Question Tire pressure sensor help???
+ Reply to Thread
Results 1 to 13 of 13
Thread: Tire pressure sensor help???
  1. #1
    Join Date
    May 2012
    Location
    Gainesville, Fl
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Default Tire pressure sensor help???
    I have a 2010 tundra double can that came with factory steel rims. I just installed the 2012 20" tundra platinum rims on my truck but the wheels did not come with tire pressure sensors. Can I use my sensors from the 2010 steel wheels on the 20" alloys? If not what part # sensors do I need to order. The sensor light actually didn't activate for the first 24 hours but is now illuminated. Please help
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,129
    Liked
    350 times
    Images
    8
    Rep Power
    42968
    Default Re: Tire pressure sensor help???
    The steel wheels take 40 degree sensors. The alloy wheels require 20 degree sensors. The are not interchangeable.
    The option is to seal the sensors from your steel wheels inside a piece of plastic pipe and pressurize it.
    EASY....TPMS ISSUES SOLVED! Pictures Included
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Join Date
    May 2012
    Location
    Gainesville, Fl
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for the help! And this is a reliable fix?
  5. #4
    Join Date
    May 2012
    Location
    Gainesville, Fl
    Posts
    10
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    So if I buy 20 degree sensors and have them installed will the work correctly. How much do you think a shop would charge me to apply them. If I don't install them for a while it won't damage anything correct, it will just keep the annoying light on right???
  6. #5
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,129
    Liked
    350 times
    Images
    8
    Rep Power
    42968
    The cheapest fix is some black tape over the light, unless your state requires the TPMS to function for inspection.
    I suggest you shop around a bit. The factory sensor price is quite high, but dealers have the Techstream to enter the new sensor serial numbers into the ECU.
    Some tire shops have the tools to enter them into the ECU but a lot of them don't. Tire shops are always questionable when it comes to installing them without damage.
    If you buy aftermarket sensors (much cheaper) make sure you write down all four serial numbers before you install them. These numbers must be entered into the ECU to get rid of the light.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
  7. #6
    Supporter Delaware's Avatar
    Join Date
    Sep 2009
    Location
    Delaware
    Posts
    506
    Liked
    109 times
    Rep Power
    4616
    Quote Originally Posted by mendonsy View Post
    Come on Mendonsy that's the caveman approach. You steered me to the wiring work around by bstevens a month ago. I purchased the parts for like $4.00, did a little soldering and problem solved. Sure beats carrying a pressurized canister around.
    Firemedic71 - Check out this thread for a quick fix. See post #11
    Tpms light!! Toyota has a problem
    Delaware
    2007 Tundra SR5 4WD, Super White, RollBak G2 Tonneau
    2012 RC Tacoma, Pyrite Mica [Kid's college vehicle]
    2002 Tacoma, White [Sold]
    2001 Tundra, Green [Sold]
  8. #7
    Join Date
    Sep 2006
    Location
    houston
    Posts
    85
    Liked
    5 times
    Rep Power
    9
    Why you gonna take a chance with your life and your 30k truck to save $150 on tpms and $60 to install bro? Tires are the most important part on your truck.
    Sent from my Autoguide iPhone app
    2011 DC 5.7
    TRD Exhaust
    TRD S/C
    Hella Supertone
  9. #8
    Join Date
    Oct 2010
    Location
    Birmingham, AL
    Posts
    15
    Liked
    0 times
    Rep Power
    0
    Most people including me have lived quite safely for years w/o TPMS just check your air pressure and look at your tires.
  10. #9
    Join Date
    Sep 2009
    Location
    Delaware
    Posts
    506
    Liked
    109 times
    Rep Power
    4616
    Quote Originally Posted by dndodd View Post
    My thoughts exactly. If TPMS were a $500 option I suspect that very few would opt in.
    Delaware
  11. #10
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,129
    Liked
    350 times
    Images
    8
    Rep Power
    42968
    Quote Originally Posted by Delaware View Post
    AND ........... For those of us with '07s the sensor batteries are due to die of old age soon so it's about $500 to replace them.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
  12. #11
    Supporter Chudlles's Avatar
    Join Date
    Nov 2009
    Location
    Prince George B.C.
    Posts
    517
    Liked
    114 times
    Images
    20
    Rep Power
    7440
    You can just buy new stems that will work with the 20's and use your old sensors. To install a sensor you don't have to dismount the tire, just break the front bead. It should be under a $100. Do the new wheels you bought not have sensors? I'd check that first, cause they can be learnt to you truck.
    sent by my HTC Desire HD
  13. #12
    Join Date
    Sep 2009
    Location
    Delaware
    Posts
    506
    Liked
    109 times
    Rep Power
    4616
    And when the batterie[s] die does the pressurize tube do you any good?
    Delaware
  14. #13
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,129
    Liked
    350 times
    Images
    8
    Rep Power
    42968
    Nope, not one bit of good!
    And for those of us who have to have a functional TPMS to pass inspection, it will require a bit more elaborate bypass circuit.
    Toyota SS steps
    ARE MX cap
    AMP bed step
    Ultragauge EM
    Techstream
    CBTMA member
    Block Off Plate
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
