Loose steering when hitting umps under 40 mph
+ Reply to Thread
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By mendonsy
Thread: Loose steering when hitting umps under 40 mph
  1. #1
    Junior Member 38Thumper's Avatar
    Join Date
    Jun 2007
    Location
    Pittsburgh
    Posts
    157
    Liked
    1 times
    Rep Power
    71
    Default Loose steering when hitting umps under 40 mph
    Does anyone else have a loose feeling or sloppy steering wheel when hitting small bumps? I have 2012 CM and I noticed something loose when hitting bumps it may even be in the steering linkage or suspension. Its all stock and 1500 miles???? My 2007 and 2010 did not have this issue.
    2012 Tundra Crewmax Platinum 5.7, Super White
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter mendonsy's Avatar
    Join Date
    Oct 2007
    Location
    Western NY
    Posts
    5,131
    Liked
    350 times
    Images
    8
    Rep Power
    42968
    Default Re: Loose steering when hitting umps under 40 mph
    Sounds like something that would be worth having the dealer take a look at. If nothing else that would create a record that there was a problem if something happens later on.
    teallin likes this.
    07' SR5 DC 4x4, 5.7, TRD
    Toyota SS steps
    ARE MX cap
    AMP bed step
    DIY underseat storage
    Weathertech Floor Liners
    Weathertech Vent Visors
    Ultragauge EM
    Cooper Discoverer AT3's
    Techstream
    CBTMA member
    aip override 1.1.pdf
    Block Off Plate
  4. #3
    Join Date
    Nov 2012
    Location
    Gatineau
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    I have a 2012 platinum and have the same problem! Mine is also bad at hyw speed when going over rough pavement. It feels unstable and unpredictable. I had the dealership check the front end suspenssion and shocks with no luck. I've got the tires changed and an enlignement... Still no luck!
    I'm thinking that the dealership missed something.
  5. #4
    Join Date
    Aug 2008
    Location
    orange county
    Posts
    100
    Liked
    2 times
    Rep Power
    9
    I think that's called bump steer, either the inner or the outer tie rod ends needs to be rerplaced to fix the problem.
    BT
  6. #5
    Supporter cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,355
    Liked
    9 times
    Images
    3
    Rep Power
    914
    You can usually check a steering looseness with2 people. One turning the steering with wheels on ground and the other checking tierods and other steering parts.
    Charlie & Linda
  7. #6
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,456
    Liked
    156 times
    Images
    13
    Rep Power
    9438
    an alignment and good tire pressure will do wonders.
    tie rod ends and bushings are the second step.
  8. #7
    Junior Member Shotgun's Avatar
    Join Date
    Dec 2008
    Location
    upstate SC
    Posts
    203
    Liked
    11 times
    Rep Power
    2224
    Quote Originally Posted by Tundra_2012 View Post
    I have an 08 rcsb, and that pretty much sums up the handling of my truck on anything but smooth roads. Haven't been able to find anything wrong.
    I'm hoping when I switch from OEM to Michelins, and maybe add a TRD rear sway bar, things will improve. Otherwise, the driving experience doesn't inspire confidence in adding a supercharger.
  9. #8
    Join Date
    Nov 2012
    Location
    Gatineau
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Same for me!! I just got the truck about 3 weeks ago and had them check everything suspenssion includding shocks. I had an enlignement done and even swaped the tires.
    Driving on a nice smooth road it has no issues but as soon that there are bumps I can't keep it on a strait line. The truck feels really unstable and unpredictable.
    I need help with this! I would have expected thing like this from a Gm or Ford but never from a Toyota! Seems like the dealership can't figure it out so they say it's normal... Bunch of crap if you ask me!
    Any help would greatly be apreciated!
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
