What psi do you run in your tires?
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Like Tree4Likes
Thread: What psi do you run in your tires?
  1. #1
    Lurking Member joshc8503 is on a distinguished road.
    Join Date
    Jun 2012
    Location
    NC
    Posts
    21
    Liked
    1 times
    Rep Power
    2
    Default What psi do you run in your tires?
    What psi do you run in your tires? Do you go by the number on the door?
  2. #2
    Veteran Member RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter is almost part of the TundraSolutions family. RRzxter's Avatar
    Join Date
    May 2011
    Location
    Buffalo, NY
    Posts
    783
    Liked
    112 times
    Rep Power
    5170
    Default Re: What psi do you run in your tires?
    I can't remember what my current tires run.
    But I run whatever is specified on the tire itself.
    If you buy aftermarket wheels/tires and go to a different size, etc., chances are that specific tire/manufacturer designed their tire to run at a different pressure.
    Particularly if you go up to a 10-ply for towing.
    So, can't really go by what's in the door jamb.
  3. #3
    Supporter Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw is a glorious beacon of light. Ton-draw's Avatar
    Join Date
    Jan 2009
    Location
    WI
    Posts
    137
    Liked
    4 times
    Images
    9
    Rep Power
    192
    I always fill to just below the max cold-fill pressure specified on the tire for better fuel economy. It's almost 10 psi higher than what the sticker in the door jamb suggests for P-rated tires. When filled to the lower Toyota recommended pressure the truck feels a bit sloppy and sluggish to me.
    E-rated tires will vary much more, like RRzxter touched on. The guys who do a lot of towing can comment on high ply tires.
  4. #4
    Lurking Member ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some. ccraig has done just about everything...and then some.
    Join Date
    Jan 2012
    Location
    Ma
    Posts
    46
    Liked
    3 times
    Images
    2
    Rep Power
    792
    32 to 35 psi.
    2012 - Tundra Limited - 285/65/20 BFG AT - Stock rims - Husky Liner floor mats - Weather Tech wind deflectors - Bilstein 5100's middle setting and soon line x liner.
  5. #5
    Veteran Member deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points.
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,455
    Liked
    155 times
    Images
    13
    Rep Power
    9436
    i love ply! 45 to 50 psi for me.
  6. #6
    Join Date
    May 2011
    Location
    Buffalo, NY
    Posts
    783
    Liked
    112 times
    Rep Power
    5170
    Quote Originally Posted by ccraig View Post
    32 to 35 psi.
    What size tires?
    What load range?
    Conventional or synthetic air?
    Are you running summer air or all-season?
  7. #7
    Supporter mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy wants you off his porch. mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    4,583
    Liked
    197 times
    Images
    8
    Rep Power
    32267
    40 to 45 psi works best for me.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Scangauge II
    Cooper Discoverer ATR's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  8. #8
    Just a Herbicidal maniac. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal is almost part of the TundraSolutions family. Herbicidal's Avatar
    Join Date
    Aug 2000
    Location
    Roseville, CA.
    Age
    50
    Posts
    2,039
    Liked
    67 times
    Images
    385
    Rep Power
    5341
    CrewMax - scaled weight of 6,050 lbs with just me and a 1/2 tank of gas. Tires: 285x75x18 Toyo Open Country M/T's: Unloaded 30-32 psi, anything higher starts wearing out the center first. Towing our 26' travel trailer: 40 psi. This is my 3rd set of the Toyo's on two different Tundra's. The lower psi gives me a more even wear pattern. I'm averaging ~50,000 miles per set. The other key to long tire life is to rotate and balance! I have it done every 3,000 miles since it's "free" for me and was included in the price of the tires. Doing it today after work as a matter of fact. Especially important on the larger M/T type of tires.
    RRzxter likes this.
    *** 2007 Black Tundra CrewMax 5.7 liter SR5 4x4 with TRD and tow packages. Old Man Emu 3/1 complete lift with Toyo Open Country M/T's - 285x75x18's. Hypertech speedo recalibrator. Ultra Motorsports 18" black rims with silver accents. N-Fab 6-step, wheel to wheel black nerf bars. G-Tek radiator air-dam and door sill protectors. Arma Coatings spray in bedliner and bumpers by On The Road Trucks in Rocklin, CA. De-badged. Black grill surround. RBP black exhaust tip. Air Lift 5000 air bags with WirelessOne remote. Amp Research bed step.
