Low tone rattle from frontend
+ Reply to Thread
Results 1 to 12 of 12
Thread: Low tone rattle from frontend
  1. #1
    Rookie redmond is on a distinguished road.
    Join Date
    May 2010
    Location
    Tennessee
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default Low tone rattle from frontend
    I know how hard it is to try and diagnose a noise based on a post............I can't diagnose it and the dealer hasn't diagnosed it while driving the 2007 Tundra. The noise occurs when slowly accelerating from a stop and durning stops, particularly at low speeds. May occur at other times, but can't be heard. Almost like something moving around in the dash, but it isn't. Comes from the frontend. Not much to go on I know. If the truck is raised off the ground to rotate the tires, the noise goes away for about a day, then starts again. Have you experienced this? Could it be the struts? Noise is driving me nuts....
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member bucstundra is on the right track.
    Join Date
    Sep 2006
    Location
    Orlando, FL
    Posts
    53
    Liked
    1 times
    Images
    3
    Rep Power
    7
    Default Re: Low tone rattle from frontend
    I had a similar noise in my 2010. It turned out to be the main wiring harness attachment at the firewall, right side. Disconnected the harness from is mounting and noise went away.
    2010 DCab SR5 4.6l Pyrite Mica
    TRD Off-Road Pkg
    TRD perf intake
    TRD rear sway bar
  4. #3
    Junior Member mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard has much to be proud of. mattjgerard's Avatar
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    399
    Liked
    37 times
    Rep Power
    41
    Is it almost a sort if low sounding creak or clunking? I am hearing that in the front end of my 11 DC 4x4. Low speed, suspension is moving or braking. In and out of h
    Sent from my iPhone using Autoguide.com Free App
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow.
  5. #4
    Join Date
    Oct 2012
    Location
    Coon Rapids, MN
    Posts
    399
    Liked
    37 times
    Rep Power
    41
    Of the driveway mostly.
  6. #5
    Veteran Member DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez would rather be driving his reputation. DawgBonez's Avatar
    Join Date
    Dec 2008
    Location
    Covington
    Posts
    1,148
    Liked
    15 times
    Images
    5
    Rep Power
    702
    You can try this one....
    Creaking Dash, Mirror, you name it....
    08 Limited DC 4x4 Black/Charcoal
    TRD SuperCharger, TRD Cat Back, TRD 22" Forged 5 Spoke
    Odessey Battery, Pioneer Avic Z120BT, PAC SWI-PS, PAC TATO, RockFord Fosgate P1000 w/remote powering a JL SteathBox
    Factory matched tint, Paint matched grill surround, Sequoia mirror caps, Sequoia door handles, Debadged, Appearance rear bumper w/ sonar, Removed step bars
    Full interior LED's including vanity, puddle, reverse, cargo, and license plate LED's, DirectJG 35w 4500k HID's Low Beams, 35w 6000k Fogs, 55w 6000k High Beams, Side marker bulb delete, 2010 TailLights, EBAY bought LED/Smoked 3rd brake Light, Chrome painted amber DRL's and blinker bulbs
    More to come......
  7. #6
    Rookie colaman is on a distinguished road.
    Join Date
    Dec 2008
    Location
    Ontario
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Just went through this. Almost the same types of sounds that you are describing. It's hard to describe sounds in a literary form. It turns out that I had loose bolts in the steering rack. It only took the dealer three times to figure that out. Two in warrenty and one out. They did it under goodwill. Hope this helps. Good luck.
    Tundra 5.7 double cab 4x4
  8. #7
    Lurking Member redmondrr is on a distinguished road.
    Join Date
    Feb 2002
    Location
    Oak Ridge, TN
    Posts
    32
    Liked
    0 times
    Rep Power
    12
    A creak.
  9. #8
    Join Date
    Feb 2002
    Location
    Oak Ridge, TN
    Posts
    32
    Liked
    0 times
    Rep Power
    12
    Thanks. I'll check this today.
  10. #9
    Join Date
    Feb 2002
    Location
    Oak Ridge, TN
    Posts
    32
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by colaman View Post
    I'll check this out today. Thank you!
  11. #10
    Join Date
    Feb 2002
    Location
    Oak Ridge, TN
    Posts
    32
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by DawgBonez View Post
    Thanks for the link - lots of squeaks, rattles and creaks!
  12. #11
    Join Date
    Feb 2002
    Location
    Oak Ridge, TN
    Posts
    32
    Liked
    0 times
    Rep Power
    12
    Quote Originally Posted by bucstundra View Post
    I'll check this out. Thanks
  13. #12
    Junior Member josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1 is a splendid one to behold. josephc1's Avatar
    Join Date
    Feb 2006
    Location
    Texas
    Posts
    78
    Liked
    3 times
    Images
    7
    Rep Power
    30
    I had the same thing on my '08 DC, drove me nuts for several months until I noticed the right front strut leaking. The dealer replaced it under warranty. I had been under there several times and never noticed the leak. 48k miles but I have the extended warranty, cost me $50. Not a single squeak or rattle since, hope this helps.
    5.7 LTD "Big Red", Leather w heated seats. LineX bed liner, Extend a bed, ARE hard bed cover, DU-HA underseat rear storage, (Nav mod, all nav functions all the time), Always on backup camera switch, Firestone Ride Rite air bags, Sway bar, Supercharged, Auburn LSD with stock 4.30 gears.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
