DIY Trying to Install a 3'' Strut Spacer Lift Help!!!!!
+ Reply to Thread
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By deviltundra
Thread: Trying to Install a 3'' Strut Spacer Lift Help!!!!!
  1. #1
    Join Date
    Nov 2010
    Location
    San Diego
    Posts
    6
    Liked
    2 times
    Rep Power
    0
    Angry Trying to Install a 3'' Strut Spacer Lift Help!!!!!
    Hey guys, I just purchased a strut spacer lift from ebay. It's a 3'' Spacer lift that sits ontop of the strut, the ebay website says handtools and a floor jack. No strut dissassembly. I just wanted to see if anyone could advise me on how to install them. I have an 05 Toyota Tundra SR5.
    If anyone could help I would appreciate it!!
    1999-2006 Toyota Tundra 3" Leveling Lift Kit 2WD 4WD | eBay
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter sfoote's Avatar
    Join Date
    Apr 2011
    Location
    Los Lunas, NM
    Age
    37
    Posts
    184
    Liked
    53 times
    Images
    3
    Rep Power
    1829
    Default Re: Trying to Install a 3'' Strut Spacer Lift Help!!!!!
    From what I can see it looks like all you need to do is remove the strut from the vehicle and insert these spacers between the top of the strut and the strut tower. You may need new fasteners (bolts, nuts, washers, etc) if the kit does not come with this stuff.
    I'm sure you can find a write-up on strut removal, its pretty simple.
    The reason (I believe) that no strut disassembly is required is because from what I saw in the ad these are just spacers that go ON TOP of the strut...in other words there are no pre-load spacers that need to be installed. Pre-load spacers would require you to take the strut apart and probably would require a strut compressor.
    Again, this is just my "first-glance" assessment, I could be wrong. Make sure you understand what you are buying before you buy it.
    2011 "Pebble-Warrior"
    5.7L DC
    Mods (in order of install):
    Truxx 3/1 (Replaced with ICON's), WeatherTech Floormats, Pro Comp Add-A-Leaf(s), do-it-yourself steps (w/Line-x), Total Chaos Upper Control Arms, AFE Stage II CAI, Racor Spin-On Tranny Bypass, Line-x (bed, over-rail), Corsa Sport Exhaust, UWS Low-Profile Toolbox (w/Line-x), Sprint Booster, Mac's Tie Downs, ARB High Performance twin air compressor w/air up kit, (2)-1 gallon VIAIR storage tanks, Big Sky 2-Gun Rack, Front/Rear ARB Lockers, Nitro 4.88's Front and Rear, Hypertech Speedometer/Odo Recalibration Unit, (5) 35x12.5 Nitto Trail Grapplers, (5) 18x9 Fuel Boost Wheels, Body Mount Chop, 4.5" Rough Country Lift (ICON's in front, FOX shocks in rear), do-it-yourself headache rack, Apache Bullnose Front Bumper (Replaced With Demello), Fumoto Oil Drain Valve, Fox 2.0 Rear Shocks, Firestone Ride-Rite Air Bags, Dakota Digital Gauges (for ARB System and Air Bags), Craven Speed Gauge Pods, PIA LED Foglamps, Hypertech Interceptor, Custom Rear Driveshaft, Demello Offroad Bumper, Craven Speed Stubby Antenna.
  4. #3
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    oh yeah its super easy. jack, and block up the front end releasing pressure off the wheels. use a floor jack to compress the shocks a very little bit. undo the three top strut bolts; then lower the floor jack slowly. install the new spacer, reassemble, and torque the bolts. shortly after follow up with a full alignment.
    WannaRedTundra and Barrow214 like this.
  5. #4
    Junior Member Brandan86's Avatar
    Join Date
    Aug 2011
    Location
    San Antonio Texas
    Posts
    390
    Liked
    50 times
    Images
    2
    Rep Power
    12083
    What devil said is right. then post pics, as I will be doing this very soon.
    2001 AC SR5
    iDiy
    200k Club
    K&N drop in filter, Satin Black Eagle Alloy Series 102 wheels, Bilstein 5100s, 265/27-16 Hankook DynaPro ATM, Magnaflow 14inch Muffler.
  6. #5
    Join Date
    Nov 2010
    Location
    San Diego
    Posts
    6
    Liked
    2 times
    Rep Power
    0
    Thread Starter
    Thank you Devil! I appreciate it man!
  7. #6
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    sometimes we all just need a little moral push, i sure you could have done it alone. let me know if you run in to problems. just pm me, i could probably hook you up with a manual link.
  8. #7
    Join Date
    Nov 2010
    Location
    San Diego
    Posts
    6
    Liked
    2 times
    Rep Power
    0
    Thread Starter
    Is there anyway you could hook me up with a manual link? I just want to go over it before I start tearing down my struts. I'd really appreciate it!!
  9. #8
    Join Date
    Feb 2012
    Location
    Mandeville, louisiana
    Posts
    20
    Liked
    4 times
    Rep Power
    4
    On my 2000 all I had to do was, unbolt the swaybar link, take the 3 nuts off the top strutmount, remove lower shock bolt, pull the unit out, put the spacer on top and bolt down with nuts off original mount. remove the 4 bolts that hold the lower control arm to the spindle while having a jack under it. lower lower control arm enough to get shock assembly back in, jack back up to the spindle reinstall bolts and swaybar link. Good to go.
  10. #9
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
  11. #10
    Join Date
    May 2013
    Location
    Oahu
    Posts
    24
    Liked
    0 times
    Rep Power
    3
    Click image for larger version.
    Quote Originally Posted by sdm111 View Post
    this would be it right? The 4 bolts
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