    *** 2008 Flint Mica Yaris aka: Vios 'S' sedan. TRD lowering springs, TRD cold air intake, TRD anti-sway bar for the rear, TRD Sportivo rear shocks and front struts. Tinted windows all the way around, Tanabe front shock tower brace, 17" rims - Samurai SC02 Hyper Black. Megan Racing header.
    *** 2009 Salsa Red Corolla 'S' 5-speed manual.Wife's ride. Back windows tinted, but otherwise stock.
  9. #9
    Lurking Member Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold. Yaesu is a splendid one to behold.
    Join Date
    Jan 2012
    Location
    Rineyville, KY
    Posts
    43
    Liked
    3 times
    Rep Power
    15
    I have the stock tires and run the maximum pressure printed on the side wall. The harder the tire the better it rolls. I am not concerned about a cushy ride.
  10. #10
    Junior Member krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29 has a brilliant future. krut29's Avatar
    Join Date
    Aug 2007
    Location
    Newnan, GA
    Posts
    106
    Liked
    2 times
    Rep Power
    106
    I am running the 10 ply "E"rated tire. I typically keep 50 psi in the tires.
    Thanks Ken
    Sent from my VS910 4G using AutoGuide.com App
    07 Tundra, 5.7, 4X4, ToyTec 3" level kit with rear add a leafs. Smitty Built Step Bars, Bull Bar, Pro Comp Lights, Rear Seat Mod, Falken 10Ply E Rated Tires Firestone Ride Rite airbags.
  11. #11
    Junior Member ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16 has done just about everything...and then some. ggms16's Avatar
    Join Date
    Jun 2012
    Location
    Lake Hart
    Posts
    91
    Liked
    6 times
    Rep Power
    1058
    I use 30psi up front and 32 in the rear... I think that's what toyota recommends.
    How come some of you guys put over 40psi? Isn't that bad for the mpg?
  12. #12
    Junior Member thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some. thechristianbear2001 has done just about everything...and then some.
    Join Date
    Nov 2011
    Location
    Canadian, Texas
    Posts
    102
    Liked
    8 times
    Images
    9
    Rep Power
    788
    I have hankook dynapro atms 285-65-18 ..... running 38psi in all right now but have no idea what is best to run them. I dont haul anything usually so any suggestions on what is optimal for my setup?
  13. #13
    Join Date
    May 2011
    Location
    Buffalo, NY
    Posts
    783
    Liked
    112 times
    Rep Power
    5170
    Quote Originally Posted by ggms16 View Post
    Not everyone is using the same tire. Did you read all the posts?
    Quote Originally Posted by thechristianbear2001 View Post
    What does it say on the tires?
  14. #14
    Junior Member Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future. Sid Post has a brilliant future.
    Join Date
    Nov 2008
    Location
    Huntsville, Alabama
    Posts
    431
    Liked
    1 times
    Rep Power
    103
    I recently intalled Michelin LTX AT2 E-rate 10-ply tires on the factory 20" wheels. I had passenger rated P-Metric equivalents on previously. With ~60K miles, I had excessive shoulder wear and good tread left in the center of the tire. I rotated and balanced frequently. With 32 PSI, I had excessive sidewall flex so I generally ran these tires at 38PSI. With the tread wear pattern, I'm curious why I had shoulder wear that didn't match the tire's center. Give the high PSI, I expected the tire to be more donut shaped and wear in the center more then the shoulder
    I'm curious what I should ran these new E-rated tires at. I think I will try 40PSI.
    On a related note, these tires really kill the ride quality. With the P-Metrics, my Tundra had almost a car like ride on most road surfaces. The jury is still out on the E-rate equivalents but, they are a much rougher ride though things are smoothing out with a little bit of break in.
    2007 Toyota Tundra Double Cab SR5 with the 5.7L V-8, AFE CAI, Doug Thorley headers, Firestone airbags, and Rancho RS9000XL shocks on the rear
    PIAA driving lights in the factory foglight position. N-FAB PreRunner bar with 3 Hella Rallye 4000 EuroBeams with position lights.
    Need to add the RanchHand rear bumper and some F-FAB steps to help mom get in my pickup ...
    "Trying to tax yourself into prosperity is like standing in a bucket and trying to pick yourself up by the handle." - Winston Churchill?
  15. #15
    Join Date
    Nov 2008
    Location
    Huntsville, Alabama
    Posts
    431
    Liked
    1 times
    Rep Power
    103
    double post with a slow loading web page.
    Last edited by Sid Post; 07-08-2012 at 09:59 AM. Reason: double post - website was very slow
Posting Permissions
  • You may not post replies
  • You may not edit your posts
