DIY Disable DRL's!!! What's Up Guys I've been a member, just decided to put a post now
+ Reply to Thread
Results 1 to 5 of 5
Thread: Disable DRL's!!! What's Up Guys I've been a member, just decided to put a post now
  1. #1
    Rookie TUNDRAJDM28 is on a distinguished road.
    Join Date
    Aug 2012
    Location
    Miami
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Exclamation Disable DRL's!!! What's Up Guys I've been a member, just decided to put a post now
    So as you may know a lot of you may have if not already disabled the DRL'S of our beautiful Tundras. We all like when we're with our loved ones alone and want the truck on but without anyone knowing you're in it and you're loved one wants the A/C on because some of us "Cough Cough" live in south Florida and its mostly hot and humid throughout the year. So is there anyone please that knows how to disable the DRL's without just unplugging the light and knowing its still a running outlet?! I would greatly appreciate it, Thanks Guys and Gals!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400 is almost part of the TundraSolutions family. tundra3400's Avatar
    Join Date
    Feb 2012
    Location
    Abingdon, MD
    Age
    18
    Posts
    1,113
    Liked
    180 times
    Images
    27
    Rep Power
    6289
    Default Re: Disable DRL's!!! What's Up Guys I've been a member, just decided to put a post no
    the DRLs should have a fuse(s). find the fuse(s) and pull them while your idling.
    2000 Tundra Platinum Metallic 3.4L V6 SR5 AC 4WD, 197,000 miles and counting, Husky Liners, 5000K 35 Watt HI/LO HIDs, LED OEM Fog Lights w/ Fog Modification from IZL, LED Cargo Light, Pioneer DEH 3300UB CD RDS, redruM69's Aluminum Billet Access Cab Window Arm Mod, Kicker 8" Sub with Custom Box, New Frame via The Rust Recall, Bilstein 5100s on 3rd Notch, CV Boot Clamp Mod, Hellwig EZ550 Helper Springs, My 1st Gen Anytime Power Window Mod, K&N Air Filter, Electric Fan Conversion (thanks texasranger96), 180 Amp DC Power Alternator, Map Light Mod & Interior LEDs, 285/75r16 Terra Grapplers, 5000K 35 Watt HID Fogs
    CBTMA Member
    Sometime in the Future:
    Offroad LEDs, Keyless Entry, Tow Hitch
  4. #3
    Junior Member jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas is almost part of the TundraSolutions family. jbroas's Avatar
    Join Date
    Mar 2010
    Location
    San Diego, CA
    Posts
    271
    Liked
    23 times
    Rep Power
    5139
    Here you go man.. Read all 3 pages to just make sure you cut the thin grey wire at pin #5 and not the thick grey wire that's visible in the photo attached on the first post.
    how to disable daytime running lights 07 tundra
  5. #4
    Rookie Nooge is on a distinguished road.
    Join Date
    Nov 2012
    Location
    Georgia
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I removed the panels and searched thru all of the wires, harnesses, connectors, pins, etc and I cannot find pin # 5 like the one shown in the illustration.
  6. #5
    Veteran Member deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points. deviltundra has a criminal record for giving away rep points.
    Join Date
    Dec 2011
    Location
    utah
    Posts
    1,454
    Liked
    154 times
    Images
    13
    Rep Power
    9436
    dont cut all the grey wires like i did, or you will need alot of duct tape.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
