Serpentine belt keeps shredding!
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 44
Like Tree2Likes
Thread: Serpentine belt keeps shredding!
  1. #1
    Lurking Member moutonja's Avatar
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Default Serpentine belt keeps shredding!
    Well first I appreciate all the help yall provide and hopefully someone can help me. Sunday the 6th I had my truck towed to NTB because my belt was shredding so they replaced it and said I need to change my water pump because it was leaking but they need to get the part from the dealer so I could do it later. Well this morning started the truck heard a noise and my belt started to come apart again and wrap around my fan so I am towing it to them again. Is there a problem that happens with these like the pully's are misaligned or do you think defective belt. I just want to be sure I can cover bull answers when they tell me whats wrong because they have to warrantee it.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,095
    Liked
    339 times
    Images
    8
    Rep Power
    42560
    Default Re: Serpentine belt keeps shredding!
    A bad tension idler can cause that to happen.
    Serpentine Belt tensioner Pulley Replacement
    WT likes this.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Thread Starter
    Thanks for that!
  5. #4
    WT
    WT is offline
    Veteran Member WT's Avatar
    Join Date
    Sep 2007
    Location
    Virgina
    Posts
    1,353
    Liked
    75 times
    Images
    6
    Rep Power
    8006
    +2 was going to say I heard of this only a few times but this is what it was. Also you may want to check if you still fall into the TSB on this but since you didn't mention the year of your truck not sure if this applies.
  6. #5
    Veteran Member StevJ's Avatar
    Join Date
    Feb 2007
    Location
    Poulsbo, Wa
    Age
    100
    Posts
    1,106
    Liked
    149 times
    Rep Power
    11015
    Yep. Occasionally, something stops turning, and it's usually the tensioner.
    But tensioners typically ride on the back of the belt, and usually won't shred the belt unless the tensioner is froze up solid.
    Steve
    Attached Files Attached Files
    1. Common sense is a curse in disguise, because if you have it, you have to live with those who do not.
    2. Everything will work exactly as expected, unless your expectations are incorrect.
    3. When Noah sends his animals to go forth and multiply, a pair of snakes replies “We can't multiply, we're adders” — so Noah builds them a log table.
    ˇpןɹoʍ ǝɥʇ ɟo sɹǝpuoʍ ǝɥʇ ɟo ǝuo sı ǝpoɔıun ʞuıɥʇ ı
    Compassionate misanthropy: loving mankind selectively.
    DIY AIP BYPASS <--
    Block-Off Plate Drawings<--
  7. #6
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Thread Starter
    Well NTB said just a defective belt so I picked up the truck. I asked them if the idler pulley could be bad and they said no. Well this morning same damn thing belt shredding! By the way 2007 tudra.
  8. #7
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,095
    Liked
    339 times
    Images
    8
    Rep Power
    42560
    It could be any one of the pulleys, but the odds are that the bearing in the tension idler pulley is shot.
    There is a TSB for the '07-08 models.
    t-sb-0323-08-pulley.pdf
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
  9. #8
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Thread Starter
    Toyota said they won't do it for free since I am over the 36,000 mile mark. I think I'm at 80 or 90,000 miles now. NTB said they would give me a belt for free and I might change the tensioner pulley myself I guess. I'll just have to cross my fingers.
  10. #9
    Join Date
    Aug 2007
    Location
    alabama
    Posts
    63
    Liked
    2 times
    Rep Power
    9
    moutonja, I had the exact same situation you did. I had replaced my 4th belt in 66k miles. At 48k miles , toyota told me that my tensioner was bad and replaced the tensioner and water pump along with the belt. About 10k miles later it ate another belt. Thats when I switched to the gatorback and got good results until 66k miles so I just threw on another gatorback. To my surprise it ate the next belt in less than 24 hrs! At that time I gave in and went to the Stealership. They told me the tensioner had failed and that the idler was sitting at an angle, loose. My pulley was eating the first rib off the belt everytime. Not snapping the belt in two but would just take the first rib off and wrap it around another pulley. If you had similar symptoms with your belt just do yourself a favor and swap that tensioner first. Good luck, -Craig
  11. #10
    Veteran Member TRDDunn's Avatar
    Join Date
    Aug 2007
    Location
    N.W. Houston TX.
