.
    2010 Tundra DC, 5.7, 4WD, SR5, 40/20/40 Bench Seat, Pyrite Mica,
    Options: Model 8341, EC, EV, CK, LF, RL, SP, ST, TM, WX, 32, HR, CT, CJ
    GO Industries Rugged Step, LineX bed, Line-X Xtra on steps, ARE shell, Firestone RideRite, Prodigy brake controller, TRD chrome wheels
  5. #4
    Join Date
    Feb 2012
    Location
    San Diego, CA
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    As others have stated, it just changes the shifting points so you're typically on a lower gear revving higher. You'll get crappier gas mileage and it will be harder on the engine and transmission.
  6. #5
    Join Date
    Feb 2012
    Location
    Yakima, WA
    Posts
    10
    Liked
    2 times
    Rep Power
    0
    Thread Starter
    Quote Originally Posted by GWD View Post
    My aplogies guys, I tried searching and didn't find much but then tried again this morning and found what I was looking for. Check this thread, it contains the technical explanation I was looking for. Sorry for the FNG mistake!
  7. #6
    Join Date
    Sep 2011
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Rep Power
    4
    When is the tow/haul button required to be turn on? How much do you have to tow for it to be effective? Do i need to turn on this button if I am only towing 1000 lbs (towing my jet ski).
  8. #7
    Join Date
    Jul 2011
    Location
    Winfield TX
    Posts
    194
    Liked
    21 times
    Rep Power
    0
    not trying to jack this thread but, a few days ago I hit the tow/haul button while I was going around 55 or so and the truck jerked like if it had a bad transmission...you guys think I screwed something up??
  9. #8
    GWD
    GWD is offline
    Join Date
    Feb 2009
    Location
    Vacaville, CA
    Posts
    442
    Liked
    45 times
    Images
    3
    Rep Power
    2081
    No problem. Not any more serious that stomping on it and downshifting.
  10. #9
    Veteran Member bill3508's Avatar
    Join Date
    Oct 2008
    Location
    Atlanta
    Posts
    1,135
    Liked
    8 times
    Images
    8
    Rep Power
    1285
    Quote Originally Posted by krouchchocolate View Post
    Not really needed but it will help you stay in gear longer. A proper tow haul button would lock out overdrive, but ours doesn't do that, only extends the rpm's between shifts. No one should be towing much more than a small trailer in 6th and the real towing gear is 4th as both 5 and 6th gears are overdrives in the Tundra.
    04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40 (Gone)
    2010 Slate DC LB 4X4 W/T, Injen CAI, Unichip, Pulstar Iridium, Amsoil Signature 0w-30, Nfab wheel to wheel 6 step, Spintech Sportsman Street XL muffler #3247, Jegs H-Pipe, Bilstein HD shocks, Truck Covers USA Cover, Nitro 4.88 gears, Auburn Pro LSD, SuperSprings SSA4.
    AIP Solution: Disconnect both air pumps. You will get a CEL ( Codes P0418,P0419)but no limp mode and no affect on performance. AIP system will be shut down preventing valves from opening. There are two pump connectors, one behind the coolant reservoir on the front of the engine and one below the air box along the wheel well. Both are large gray connectors. Disconnect them, tape them up, zip tie them to keep them from getting into anything hot or moving and your done. If you need service done, reconnect them before you take the truck to the dealer. Enjoy.
  11. #10
    Junior Member Paul312612's Avatar
    Join Date
    Apr 2008
    Location
    Cheshire CT
    Posts
    92
    Liked
    0 times
    Rep Power
    8
    So is there a minimum weight that is being hauled or towed before you need to push it? I mean a 2000lb trailer? Not sure, I know when I load up the bed with wood, I use it. Just Curious.
    “Freedom is never more than one generation away from extinction." Ronald Reagan
    2011 Black D/C 5.7 Tundra Grade, Tow Pkg, Cold Pkg
    EGR In-Channel Rain Guards Lund 5" Oval Nerf Bars
  12. #11
    Veteran Member RRzxter's Avatar
    Join Date
    May 2011
    Location
    Buffalo, NY
    Posts
    787
    Liked
    118 times
    Rep Power
    5172
    Every time you push it, god kills a kitten.
  13. #12
    Veteran Member StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Age
    100
    Posts
    1,104
    Liked
    148 times
    Rep Power
    11015
    Quote Originally Posted by TrailCruiser View Post
    Here you go:
    Holy Crap the TOW Button!
    Steve
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    3. When Noah sends his animals to go forth and multiply, a pair of snakes replies “We can't multiply, we're adders” — so Noah builds them a log table.
    ˇpןɹoʍ ǝɥʇ ɟo sɹǝpuoʍ ǝɥʇ ɟo ǝuo sı ǝpoɔıun ʞuıɥʇ ı
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  14. #13
    Junior Member 11Tundra's Avatar
    Join Date
    Jan 2012
    Location
    United States
    Posts
    457
    Liked
    113 times
    Rep Power
    2818
    Quote Originally Posted by bongarone View Post
    Harder on the engine and transmission? I disagree. With the tow/haul switch off, the ECU puts a priority on fuel efficiency and typically has the tranny shifting as soon as possible to the next higher gear thereby loading the engine at the lowest possible rpm. When under load or towing, the tow/haul switch does the exact opposite. It puts a priority on keeping the engine revs higher (especially between shifts) and reduces excessive engine loading at low rpm's. This, in-turn, lowers the need for transmission upshifts & downshifts, reducing wear & tear on the tranny--especially the clutches.
  15. #14
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1157
    If you want to impress your wife/girlfriend, neighbors, etc., just turn off the VSC, turn on the Tow/Haul. and put the pedal to the floor....instantaneous thrill for everybody!
    I tow my 2000 boat with it Off, turn it on for my 5500lbs travel trailer. Keep in mind that it is disabled in "S" mode.
    '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
  16. #15
    Junior Member ct03911's Avatar
    Join Date
    Mar 2010
    Location
    CT
    Posts
    279
    Liked
    20 times
    Rep Power
    7
    In my opinion it does not do much. I am towing a fair amount of weight though so the Truck holds all shifts a long time.
    I have it on towing 3400lbs of empty trailer and 7k loaded but with the drag of a 7' high trailer too.
    I have only towed the 2011 I have some 1200 miles.
    I found "S" mode to be the way to go much of the time to control it more but am still pllaying with it.
    * CURRENTLY FOR SALE *
    '11 Tundra Doublecab, 4x4, SR5, TRD, Tow, Moroso Air/Oil Separator, LineX bedliner, Venture clear bra
    Coated in P21S wax, the best there is....
    '12 ZO6
    '13 Harley Street Glide
    '11 24' Featherlite enclosed car hauler
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
