Steering wheel shake! help!!
+ Reply to Thread
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By DWarner6371
Thread: Steering wheel shake! help!!
  1. #1
    Rookie trdtundrasport is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Ga
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Steering wheel shake! help!!
    Im new to the tundra solution and i have a question. When i hit around 55-80 mph my steering wheel starts to shake pretty bad, and i did get the wheels balanced and got alighnment. And its a 2010 toyota tundra 4.6L 4X4
    Has anyone had this before on a 4X4?
    How do i get rid of it?
    Thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Ky King Tundra is on a distinguished road.
    Join Date
    Jan 2012
    Location
    Lexington Ky
    Posts
    81
    Liked
    9 times
    Images
    12
    Rep Power
    2
    Default Re: Steering wheel shake! help!!
    Mine did this a little after I put on a lift kit recently. I got it re Aligned and made sure the camber was 0 degrees and then balanced and rotated well and it fixed it up fine. where did you get yours balanced at. I found out that a company i had been using for years actually were using wheel balancing machines that were broken and were making the tires worse. Make sure you get it done somewhere credible.
    08 tundra radiant red 5.7 double cab
    Ballistic Wizards 20x9
    Nitto Trail Grapplers 295/60/R20 ( 34.5x11.8x20)
    Low Range Off Raod 3/1 Leveling Kit
    Leather ,Heated seats, Cd/DVD navigation
    Blue tooth
    Truxedo bed cover
    Black headlight mod
    Chrome DeeZee running boards
    K & N air Filter
    Blacked Out Badges
    Sun Roof
    Front Windows Tint Match
    In Channel Vent Visors
  4. #3
    Lurking Member DWarner6371 is on a distinguished road.
    Join Date
    Aug 2007
    Location
    Enfield, CT
    Posts
    31
    Liked
    2 times
    Rep Power
    6
    Rotate the tire to the rear of your truck and see if the shake changes. Could be a bad tire or bent rim but the place that balanced your tires should have seen that.
    tundra4ever26 likes this.
  5. #4
    Veteran Member JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD is more than famous, they're infamous. JMSinMD's Avatar
    Join Date
    Aug 2006
    Location
    Maryland
    Posts
    1,481
    Liked
    19 times
    Rep Power
    2761
    Your problem sounds like a balancing issue, not an alignment issue. I'd have the dealership do a high speed balance/"road force" balance to see if that addresses it. If not then you've got to start looking at the wheels/tires to see if they are out of round which is causing the imbalance.
    Modifications: debadged/30% tint over factory with 20% front/LED rear foglights in place of reflectors/White Knight reverse light system/V-LEDS reverse light LPF/Silverstar Ultra(halogen high beam/fog light)/Lexus LS460 bi-xenon HID projectors/Philips DRL8/Ravelco anti-theft/Lockpic navigation override/locking gas cap/TRD intake flow accelerator/K&N panel filter/K&N filter minder/5000k LED license plate bulbs/Big Daddy upgraded horns/SET exhaust tip/factory color matched (B&I SEQUOIA emblem insert, brake calipers, side-view mirrors, b-pillars, c-pillars)/summer 22” Giovanna Caracas w/Yokohama Parada 305/45/22/winter 18" OEM steel wheels powder-coated black w/Bridgestone Dueler A/T "Revo 2" 255/70/18
    For Sale- Custom driving light bracket with 4 Hella Black Magic 500 series driving lights $150 shipped (MADE TO WORK WITH PLATINUM MODELS, WILL WORK WITH SR5/LIMITED AS WELL)
    http://imageshack.us/g/571/new015.jpg/
  6. #5
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,561
    Liked
    194 times
    Images
    8
    Rep Power
    32267
    Do you have alloy wheels???
