Tundra electric cooling fan kit available!
+ Reply to Thread
Page 1 of 7 1 2 3 4 5 6 ... LastLast
Results 1 to 15 of 99
Like Tree12Likes
Thread: Tundra electric cooling fan kit available!
  1. #1
    Junior Member texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96 is a pinnacle in their own mind. texasranger96's Avatar
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Default Tundra electric cooling fan kit available!
    Hey what's going on guys, I havn't posted here in a while. Any way I have spent a couple months on R&D for the 07 and up cooling fan kit, I currently have the kit installed on my 2012 Tundra and is working flawless, what I am currently using on the truck is two 16" 2450 spal high amperage fans with the equivelent of almost 5000cfm, mounted on an aluminum adapter plate, the controls are two spal high amperage water proof relay harnesses controlled by the Dakota digital fan controller with a temp sensor in upper radiator hose all water proof connections. These fans are made in Italy and are more reliable than others and are OEM grade and supplied to high end car maufacturers.
    The kit that I will be selling is either the plate with the fans only for $385 and the complete kit with everything for $550 to bolt in just a few wires to hook up, the polished diamond plate would be a little more and this does not include shipping.
    Tundra cooling fan possibilities! - TundraTalk.net - Toyota Tundra Discussion Forum
    Fan only kit includes,
    2 Spal 16" 2450 cfm fans
    1 mounting plate
    Mounting hardaware
    All preassembled ready for install
    Fan complete kit includes,
    1 mounting plate
    1 Mounting hardaware kit
    1 Deraledual fan controller
    1 radiator hose sensor adaptor
    1 Sienna coolant tank
    Vettelover84 and deviltundra like this.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Default Re: Tundra electric cooling fan kit available!
    Hippo likes this.
  4. #3
    Junior Member Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation. Mr.Kong would rather be driving his reputation.
    Join Date
    Apr 2012
    Location
    Wv
    Posts
    55
    Liked
    7 times
    Rep Power
    684
    Very nice. Any chance you have access to a dyno and could post up some numbers?
  5. #4
    Junior Member RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation. RRich would rather be driving his reputation.
    Join Date
    Jul 2011
    Location
    Orange City, Fl
    Posts
    52
    Liked
    1 times
    Rep Power
    534
    That's a serious mounting plate! Only problem is it appears to block about 40% of the rad area. How about adding some flaps to that blocked area so air can flow at speed?
  6. #5
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Man in regards to the 40% radiator blockage you should see the stock radiator shroud while it is out it pretty much sets right up against the radiator as well and my fans probably flow twice as much at 5000cfm not to mention it runs smoother, quieter, more throttle response, better mpg, and you can set it up to do what ever you want, like leave it running for better idle air temps (iat) for the supercharger inner cooler. As far as Dino numbers I live pretty much out in BFE MO. Another thing that I should note it is way more cleaner under the hood, more room to change belts and work on front of engine without having to drain coolant to pull upper hose and stock shroud for pulley changes and what ever else each fan can be pulled off individually if need be.
  7. #6
    Veteran Member randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family. randomwalk101 is almost part of the TundraSolutions family.
    Join Date
    Dec 2005
    Location
    houston
    Posts
    1,086
    Liked
    32 times
    Rep Power
    6875
    I just came back from Toyota plant and saw the fan shroud in person sitting outside. The stock shroud only sits against the radiator at the edges. It curves out around the fan directing air through the middle hole where the stock clutch fan is. In other words, all air from any fin of the radiator can freely flow through.
  8. #7
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    You have to ounderstand the amount of room there is under between the raiator and the engine it is just simply not possible if you mount them in a box you are achieving nothing. I actually have a degree in air conditioning I spent alot of time on this, the fans probably flow twice as much as the stock one, I have #1 set at 195 and #2 set at 205 the second one has never came on since the install the first one hardly ever comes on so I know it is working. Besides the Dakota digital says what temp it is and it has never overheated, the stock one is very thin with a slight bend I am certain this works with no issues. Oh and the plate is not directly on the radiator it sets off from it about an inch to build a better shroud I would need to move lower raiator hose and the fans would be like an inch away from the engine, and the price would go way up I am already making virtually nothing.