    Posts
    519
    Liked
    4 times
    Rep Power
    1871
    I had to replace mine also. I live in Houston and can lend a hand if you need. It's pretty easy. You will need a quality set of Allen's. The one in the center of the pulley can be a B. I bought mine from joe Myers for about 60 or so. I have also done my own water pump if you need some help. Took me about 5 hrs taking my time.
    07 5.7 TRD Slate, Rock Warrior Wheels, 35W 6K HID'S LOW & FOG,AFE stage 2 CAI,debadged,black headlight mod,N-Fab Steps, Air Lift airbags, CW 5 pc grill in black,AVS in-channel visors,TRD shifter,G-TEK Sills, V-LEDs, GLOCK 22
  12. #11
    Join Date
    Sep 2007
    Location
    new hampster
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    2007 Crewmax. At about 80k i looked at my belt and it was shredding too. I brought it in andluckily purchased the extended warranty.
    The ideler pullys were manufactured incorectly more cone shaped than cup. This destryed my water pump also. Toyota replaced everything for free and so far so good
  13. #12
    Supporter Delaware's Avatar
    Join Date
    Sep 2009
    Location
    Delaware
    Posts
    504
    Liked
    109 times
    Rep Power
    4616
    Seriously, NTB for a serpentine belt replacement. I've had situations where they could barely put tires on correctly.
    Delaware
    2007 Tundra SR5 4WD, Super White, RollBak G2 Tonneau
    2012 RC Tacoma, Pyrite Mica [Kid's college vehicle]
    2002 Tacoma, White [Sold]
    2001 Tundra, Green [Sold]
  14. #13
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Thread Starter
    Wow thanks for all the help! Reason for NTB is I was an hour and a half from home with no tools on a sun so
    they were the only hope.
  15. #14
    Join Date
    May 2012
    Location
    Houston
    Posts
    24
    Liked
    0 times
    Images
    15
    Rep Power
    4
    Thread Starter
    This is what Joe Myers Toyota is quoting me! I can't believe they actually do any work for these prices!? They want $100.00 for the tensioner pulley and $186.00 for the belt if I buy the parts to do it myself but NTB will give me a belt for free since I paid for it. I didn't even ask about the water pump! So next question what should I buy from the dealer and what should I call around for? I am going to do the work myself this Sat so TRDDunn if you are available to help out that would be awsome! Just email me at jamesallenmouton@yahoo.com if so and I will give you the address and phone number.
    REPLACE TENSIONER AND DRIVE BELT (FOUND
    TENSIONER BAD) $431.64
    B. JOE MYERS TOYOTA COURTESY INSPECTION $0.00 X
    Subtotal $431.64
    Inspection Recommendations Status Cost Declined Approved
    Replace water pump (Found engine coolant leak) Fail $792.21 See AI-32
    Subtotal $792.21
    Perform air conditioning system refresh service (Found cabin
    air filter dirty) Caution $64.99
    Perform reardifferential service (REAR DIFFERENTIAL
    DUE BY TIME / MILEAGE) Caution $110.00 See AI-6
    Replace cabin air filter (Found cabin air filter dirty) Caution $54.99 See AI-18
    Perform transmission fluid exchange service (Found
    transmission service due by time or mileage) Caution $299.99 See AI-60
    Perform power steering system fluid exchange service
    (Found power steering fluid dirty/contaminated) Caution $99.99 See AI-62
    Perform brake system fluid exchange (Found brake fluid
    dirty/contaminated) Caution $99.99 See AI-63
    Perform battery service (Found battery cables/terminals
    corroded) Caution $29.99 See AI-66
    Subtotal $759.94
    Totals, Taxes and Fees Cost Declined Approved
    Estimate Subtotal $1,983.79 $0.00 $0.00
    Shop Fee $39.00 TBD $0.00
    Tax 8.25% $166.88 TBD $0.00
    Estimate Total $2,189.67 TBD $0.00
  16. #15
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,095
    Liked
    339 times
    Images
    8
    Rep Power
    42560
    I don't think that I would rush right into that service department for anything. They seem to be a bit overpriced!
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
