*** 2007 Black Tundra CrewMax 5.7 liter SR5 4x4 with TRD and tow packages. Old Man Emu 3/1 complete lift with Toyo Open Country M/T's - 285x75x18's. Hypertech speedo recalibrator. Ultra Motorsports 18" black rims with silver accents. N-Fab 6-step, wheel to wheel black nerf bars. G-Tek radiator air-dam and door sill protectors. Arma Coatings spray in bedliner and bumpers by On The Road Trucks in Rocklin, CA. De-badged. Black grill surround. RBP black exhaust tip. Air Lift 5000 air bags with WirelessOne remote. Amp Research bed step.
*** 2008 Flint Mica Yaris aka: Vios 'S' sedan. TRD lowering springs, TRD cold air intake, TRD anti-sway bar for the rear, TRD Sportivo rear shocks and front struts. Tinted windows all the way around, Tanabe front shock tower brace, 17" rims - Samurai SC02 Hyper Black. Megan Racing header.
*** 2009 Salsa Red Corolla 'S' 5-speed manual.Wife's ride. Back windows tinted, but otherwise stock.
Everyone's setup, truck weight, etc is different. One trick is buy some children’s sidewalk chalk, those big ol' giant pieces, then with your truck on a flat, smooth surface, liberally coat the tread with the chalk (lay the chalk on it's side) covering it completely from side to side and from 7 o'clock to 5 o'clock position (or as much as you can reach). Then slowly drive your truck straight ahead for about 50'. Stop, put it in park and look to see where the chalk is left behind on the tire and adjust your tire pressure so that you remove approximately 90% of the chalk from side to side. Basically 5% on each outside edge should still have chalk left. You can also do this if the pavement is wet and you can slowly drive to a dry section. Not quite as effective as the water left on the tire as the indicator starts to dry pretty fast.
I did the chalk method and that's why even with a load range "E" tires with stiff sidewalls I'm in the 30-32 psi range for every day use. However, I don't hesitate to bust out the air compressor if I know I will be towing or carrying a heavier load. Everything is a compromise - ride quality vs. fuel economy vs. tire wear. For me and my CrewMax with Toyo M/T's load range "E", 30-32 psi has proven to be the right pressure for the majority of my use. Your mileage may vary.![]()
I usually have it at 40psi cold, and it heats up 2-3psi.
I just put a set of Michelin LTX M/S2 LRE tires on my Tundra. Sent an email to Michelin on tire pressure for these and was told 50PSI front 55PSI rear would be equivalent to the P rated at 30 and 33. Running both front and back at 55 right now. Don't notice too much difference in the ride from the P rated tires. A bit stiffer but not a lot.
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors
Scangauge II
Cooper Discoverer ATR's
Techstream
CBTMA member
aip override 1.1.pdf
Block Off Plate
I agree. The factory recommendations aren't for any and all tires you will ever put on your truck.
Different tires have different optimal PSI.
Start with what is says on the tire itself and adjust from there.
36 psi in my stock 2012 CM 4X4 tires.
Another way to check the air pressure distribution on a tire is to check it after a long drive ( as the tires are as hot as they will be.
Use an Infra Red thermometer and check the tire temperature on the outside part of the tread, then in the middle, then on the inside.
Those three spots should be at the same temp. If the outside is hotter you have too much toe-in .
If the inside is hotter, you have toe-out.
If the temp is even all over the tire, your alignment and tire pressure are correct.
If the middle part of the tire is lower than the outside parts, increase the air pressure.
If the middle part is higher, deflate a bit.
This is easy to do and an easy guide for alignment and best air pressure.( for even tire wear ).
Enjoying the awesome 5.7 L engine
TRD rear Sway Bar, Billet Grille, Heated Seats, Westin Bull Bar and Skid Plate, HELLA driving Lights, Chrome handles and mirrors,
I just got new tires (cooper st maxx) 33" and running 40psi. I could see going up to 45 unloaded. I may try that
2013 Ram Crew Sport 4x4, 5.7, 8-speed, 3.92
2010 Tundra 4x4 5.7 Limited, Slate, TRD RW Wheels with 33" Cooper ST Maxx (sold)
I'm running 38PSI now on my Michelin LTX M/S2's (P285/70/17). Noticed slightly more wear on outside edges at 35psi, so I went up to 38. Couldn't be happier, still a damn good tire.
I just up mine to 45 psi all the way around, seems to be better on the MPG. ride is fine as well so this seems to be the sweet spot for this set-up.
use the chaulk method. rub chaulk alond the tire and drive down a few hundred feet, when chaulk is evenly wore out along the tire then you have reached the right tire pressure. its trial and error till you get it right. you will notice that fronts will need more air.
