oil gauge ??
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Like Tree4Likes
Thread: oil gauge ??
  1. #1
    Junior Member tundra4ever26's Avatar
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Question oil gauge ??
    hey guys,
    this morning and i think for the first time the oil gauge(the one of the bottom right) catches my eyes, and im worried a bit.
    so the quick question:
    is it normal the oil pressure increase like two bars (white slashes) when you accelerate? I got 11k on a 2011 CM and have changed the oil twice first time @ 4k second time @ 8k and btw I got FF but i dont use the e85
    thx.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    Default Re: oil gauge ??
    after some google search i guess it normal, i think i just noticed that but is it ok to reach 75%?
  4. #3
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    if you think its oil related, change the oil anyway. oil, and coolant is the blood of your car. you take care of it.
  5. #4
    Junior Member Fordless's Avatar
    Join Date
    Jan 2011
    Location
    Auburn, AL
    Posts
    72
    Liked
    8 times
    Rep Power
    390
    It's normal...as you acclerate at higher rpms your oil pump is turning faster and there for producing higher oil pressure. The oil pressure gauge on the tundra seems to be slow to respond but fairly accurate. If you'll notice you'll run higher pressure when the engine is cold b/c of the thick oil. Just be sure to not acclerate heavily with the engine cold b/c the engine will not oil properly. I try to stay below 2K rpm until engine is warm.
    tundra3400 likes this.
    2015 Tundra DC SR5+ 4.6L MGM
    2007 Tundra DC Limited 5.7L 4x4 Slate Metallic - Graphite Leather (Sold but missed)
  6. #5
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    hmm just tried a Lexus 570 the gauge shows 25% when car is not moving, on high acceleration it would reach 50% - 60%. on the other hand, the tundra show 40% - 50% at stop, on acceleration it could reach to 75% - 80%. is it normal guys?
  7. #6
    Supercharged Member tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    what kind of oil are you running (synthetic or conventional) and what is the weight (i.e. 5w 30)?
    2000 Tundra 1A0 Platinum Metallic 3.4L V6 SR5 AC 4WD, 212,000 miles and counting, Husky Liners, 5K 36 Watt LED Heads & 5K 60 Watt LED Fogs w/ Fog Mod from IZL, LED Cargo Light, Pioneer 3300UB, redruM69's Quarter Window Arm Mod, Kicker 8" with Custom Box, New Frame via The Rust Recall, 5100s on 3rd Notch, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & LEDs, Curt Tow Hitch, Keyless Entry, ES Rack Bushings, 30" SR Offroad LED Bar (Install Click here), Uniden PRO 520XL CB, 4in LED Reverse Lights (Install Click Here), 255/85r16 BFG KM2s
    CBTMA Member
    Sometime in the Future:
    Lock-Rite (maybe)
  8. #7
    Veteran Member bill3508's Avatar
    Join Date
    Oct 2008
    Location
    Atlanta
    Posts
    1,135
    Liked
    8 times
    Images
    8
    Rep Power
    1285
    Yes its normal, you will always have a increase in oil pressure with an increase in rpms.
    04 TRD AC 4X4,JBA headers,True Flow intake w/K&N drop-in, Spintech Sportsman Street XL muffler, NGK TR6ix plugs, new Denso 234-4209 o2 sensors,Mobil 1 Syn 0W-40 (Gone)
    2010 Slate DC LB 4X4 W/T, Injen CAI, Unichip, Pulstar Iridium, Amsoil Signature 0w-30, Nfab wheel to wheel 6 step, Spintech Sportsman Street XL muffler #3247, Jegs H-Pipe, Bilstein HD shocks, Truck Covers USA Cover, Nitro 4.88 gears, Auburn Pro LSD, SuperSprings SSA4.
    AIP Solution: Disconnect both air pumps. You will get a CEL ( Codes P0418,P0419)but no limp mode and no affect on performance. AIP system will be shut down preventing valves from opening. There are two pump connectors, one behind the coolant reservoir on the front of the engine and one below the air box along the wheel well. Both are large gray connectors. Disconnect them, tape them up, zip tie them to keep them from getting into anything hot or moving and your done. If you need service done, reconnect them before you take the truck to the dealer. Enjoy.
  9. #8
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    Quote Originally Posted by tundra3400 View Post
    synthetic, the guy at the shop told me i should change the oil every 6k, i changed it twice after 4 or 5k, i think ill change the oil this week.
    anyway i got a small clip because im a bit worried, i never noticed the oil gauge moving before
    tundra oil gauge behavior?? (temp) - YouTube
    i really appreciate you help guys
  10. #9
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    did you just start using the synthetic or have you had it in the truck before?
    CBTMA Member
    Lock-Rite (maybe)
  11. #10
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    I only used synthetic ( the 1 that last longer) .
    i only changed it twice as i mentioned in the first post, 11k on the truck now.
    is this normal?
  12. #11
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    20
    Posts
    2,534
    Liked
    961 times
    Images
    38
    Rep Power
    42221
    i was told for my truck that its normal for the gauge to move like that with synthetic oils. mine usually hovers lower than the second line kinda close to the bottom when warm and idling. when i take off it moves quickly upward to the 3rd line closer to the top line. the only thing is that my truck is v6 3.4L and yours is the v8 5.7L so the gauge might stay a little higher because of the larger motor. i think its normal.
    CBTMA Member
    Lock-Rite (maybe)
  13. #12
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    thanks for your help
  14. #13
    Join Date
    Jan 2011
    Location
    Auburn, AL
    Posts
    72
    Liked
    8 times
    Rep Power
    390
    Watched your video...absolutly normal...stop worrying and drive the dang thing.
  15. #14
    Join Date
    Oct 2011
    Location
    UAE
    Posts
    244
    Liked
    24 times
    Images
    1
    Rep Power
    4
    Thread Starter
    Quote Originally Posted by Fordless View Post
    thx mate
  16. #15
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,524
    Liked
    20 times
    Rep Power
    1156
    Mine has worked like a mini-Tach since new..........
    '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