  9. #8
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Here is the video.
    http://youtu.be/QgquJJ6PN8o
  10. #9
    Lurking Member l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of. l1tech has much to be proud of.
    Join Date
    Jun 2012
    Location
    AZ
    Posts
    39
    Liked
    3 times
    Rep Power
    44
    I converted a 2002 Dodge Dakota and also a late 90's Ford Explorer to electric cooling fans and realistically the only thing that I noticed was a lighter wallet. Neither vehicle felt as if it ran better or had any more power and gas mileage on both vehicles was not affected at all. I'm not saying that this would be the case with the Tundra but I'm skeptical of any real benefits that this would provide. I can appreciate the work you have put into this though.
  11. #10
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Well thing that actually like most on my truck is it is not loud now and the throttle response, and I can totally understand how you would not get any more power out of dodges and fords as they will always be doggy.
  12. #11
    Veteran Member deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points.
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,453
    Liked
    154 times
    Images
    13
    Rep Power
    9436
    i like your work!! if you would make the backing plate out of cheaper sheet metal, add some one way flapper valve plates for freeway speeds, and drop the price a little. i would be all in! i might just bite at what is available now, but i would like to see some more reviews first at that price.
  13. #12
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Quote Originally Posted by deviltundra View Post
    I actually made an adapter plate out of 1/8" and did not give the warm fuzzy feeling not rigid enough, I wouldn't put it on my truck, the spal fans I am using one of the best spal produces and usually goes for $150 a piece the controller I will be using is usually about $150, the plate my cost is $70 and the tank I am using is $40, and that doesn't even include the wiring and hardware. Do the math,I refuse to build junk especially for one the most reliable trucks built the Tundra, I guess it kinda reminds when I read how Toyota was selling the GM Cavalier in Japan under the Toyota Cavalier, the car was such a piece of crap that the Japanese government actually fined them for discracing the Japanese auto manufacturers.
  14. #13
    Lurking Member t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra has blessed us with their presence. t&ctundra's Avatar
    Join Date
    Jun 2007
    Location
    Beaver, UT
    Posts
    33
    Liked
    0 times
    Images
    9
    Rep Power
    35
    So if your fans are rarely on, especially when driving and towing, then how does it keep air flowing through the transmission cooler? I had the flexalite fans on my last tundra and the transmission overheated and failed. Air passing through the radiator while driving kept the engine cool enough to keep the fans off but not cool enough to for the transmission cooler.
    My 1st gen tundra did not have a transmission temp gauge inside like the 2nd gen does though.
    2010 Toyota Tundra Double Cab 4WD TRD 5.7L V8
  15. #14
    Junior Member saki302 is on the right track. saki302 is on the right track. saki302 is on the right track. saki302 is on the right track. saki302 is on the right track. saki302's Avatar
    Join Date
    Jun 2008
    Location
    Los Angeles, CA
    Posts
    183
    Liked
    0 times
    Images
    10
    Rep Power
    7
    I'm curious if this will cool enough for a supercharged truck.
    I had an electric fan on my 98 Tacoma and loved it- it actually gained about 1-1.5mpg, and didn't sound like a .. well, 'truck' anymore I didn't dyno it, but the motor felt like it revved up quicker.
    BUT- my other experience was with a 99 Wrangler 4.0L. I tried several fan setups, from custom single fans to the dual fan kit. They ALL overheated. It was a damn shame too, the Jeep actually felt much nicer without the fan, that engine didn't make th emost power, so it was definitely noticeable.
    It takes a pretty damn strong electric fan to out-pull the stock clutch driven unit. The engine driven fans pull a TON of air.
    -Dave
  16. #15
    Join Date
    Sep 2011
    Location
    warrensburg mo.
    Posts
    330
    Liked
    56 times
    Images
    3
    Rep Power
    1622
    Thread Starter
    Quote Originally Posted by t&ctundra View Post
    I did not say the fans are rarely on I said the second one hardley comes on, my 2012 tundra has the tow package so it does have the trans temp gauge, and never overheated yet.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