    If someone installed them with an impact wrench that might cause your problem. They must be torqued to 97 ft/lb with a torque wrench when they are installed.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  7. #6
    Junior Member Djackman777 is on the right track. Djackman777 is on the right track. Djackman777's Avatar
    Join Date
    Jun 2007
    Location
    Cali
    Posts
    455
    Liked
    1 times
    Rep Power
    6
  8. #7
    Join Date
    Jun 2007
    Location
    Cali
    Posts
    455
    Liked
    1 times
    Rep Power
    6
    Its all about the balancing. Got it balanced 3 times within a year and they finally goy it right. Try to have the tech install the weight both inner and outter side of the wheels, it worked for my hard-to-ballance 22s
  9. #8
    Lurking Member M@D-M@X is on a distinguished road. M@D-M@X's Avatar
    Join Date
    Nov 2004
    Location
    S.Fla. USA
    Posts
    47
    Liked
    7 times
    Rep Power
    9
    I recently bought a used 2010 and it had that issue until I got around to rotating, balancing and alignment of the wheels.
    As many have mentioned, it's most likely a balancing issue and at times it is your shock absorbers.
    To rule out the shocks, push with your weight down on the front bumper and let off.
    If your truck comes right up to where it was in one shot, then they are good.
    If your truck kinda bounces several times until it stops or has a bouncy ride then your shocks are bad.
    Good Luck
    Max
  10. #9
    Veteran Member SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold. SR5NEWBIE is a splendid one to behold.
    Join Date
    Dec 2007
    Location
    BURLESON, TX
    Posts
    576
    Liked
    0 times
    Rep Power
    11
    Mine shakes at 70 mph. Bought new tires, wheels and it still does it. But get this, not all the freaking time. Just most of the time. There are times that it drives smooth as a baby's butt. Between the front end shake, front tires wearing, and the crappy brakes that warp, this truck is junk and no longer fun to drive.
    You can try retorquing the wheels to factory specs. Mags are approx 98 ft/lbs and make sure the surface and wheel itself is clean.
    I have never had so much trouble from a truck in my life. I have owned Chevy most of my life.
    2007 White DCSB, Drop in K&N filter, Flomaster 70 series replacement muffler. (no cat back)
  11. #10
    Veteran Member deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points.
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,453
    Liked
    154 times
    Images
    13
    Rep Power
    9436
    Attachment 84234this and balance.
  12. #11
    Rookie WesCole is on a distinguished road.
    Join Date
    Jun 2011
    Location
    Texas
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    My 2008 Tundra had a bad steering wheel shake at about 65+ mph. I bought it brand new with a 3/1 lift and 275/70/18 tires. I tried two sets of wheels and tires, road force balancing, alignments, balancing beads, load-match balancing, new shocks, etc. I took it to my dealership at least 15 times in 2 and 1/2 years and to Discount Tire almost as much. No one could ever figure it out. I ended up trading it for a 2011 GMC Z71 Duramax. I still have no idea what was wrong with it. if you figure it out, please post the remedy because I am still curious what was causing my steering wheel shake.
  13. #12
    Lurking Member eric102 is on a distinguished road.
    Join Date
    Sep 2007
    Location
    Pacific NW
    Posts
    48
    Liked
    0 times
    Rep Power
    6
    My 07 shook at 55-65 randomly for several years since I bought it new, some days it was fine, others it shook, numerous attempts at balancing were fruitless. I finally pitched the stock junk tires and put on some good Michelin's and its been smooth as silk since then.
  14. #13
    Lurking Member Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some. Downeaster2011 has done just about everything...and then some.
    Join Date
    Nov 2011
    Location
    Waterford, ME
    Posts
    27
    Liked
    2 times
    Rep Power
    790
    Warped Rotors! Either have them turned or replace with new.
  15. #14
    Rookie jbpruitt is on a distinguished road.
    Join Date
    Apr 2010
    Location
    n/a
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    3 sets of tires 2 diff sets of wheels still shaking, but not all the time, fixing to sell or trade it.
    2010 trd dc 4x4 back to stock rims with michelin ltx at 2 new tires (3 diff sets) no one can get the
    shakes out, besides windshield creaks and pops, air induction pump screams when its cold out.
    may be going back to titan 100,00 miles trouble free with it.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
